Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Video is blurry
Video is out of focus, or there is something obstructing the field of view.
The mechanical focus motor is burned out
If your mechanical focus motor is burnt out or defective you will need to replace it.
The mechanical focus motor is unplugged from the camera
If the mechanical focus motor is unplugged, the video will be stuck at a certain depth of focus. To fix this problem follow the camera lens replacement guide, but instead of replacing the lens at the last step, simply ensure that the focus motor cable is firmly attached to the circuit board receptacle.
The camera lens may be scratched or otherwise damaged
If your lens is damaged, you will need to replace it. To do so follow these steps.
Battery will not hold a charge
The camera battery is not holding a charge, or will not charge when plugged in to the magnetic charger.
The batteries are too cold
Arlo batteries have a built-in safety feature where if the temperature drops below freezing (32 F or 0 C), the battery will not charge. Bring the battery inside to charge where it is warmer.
The charging cable has failed
Make sure you are using the magnetic charging cable that came with the camera; these are more powerful than the average USB charger cable. Charge for ten minutes, and check the battery status on your Arlo App.
The battery charge has dropped too low
Arlo batteries can have a weird issue where if the charge is allowed to drop too low, it takes several tries to bring the battery back to functionality. Fully charge the battery up to five times and the battery should work again.
Battery Failure
At a certain point the battery may come to the end of its lifecycle. At this point you will need to replace the battery.
Spotlight won't turn on
The camera spotlight won't turn on automatically (at night) or manually via the Arlo app.
Your settings within the Arlo app aren't configured properly
Follow this troubleshooting guide from Arlo for instructions on how to set up your spotlight settings.
The spotlight flex cable connector is unplugged or loose within the camera
If this is the case, follow the steps for replacing the spotlight flex circuit board, but instead of replacing it, simply ensure that the flex cable connector is firmly attached to the circuit board receptacle.
The spotlight LED is burned out
If your spotlight LED is burnt out or defective, follow the replacement guide.
Camera doesn't store footage
Video footage is not found in the Arlo app video Library, even when actively recording.
Battery Failure
Remove the battery from the camera, wait 15 seconds, and put the battery back in. Turn the camera back on and test the video.
The Device Needs a Factory Reset
Take off the white camera enclosure, and find the factory reset button located on the bottom of the camera. It is a small round black button located next to the three charger terminals. Press and hold this button for 15 seconds, and the camera will factory reset.
Helpful link: Arlo Support, "Why are there no recordings in the Arlo Library?"
Sound distortion through speaker
When talking through the speaker or when playing the siren, the sound is distorted or inaudible.
The speaker cable is loose or disconnected
If this is the case, follow the steps for replacing the speaker unit, but instead of replacing it, simply ensure that the cable from the speaker is firmly attached to the circuit board receptacle.
Speaker failure
If your speaker is burnt out or defective then follow the replacement guide.
Author
with
Madeleine Kennedy
334 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 31
All Time: 2,230
