Up to 20% off select tools
Asus Padfone 2 Camera Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
89
All Time:
2,606
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Asus Padfone 2 Camera  Replacement, Power Down Device: step 1, image 1 of 1
      • Hold down the power button.
      Ask FixBot
    2. Asus Padfone 2 Camera  Replacement, Remove Back Plate: step 2, image 1 of 3 Asus Padfone 2 Camera  Replacement, Remove Back Plate: step 2, image 2 of 3 Asus Padfone 2 Camera  Replacement, Remove Back Plate: step 2, image 3 of 3
      • Use plastic opening tool to pry off the back cover of the phone.
      Ask FixBot
    3. Asus Padfone 2 Camera  Replacement, Battery Removal: step 3, image 1 of 3 Asus Padfone 2 Camera  Replacement, Battery Removal: step 3, image 2 of 3 Asus Padfone 2 Camera  Replacement, Battery Removal: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the warning sticker that covers the battery plug and connecting cord.
      • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
      • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
      • Disconnect battery connecting cord using tweezers.
      Ask FixBot
    4. Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: step 4, image 1 of 3 Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: step 4, image 2 of 3 Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: step 4, image 3 of 3
      • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
      • Use of magnetic pad will help with keeping track of screws.
      • Once screws are out, remove the plate.
      Ask FixBot
    5. Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: step 5, image 1 of 3 Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: step 5, image 2 of 3 Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: step 5, image 3 of 3
      • Disconnect four plugs to the motherboard using tweezers.
      • Lift up green motherboard.
      Ask FixBot
    6. Asus Padfone 2 Camera  Replacement, Removing Camera: step 6, image 1 of 2 Asus Padfone 2 Camera  Replacement, Removing Camera: step 6, image 2 of 2
      • Remove camera from back of the motherboard with tweezers.
      Ask FixBot
3 other people completed this guide.
Author
with
Erica
482 Reputation
2 Guides authored
USF Tampa, Team 5-4, Mcgee Fall 2014 Member of USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 89
All Time: 2,606
