Arlo Ultra 2 Spotlight Replacement
    1. Arlo Ultra 2 Spotlight Replacement, Battery: step 1, image 1 of 2 Arlo Ultra 2 Spotlight Replacement, Battery: step 1, image 2 of 2
      • Press the button on the bottom of the camera to release the housing.
      • Pull the white housing off the camera.
      Ask FixBot
    2. Arlo Ultra 2 Spotlight Replacement: step 2, image 1 of 1
      • Pull the white cube shaped battery from the back to remove it from camera.
      Ask FixBot
    1. Arlo Ultra 2 Spotlight Replacement, Spotlight: step 3, image 1 of 2 Arlo Ultra 2 Spotlight Replacement, Spotlight: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity.
      Ask FixBot
    2. Arlo Ultra 2 Spotlight Replacement: step 4, image 1 of 2 Arlo Ultra 2 Spotlight Replacement: step 4, image 2 of 2
      • Use a spudger to loosen and remove the camera faceplate.
      Ask FixBot
    3. Arlo Ultra 2 Spotlight Replacement: step 5, image 1 of 2 Arlo Ultra 2 Spotlight Replacement: step 5, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two 4.00 mm black screws located across from each other above the camera lens.
      Ask FixBot
    4. Arlo Ultra 2 Spotlight Replacement: step 6, image 1 of 2 Arlo Ultra 2 Spotlight Replacement: step 6, image 2 of 2
      • Use a spudger or your fingernail to flip up the small locking flap on the ZIF connector. Then, you can safely pull the cable out.
      • The cable is very short and you will see it when removing the circuit board.
      Ask FixBot
    5. Arlo Ultra 2 Spotlight Replacement: step 7, image 1 of 2 Arlo Ultra 2 Spotlight Replacement: step 7, image 2 of 2
      • Use a spudger to gently pry the green circuit board away from the case.
      • Remove the green circuit board. This is your spotlight.
      Ask FixBot
2 other people completed this guide.
3 Guide Comments
Great tutorial, very helpful. A suggestion however would be to also offer for sale or add links to where the replacement components can be purchased. In this instance I could not find a replacement spotlight and had to buy a donor camera. Thanks
Gareth - Reply Share
Where can I buy a new spotlight for this camera?
Thomas Sanderhoff - Reply Share
Thanks a lot. Took the LED from an old dead Ultra camera and it worked flawlessly.
Kristoffer - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 448
