Apple TV 4K Remote Logic Board Replacement
    1. Apple TV 4K Remote Logic Board Replacement, Remote Logic Board: step 1, image 1 of 1
      • Heat iOpener according to manufacturer's instructions.
      • Place over the face of the remote to soften the adhesive under the glass.
      Ask FixBot
    2. Apple TV 4K Remote Logic Board Replacement: step 2, image 1 of 2 Apple TV 4K Remote Logic Board Replacement: step 2, image 2 of 2
      • Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
      Ask FixBot
    3. Apple TV 4K Remote Logic Board Replacement: step 3, image 1 of 1
      • Push front face forward to disengage plastic clips at the top of the remote.
      Ask FixBot
    4. Apple TV 4K Remote Logic Board Replacement: step 4, image 1 of 2 Apple TV 4K Remote Logic Board Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Unlatch the connector that binds the touch screen and logic board.
      • Afterwards, use tweezers to detach the connector that binds the touch screen to the logic board.
      Ask FixBot
    5. Apple TV 4K Remote Logic Board Replacement: step 5, image 1 of 1
      • Lift the face from the body of the remote.
      Ask FixBot
    6. Apple TV 4K Remote Logic Board Replacement: step 6, image 1 of 2 Apple TV 4K Remote Logic Board Replacement: step 6, image 2 of 2
      • Lift the latch holding back the connector to the battery.
      • Use tweezers to disconnect the battery connector.
      Ask FixBot
    7. Apple TV 4K Remote Logic Board Replacement: step 7, image 1 of 1
      • Remove the following screws using a T3 Torx screwdriver:
      • Eight 2mm screws
      Ask FixBot
    8. Apple TV 4K Remote Logic Board Replacement: step 8, image 1 of 1
      • Using a plastic spudger, gently remove the logic board from the case of the remote.
      Ask FixBot
4 other people completed this guide.
Keenan Barber
1,367 Reputation
3 Guides authored
UW Stout, Team S6-G3, Ogden Fall 2018 Member of UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 Members
60 Guides authored
2 Guide Comments
Have you ever successfully reconnected the ribbon cable after disassembly? It seems nearly impossible to do by hand…
B R - Reply Share
I can’t find replacement adhesive that fits. How are people getting this thing to stick back together when you’re done??
Jeremy - Reply Share
Past 24 Hours: 6
Past 7 Days: 45
Past 30 Days: 232
All Time: 10,057
