Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Unresponsive Touchpad
The touchpad is not working or broken.
Faulty Touchpad or Physically Broken
Be sure to check if you accidentally turned off your touch pad through the Hot Key combination. Asus Eee Netbooks will use the combination of holding down the Fn key and the F3 key. If this doesn't work, the touchpad will need to be replaced.
Unresponsive Keyboard
The keyboard is not working.
Defective Keyboard
If the whole keyboard does not function, try the keyboard replacement guide here.
Keys are Missing
If the keyboard is missing keys, you can replace the keys by simply using a plastic opening tool. Push the end of the tool under one edge of the button to pop it off then replace it with a new button by snapping it into place.
Unresponsive display
The screen of your computer will not turn on.
Screen appears dead or broken
If the screen for your netbook is broken or will not appear to turn on you can first try to reload your bios by, unplugging the power adapter and removing the battery. Hold the power button for 30 seconds, reinsert the battery and plug in the power adapter.
If this does not help or your screen is broken, you can follow this guide to replace it.
Computer Won't Start
The computer does not power up.
Bios Loading Errors
Unplug the power adapter and remove the battery. Hold the power button for 30 seconds, reinsert the battery and plug in the power adapter.
Faulty Power Adapter
Make sure the power adapter is connected to the laptop and a power source. Check the adapter for an indicator light. If the light is not on, the adapter is not working and needs to be replaced.
Faulty Battery
First charge the laptop, disconnect the power adapter and turn on the laptop. If the laptop does not turn on, plug in the adapter and try again. If the laptop works the battery is is not working and needs to be replaced. This guide shows how to do so.
Overheating
The computer gets too hot and shuts itself off.
Blocked Vents
Check the vents on the laptop for any blockage and clean the vents using a can of compressed air.
Faulty Fan
If there is nothing blocking the vents, check to see if the fan is active by listening when the laptop is on. If you do not hear the fan, replace using the following guide.
Unresponsive Peripherals
Some peripherals are not working.
Blocked Ports
Check the ports for any blockage and clean the ports using a can of compressed air.
Faulty Ports
To ensure the peripheral is working, plug it into multiple ports and make sure the drivers are up to date. Check to make sure the peripheral is plugged in.
Brandon Hastings
250 Reputation
1 Guide authored
USF Tampa, Team 2-3, Nance Fall 2016 Member of USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 18
All Time: 1,340
