Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
No Standby LED When the Apple TV 4K Plugged In
There is no standby LED light turned on when the Apple TV is plugged in.
Faulty Power Supply
The Apple TV not turning on may be the result of the power supply being faulty. If the power cord is plugged in but you are seeing no light on the Apple TV itself, the power supply may need to be replaced. Follow this guide explaining how to replace the power supply.
Damaged Power Connector
Your power connector may be damaged in some way preventing your Apple TV from turning on when plugged in. Repairing/replacing the power connector may be needed.
No Displayed Image
Your Apple TV turns on, but does not give a display output.
Incorrect Input Source Being Used
After having connected your Apple TV to your TV using the HDMI cable and making sure that the Apple TV itself is plugged in, your TV may not be set to the proper input source which will keep you from seeing any image on your display. You'll want to make sure to change the input source to the matching HDMI port that the Apple TV is plugged in to.
Bad HDMI cable
Try using your HDMI cable on a different device. If it works on a different device your HDMI cable my be bad.
Damaged Logic Board
It's possible that the logic board in your Apple TV is damaged so the device doesn't function properly. If this is the case, follow this guide explaining how to replace the logic board.
Poor Battery Life on Apple TV Remote
Your remote doesn't seem to hold a charge well.
Damaged Charge Port
If your Apple TV Remote is plugged in and should be charging, but there is no visible light coming from the device, the charging port may be damaged and need to be replaced. You will want to inspect your charging port for physical damage such as bent prongs or an irregular fit with your lightning cable.
Faulty Battery
It is possible that if your Apple TV Remote loses charge quickly, even after it has been charging for a while, the battery may be faulty. The Apple TV Remote uses a rechargeable battery, so the replacement may be a bit more difficult but still doable. Replace the battery using this guide.
Apple TV Remote is Unresponsive
The buttons on your remote appear to be unresponsive.
Damaged Logic Board
If the Apple TV Remote doesn't respond to your button clicks, a damaged logic board could be the cause. Follow this guide to replace the logic board.
Author
with
Milo McCabe
179 Reputation
0 Guides authored
UW Stout, Team S6-G3, Ogden Fall 2018 Member of UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 Members
60 Guides authored
5 Comments
Display has width black ban and brink when Apple TV get warm. only happens when use Apple TV . Not other input. Any help.
Ming Lau - Reply Share
Necesito comprar solo el control, se me extravío en una mudanza, hace ya varios meses y no lo encontré, cómo puedo comprarlo?
JIMENA PATRICIA ARAYA SÁNCHEZ - Reply Share
Se agradece cualquier información de donde lo pueda adquirir o si existe uno universal.
Necesito comprar control remoto universal para apple tv, existe???
The light on the front of the apple TV is flashing quickly and it won't turn on. Does anyone know what's causing this? and can it be fixed?
rb - Reply Share
Past 24 Hours: 8
Past 7 Days: 65
Past 30 Days: 309
All Time: 22,893
