Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Asus Chromebook Flip C100PA-RBRKT07 Troubleshooting
Can't figure out your issue, use this troubleshooting page on the Asus Chromebook Flip C100PA-RBRKT07
The Laptop Will Not Power On
The laptop is not showing any signs of powering up.
The Power Adapter Is Faulty
Check to see if the power adapter is plugged in and the charge light is on. If the light is not on and the adapter is plugged in, the adapter is faulty, Consider purchasing a replacement adapter.
The Battery Is Faulty
If the light of the adapter is on, check to see if the adapter is connected to the laptop. If the laptop only powers on when the adapter is plugged in, regardless of charging time, then the battery is faulty. Replace the battery Asus Chromebook Flip C100P Battery Replacement.
The Power Button Is Broken
If the above resolution has not fixed the issue the problem could be the power button is faulty. Replace the button Asus Chromebook Flip C100P Power and Volume Buttons Replacement, the guide includes volume but that section is not needed for fixing this problem.
The Laptop Is Not Charging when Plugged in
The laptop is not showing signs or charging despite being plugged into a power adapter.
The Charging Hole Is Blocked
Check to see if the charging port on the Chromebook is clean inside. If the item is large enough to remove, take a pair of plastic tweezers and remove the object. If there is dirt on either the charger or inside the port, that could be blocking your power source. Clean them using compressed air (i.e. air dusters, keyboard cleaners) and once clean check to see if they work. If this does not fix your problem try another one.
If the light of the adapter is on, check to see if the adapter is connected to the laptop. If the laptop only powers on when the adapter is plugged in, regardless of charging time, then the battery is faulty. Replace the battery iBook G3 12" Display Replacement
The Laptop Touchscreen Is Not Responding
After furiously tapping on the screen, it is still unresponsive.
The Screen Needs to Be Cleaned
Use a clean, soft microfiber cloth to clean the screen. If this does not help, lightly damp the cloth and clean the screen.
The Laptop Needs to Be Restarted
Press and hold the power button on your laptop until the laptop powers down and turn it on or use the mouse pad to select the restart option. Once turned on, check to see if the screen is responsive using your finger. If this does not fix your problem, try another one.
The Screen Is Faulty
If the screen does not respond after using the previous steps, then the screen is faulty. Replace the screen.
The Keyboard Is Not Responding
Typing on the keyboard does nothing.
There Is Dirt or Residue Buildup
When the key is pressed down and there is a crunching sound, there may be crumbs stuck under the keys. Use a cotton swab or a can of compressed air to remove the crumbs. If that fails, gently remove the key by lifting it up and away from the keyboard. After, remove the crumbs under the key. Gently press the key back into place when finished.
The Drivers Are Corrupted
If the keyboard is not working, you can update or reinstall the keyboard drivers. By going to the Control Panel, and clicking Device Manager, you will have the option to update the drivers or uninstall then reinstall drivers. Both of these options require internet connection.
The Key Is Bad
If one or two keys on the keyboard does not work, they need to be replaced.
The Keyboard Is Broken or Malfunctioning
The keyboard may be physically damaged by spilling liquid over the keys. If a majority of the keys are unresponsive, replace the keyboard iBook G3 12" Display Replacement.
The Laptop Has a Virus
If your browser is slow and your keyboard is taking a while to respond, there is a high chance you have a virus. To remove have a hard factory reset.
The Audio Port Is Not Responding
Still can’t listen to your favorite song...
The Audio Jack Is Dirty Inside
Check to see if the audio port on the Chromebook is clean inside. If there is dirt on either the audio jack or inside the port, that could be blocking your power source. Clean them using compressed air (i.e. air dusters, keyboard cleaners) and once clean check to see if they work. If this does not fix your problem try another solution.
The Audio Jack Is Faulty
If the audio port doesn’t successfully connect to a speaker using an audio jack, when both the laptop and speaker are turned on, a replacement may be needed.
The Headphones have Connection Issues
Test that your own headphones are not the cause of this problem by plugging them into another device. If they do not work, we recommend buying yourself a new pair of headphones.
The USB-Port Is Not Functioning Properly
Laptop doesn’t recognize devices through the USB port.
The USB Port Is Dirty Inside
Dust and debris can enter the port through repeated use. Clean the port using compressed air (i.e. air dusters, keyboard cleaners) and once clean check to see if it works. If this does not fix your problem try another one.
The Laptop Is Not Updated
Occasionally, the software that is installed doesn’t allow the computer to properly recognize the devices connected to the USB port. Check for updates and restart the laptop.
The Connected Wire Is Faulty
The wire is being used to connect to the laptop may be damaged and must be replaced to ensure a safe connection between two devices.
The USB Port Is Faulty
The USB port may not be working and needs to be replaced. Follow the guide to properly replace the damaged USB port. HP Chromebook 14-Q010DX USB/SD card Replacement. Be sure to just replace the USB port.
Author
with
Tomas Martinez
185 Reputation
1 Guide authored
Cal Poly, Team S19-G4, White Winter 2019 Member of Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 1,269
