Asus Chromebook Flip C100P Battery Replacement
    1. Asus Chromebook Flip C100P Battery Replacement, Lower Case: step 1, image 1 of 1
      • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
      • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
      Ask FixBot
    2. Asus Chromebook Flip C100P Battery Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to remove the four bottom rubber feet.
      Ask FixBot
    3. Asus Chromebook Flip C100P Battery Replacement: step 3, image 1 of 1
      • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
      Ask FixBot
    4. Asus Chromebook Flip C100P Battery Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to pry up the palm rest assembly.
      Ask FixBot
    5. Asus Chromebook Flip C100P Battery Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Disconnect the two cables from the motherboard with tweezers
      Ask FixBot
    1. Asus Chromebook Flip C100P Battery Replacement, Battery: step 6, image 1 of 1
      • Unscrew the four J1 Screws of the Audio Cards
      Ask FixBot
    2. Asus Chromebook Flip C100P Battery Replacement: step 7, image 1 of 1
      • Unscrew the three Battery Screws by using a screwdriver with a J00 tip.
      Ask FixBot
    3. Asus Chromebook Flip C100P Battery Replacement: step 8, image 1 of 1
      • Lift the battery cable out of Mother Board
      Ask FixBot
To reassemble your device and complete the battery replacement, please follow these instructions in reverse order.
12 other people completed this guide.
2 Guide Comments
The difficulty rating should be higher. The sound card does not need to be removed, but this is not mentioned. I only noticed it from the next picture. Reattaching the keyboard cable is very difficult; a hint with tips would help.
Chas Hofmeister - Reply Share
I had to searched high and low for this but I'm glad I found this site. Thanks for a great how-to, well done. I wish other sites were a clear and concise.
Eugene Carroll - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 55
All Time: 12,494
