Asus Eee PC 1201N Cooling fan replacement
  1. Asus Eee PC 1201N Cooling fan replacement, Battery: step 1, image 1 of 1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
    Ask FixBot
  2. Asus Eee PC 1201N Cooling fan replacement: step 2, image 1 of 1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
    Ask FixBot
  3. Asus Eee PC 1201N Cooling fan replacement: step 3, image 1 of 1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
    Ask FixBot
  4. Asus Eee PC 1201N Cooling fan replacement, Keyboard: step 4, image 1 of 2 Asus Eee PC 1201N Cooling fan replacement, Keyboard: step 4, image 2 of 2
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
    Ask FixBot
  5. Asus Eee PC 1201N Cooling fan replacement: step 5, image 1 of 2 Asus Eee PC 1201N Cooling fan replacement: step 5, image 2 of 2
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
    Ask FixBot
  6. Asus Eee PC 1201N Cooling fan replacement, Cooling fan: step 6, image 1 of 1
    • Remove the eight 6.5mm screws using the J0 Phillips head screwdriver from back of the netbook.
    Ask FixBot
  7. Asus Eee PC 1201N Cooling fan replacement: step 7, image 1 of 2 Asus Eee PC 1201N Cooling fan replacement: step 7, image 2 of 2
    • Remove the ten 4.5 mm screws from cover plate using the J0 Phillips head screwdriver.
    • Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
    Ask FixBot
  8. Asus Eee PC 1201N Cooling fan replacement: step 8, image 1 of 1
    • Pull the blue tab for the touchpad connector before removing the cover plate completely.
    Ask FixBot
  9. Asus Eee PC 1201N Cooling fan replacement: step 9, image 1 of 1
    • Remove the two 4.6 mm screws from the cover plate using the J0 Phillips head screwdriver.
    Ask FixBot
  10. Asus Eee PC 1201N Cooling fan replacement: step 10, image 1 of 1
    • Unplug the connector.
    Ask FixBot
  11. Asus Eee PC 1201N Cooling fan replacement: step 11, image 1 of 1
    • Lift up and remove the fan.
    Ask FixBot
Krishna Janjanam
206 Reputation
1 Guide authored
USF Tampa, Team 2-3, Nance Fall 2016 Member of USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 19
All Time: 1,260
