Asus Padfone 2 Vibrator Replacement
    1. Asus Padfone 2 Vibrator Replacement, Power Down Device: step 1, image 1 of 1
      • Hold down the power button
      Ask FixBot
    2. Asus Padfone 2 Vibrator Replacement, Remove Back Plate: step 2, image 1 of 3 Asus Padfone 2 Vibrator Replacement, Remove Back Plate: step 2, image 2 of 3 Asus Padfone 2 Vibrator Replacement, Remove Back Plate: step 2, image 3 of 3
      • Use plastic opening tool to pry off the back cover of the phone.
      Ask FixBot
    3. Asus Padfone 2 Vibrator Replacement, Battery Removal: step 3, image 1 of 3 Asus Padfone 2 Vibrator Replacement, Battery Removal: step 3, image 2 of 3 Asus Padfone 2 Vibrator Replacement, Battery Removal: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the warning sticker that covers the battery plug and connecting cord.
      • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
      • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
      • Disconnect battery connecting cord using tweezers.
      Ask FixBot
    4. Asus Padfone 2 Vibrator Replacement, Remove Internal Back Plate: step 4, image 1 of 2 Asus Padfone 2 Vibrator Replacement, Remove Internal Back Plate: step 4, image 2 of 2
      • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
      • Use of magnetic pad will help with keeping track of screws.
      • Once screws are out, remove the plate.
      Ask FixBot
    5. Asus Padfone 2 Vibrator Replacement, Removal of A68 Vibrator: step 5, image 1 of 2 Asus Padfone 2 Vibrator Replacement, Removal of A68 Vibrator: step 5, image 2 of 2
      • Use tweezers to remove motor from housing, pulling the plug downward away from the phone.
      • Use tweezers to unplug the device from the circuit board.
      Ask FixBot
2 other people completed this guide.
Zach Standridge
368 Reputation
2 Guides authored
USF Tampa, Team 5-4, Mcgee Fall 2014 Member of USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 101
All Time: 1,874
