Up to 20% off select tools
Asus Eee PC 1201N Display Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
23
Past 30 Days:
96
All Time:
1,278
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 50 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
A faulty display is a very possible issue people have with their computers. If yours is faulty follow this guide to replace it in your Asus Eee PC 1201N.
    1. Asus Eee PC 1201N Display Replacement, Battery: step 1, image 1 of 1
      • Flip the netbook over.
      • Be sure to unplug the netbook and power off the device while working.
      Ask FixBot
    2. Asus Eee PC 1201N Display Replacement: step 2, image 1 of 1
      • Push open both tabs on either side of the battery.
      • The tab on the left will click open and stay in place until you close it.
      Ask FixBot
    3. Asus Eee PC 1201N Display Replacement: step 3, image 1 of 1
      • Pull the tab on the right open, while you remove battery with your other hand.
      • Pull the battery straight out ensuring that you don't damage any connectors.
      Ask FixBot
    1. Asus Eee PC 1201N Display Replacement, Display: step 4, image 1 of 2 Asus Eee PC 1201N Display Replacement, Display: step 4, image 2 of 2
      • Remove the six screw on the front cover by using the plastic opening tool. Then, remove the six 4.6mm screws using the J0 Phillips head screwdriver.
      Ask FixBot
    2. Asus Eee PC 1201N Display Replacement: step 5, image 1 of 1
      • Using the plastic opening tool, separate the over from the netbook.
      Ask FixBot
    3. Asus Eee PC 1201N Display Replacement: step 6, image 1 of 1
      • You must separate the hinge cover from the cover before removing the cover.
      Ask FixBot
    4. Asus Eee PC 1201N Display Replacement: step 7, image 1 of 1
      • After removing the cover, remove the two 4.6mm screws using the J0 Phillips head screwdriver.
      Ask FixBot
    5. Asus Eee PC 1201N Display Replacement: step 8, image 1 of 1
      • There are two screws on the left and right side of the display. Remove all four 3mm screws using the J0 Phillips head to separate the LCD from the display cover.
      • The left side will have a magnet covering the bottom screw remove the magnet. Be sure to replace when reassembling.
      Ask FixBot
    6. Asus Eee PC 1201N Display Replacement: step 9, image 1 of 1
      • Pull up on the video cable on the back of the LCD display to remove it.
      Ask FixBot
2 other people completed this guide.
Author
with
Mohamed Al Mardhouf Al Saadi
145 Reputation
1 Guide authored
USF Tampa, Team 2-3, Nance Fall 2016 Member of USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 96
All Time: 1,278
