Apple TV 4K Logic Board Replacement
    1. Apple TV 4K Logic Board Replacement, Logic Board: step 1, image 1 of 1
      • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
      • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
      Ask FixBot
    2. Apple TV 4K Logic Board Replacement: step 2, image 1 of 2 Apple TV 4K Logic Board Replacement: step 2, image 2 of 2
      • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
      • Four 10 mm screws
      • Lift and remove the heat sink assembly from the device.
      Ask FixBot
    3. Apple TV 4K Logic Board Replacement: step 3, image 1 of 2 Apple TV 4K Logic Board Replacement: step 3, image 2 of 2
      • Use plastic spudger to pull up on all three antenna connectors to remove them.
      • Remove rubber piece from front side of device.
      Ask FixBot
    4. Apple TV 4K Logic Board Replacement: step 4, image 1 of 1
      • Unscrew the following screws holding the logic board in place using the T7 Torx:
      • Two black 3 mm screws
      • Two silver 4 mm screws
      Ask FixBot
    5. Apple TV 4K Logic Board Replacement: step 5, image 1 of 3 Apple TV 4K Logic Board Replacement: step 5, image 2 of 3 Apple TV 4K Logic Board Replacement: step 5, image 3 of 3
      • Use a spudger to pry up logic board. Try lifting it up from the front side.
      • Remove logic board and set aside.
      Ask FixBot
10 other people completed this guide.
Keenan Barber
1,367 Reputation
3 Guides authored
UW Stout, Team S6-G3, Ogden Fall 2018 Member of UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 Members
60 Guides authored
9 Guide Comments
Where does one get a new logic board??
MP94025 - Reply Share
Any idea on where I can purchase. new logic board?
tylerchumchal - Reply Share
Where do you buy the board…….
Andy Grichtmeier - Reply Share
Good job on showing how to remove and replace logic board. Now as the other three commentators have asked
, where can you buy another one or is an exercise in futility
Kanehoe - Reply Share
Hm. Has anyone’s Apple TV 4k logic board failed?
oTWR - Reply Share
Past 24 Hours: 8
Past 7 Days: 43
Past 30 Days: 203
All Time: 11,835
