Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Audio Problems
You have trouble listening to sounds on your computer.
Volume Controls
It’s a common mistake that is made. Check your sound icon and raise the volume bar to a higher level if it’s very low. Also, when watching videos and listening to music check that the volume bar in the application is heightened too.
Laptop Has Been on Too Long
Laptops develop strange issues when they’re on for too long. Restarting your laptop will refresh your device and clear up most issues like audio problems.
Faulty Driver
If you have a hard time listening to any sounds through your laptop speaker, or if your audio is distorted, this might be a result of having a faulty driver. You can check this by going to the Device Manager and then click on the Sound, video and game controllers. The Device Manager will tell you the manufacturer and model. If there is a yellow or red exclamation point next to the sound device this probably means you’re missing a driver and will have to find and download the latest drivers for your version of Windows. To install the driver, you can go to: http://www.acer.com/.
Microphone Not Working
No voice recording or output.
External Cable Connections
If you can’t record your voice into your laptop you should check which cable port you’re plugged into. Make sure external cable connections for recording is plugged into the microphone port.
Internal microphone
If it is an internal problem with your built-in microphone, updating your driver for your microphone will solve this problem.
Loose Headphone Jack
If your audio cuts in and out or is distorted in any way, this is usually a sign of having a loose headphone jack. Inserting the jack fully into the computer can solve this issue. If the jack is fully inserted and problems are still occurring, then your microphone itself may be faulty.
Problems with Wireless Connection
The netbook will not detect or connect to wireless connections.
Wireless Button
Check if the wireless button is actually on. Users inadvertently turn this button off and don’t realize it. This button is usually above the keyboard.
Wireless Connection
If you think there is an issue with the connection you're using, try to connect to that same connection with a different device. If the other device works well on that connection, then the wireless connection is not the problem.
Router Settings
Check the router setting of the Acer Aspire One 722. Make sure that you have the DHCP (Dynamic Host Configuration Protocol) turned on and don’t have the mac filtering on. This can mess up the connection between your wireless connection and this device.
Router Type
The router type factors when it comes to the Acer Aspire One 722 wireless connection. A D-Link router doesn’t blend well with this device. This router tends to think that this device is still broadcasting and that kills wireless connection.
Acer Wireless Drivers
If the wireless connection is fine, and there is nothing wrong with the router type or settings, than the problem is most likely your Acer Wireless Drivers. Drivers need to be kept up- to-date and if they’re not then they become damaged. To manually install your updated Driver you can go to http://www.acer.com/ and find and download the missing Drivers that your laptop needs. The website may give you instructions to help guide you with your installation.
Black Screen Issue
The netbook is on and fan is running but the screen displays a blank black screen.
Display Brightness Settings
If the screen appears to be off, the brightness might be set to its lowest setting. Adjust the brightness settings by pressing Fn+left arrow key to increase the brightness. If this does not fix the brightness, adjust the display with the Fn+F6 key; this will switch the screen display from sleep to awake.
BIOS Update
If your netbook screen remains black after turning it on, you will need to update or reload BIOS system settings. To reload bios simply press the key combo “F2 + F9 + F10+Y,” or to update the system visit the company’s website on http://us.acer.com/ac/en/US/content/driv... . This will allow you to download the recent version of the model into an USB drive so it can be used in your defective device. Note: this should be your last resort to fixing your black screen issue since upgrading your system BIOS incorrectly could harm your Acer Product.
Screen is Cracked or Dented
If the notebook has cracks or dents on the screen, consider replacing the screen by using the guide on how to replace the screen.
Faulty Motherboard
A blank black screen can be caused by an internal hardware malfunction. Consider replacing the bridge that connects the motherboard to SD card reader, to strengthen the connection. Dismantle the top and bottom part of the laptop. Disconnect the bridge component that connects the motherboard and the right side board of the laptop, and replace the board.
Netbook Will Not Turn On
Netbook will not power on.
Faulty Power Button
If not light is displayed on the power button, you may have a loose connection. At times, the power button might get stuck at a certain position and prevents it from creating a connection with the device. One way of fixing the problem is by replacing the button.
Problems with the Power Adapter
Securely plug in the adapter, and look for signs that he adapter is receiving electricity. One of these signs will be a light turning on , this indicates that the adapter works. If this sign is not received, your adapter is faulty. A faulty adapter will lead to the behavior experienced, consider replacing your adapter.
Faulty Battery
Check that the adapter is plugged in, and the light on the adapter is on. If the netbook only powers up when the adapter is plugged in, then the battery is faulty. Remove the Acer battery by following this guide.
Author
with
Christian Barboza
824 Reputation
5 Guides authored
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
3 Members
60 Guides authored
1 Comment
Please problems computer
Md noorul Amin - Reply Share
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 33
All Time: 4,915
