Up to 20% off select tools
HP Chromebook 14-Q010DX USB/SD card Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
87
All Time:
1,077
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide requires the removal of 1x5mm screws on the USB/SD card assembly.
    1. HP Chromebook 14-Q010DX USB/SD card Replacement, Keyboard and Touchpad: step 1, image 1 of 2 HP Chromebook 14-Q010DX USB/SD card Replacement, Keyboard and Touchpad: step 1, image 2 of 2
      • Flip the laptop so the base of the laptop is facing you.
      • Using the #00 screwdriver, unscrew the 13 screws.
      Ask FixBot
    2. HP Chromebook 14-Q010DX USB/SD card Replacement: step 2, image 1 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement: step 2, image 2 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement: step 2, image 3 of 3
      • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
      • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
      Ask FixBot
    3. HP Chromebook 14-Q010DX USB/SD card Replacement: step 3, image 1 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement: step 3, image 2 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement: step 3, image 3 of 3
      • Warning! Handle the flaps and ribbon cables with care to prevent damage.
      • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
      • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
      • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
      Ask FixBot
    4. HP Chromebook 14-Q010DX USB/SD card Replacement: step 4, image 1 of 1
      • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
      • The tape has no function other than to keep the wire tucked away.
      Ask FixBot
    5. HP Chromebook 14-Q010DX USB/SD card Replacement: step 5, image 1 of 1
      • Set aside the detached keyboard.
      Ask FixBot
    1. HP Chromebook 14-Q010DX USB/SD card Replacement, Speaker: step 6, image 1 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement, Speaker: step 6, image 2 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement, Speaker: step 6, image 3 of 3
      • Undo the black tape located on the bottom from the frame of the laptop.
      • Using fingers or the spudger, slide out the black connector indicated on the left.
      • Use a #00 screwdriver to remove the two screws.
      Ask FixBot
    2. HP Chromebook 14-Q010DX USB/SD card Replacement: step 7, image 1 of 2 HP Chromebook 14-Q010DX USB/SD card Replacement: step 7, image 2 of 2
      • Gently remove the speakers.
      Ask FixBot
    1. HP Chromebook 14-Q010DX USB/SD card Replacement, Battery: step 8, image 1 of 2 HP Chromebook 14-Q010DX USB/SD card Replacement, Battery: step 8, image 2 of 2
      • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
      • Lift the black flaps and gently pull the strip out.
      • Set the strip aside.
      Ask FixBot
    2. HP Chromebook 14-Q010DX USB/SD card Replacement: step 9, image 1 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement: step 9, image 2 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement: step 9, image 3 of 3
      • Remove the screw.
      • Use your fingers to pull the white tab out of the black slot above the battery.
      Ask FixBot
    3. HP Chromebook 14-Q010DX USB/SD card Replacement: step 10, image 1 of 1
      • Gently remove battery.
      Ask FixBot
    1. HP Chromebook 14-Q010DX USB/SD card Replacement, USB/SD card: step 11, image 1 of 2 HP Chromebook 14-Q010DX USB/SD card Replacement, USB/SD card: step 11, image 2 of 2
      • Remove screw indicated by the red circle at the top of the card port.
      Ask FixBot
    2. HP Chromebook 14-Q010DX USB/SD card Replacement: step 12, image 1 of 1
      • Gently remove the USB/SD card port.
      Ask FixBot
Author
with
Kevin Piper
1,602 Reputation
6 Guides authored
USF Tampa, Team 17-2, Watkins Winter 2015 Member of USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 87
All Time: 1,077
