Acer Aspire One 722 Screen Replacement
    1. Acer Aspire One 722 Screen Replacement, Battery: step 1, image 1 of 1
      • Power down the netbook by pressing the power button on the top left corner.
      Ask FixBot
    2. Acer Aspire One 722 Screen Replacement: step 2, image 1 of 1
      • Close the netbook and flip it over so that the back is facing up.
      Ask FixBot
    3. Acer Aspire One 722 Screen Replacement: step 3, image 1 of 1
      • Slide the button below the battery to the right while simultaneously pulling the battery out.
      Ask FixBot
    4. Acer Aspire One 722 Screen Replacement: step 4, image 1 of 2 Acer Aspire One 722 Screen Replacement: step 4, image 2 of 2
      • If necessary, remove the old battery and replace it with a new one.
      Ask FixBot
    5. Acer Aspire One 722 Screen Replacement: step 5, image 1 of 1
      • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
      Ask FixBot
    1. Acer Aspire One 722 Screen Replacement, Screen: step 6, image 1 of 2 Acer Aspire One 722 Screen Replacement, Screen: step 6, image 2 of 2
      • Remove the black rubber clips from the bottom right and left of the netbook screen.
      Ask FixBot
    2. Acer Aspire One 722 Screen Replacement: step 7, image 1 of 2 Acer Aspire One 722 Screen Replacement: step 7, image 2 of 2
      • Remove the screws under the black caps.
      Ask FixBot
    3. Acer Aspire One 722 Screen Replacement: step 8, image 1 of 3 Acer Aspire One 722 Screen Replacement: step 8, image 2 of 3 Acer Aspire One 722 Screen Replacement: step 8, image 3 of 3
      • Slowly separate the screen casing from the screen.
      • Potential for device damage: Be careful when detaching the screen casing from the screen. If not done slowly, it can break.
      Ask FixBot
    4. Acer Aspire One 722 Screen Replacement: step 9, image 1 of 3 Acer Aspire One 722 Screen Replacement: step 9, image 2 of 3 Acer Aspire One 722 Screen Replacement: step 9, image 3 of 3
      • Remove the screws located on the four corners of the screen.
      Ask FixBot
    5. Acer Aspire One 722 Screen Replacement: step 10, image 1 of 3 Acer Aspire One 722 Screen Replacement: step 10, image 2 of 3 Acer Aspire One 722 Screen Replacement: step 10, image 3 of 3
      • Remove the two bottom screws.
      • Taking out these screws will allow you to remove the screen from its attachment.
      Ask FixBot
    6. Acer Aspire One 722 Screen Replacement: step 11, image 1 of 3 Acer Aspire One 722 Screen Replacement: step 11, image 2 of 3 Acer Aspire One 722 Screen Replacement: step 11, image 3 of 3
      • On the bottom left of the screen there is a cord attached. Remove the tape that is attached to the screen.
      Ask FixBot
    7. Acer Aspire One 722 Screen Replacement: step 12, image 1 of 3 Acer Aspire One 722 Screen Replacement: step 12, image 2 of 3 Acer Aspire One 722 Screen Replacement: step 12, image 3 of 3
      • On the green board, remove the two screws.
      • Remove the board.
      Ask FixBot
4 other people completed this guide.
Christian Barboza
824 Reputation
5 Guides authored
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 3,819
