Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Slow Start-up Time
Start-up and loading pages take much longer than expected.
Too Many Tabs Open
Having too many tabs open in a Web browser could cause your computer to run slowly. Try closing extra browser tabs, or any that you aren’t using. You can do this by clicking the “x” on the end of the tab.
Too Many Apps Open
Similarly, your computer may be running slowly if you have too many applications open at one time. Try closing any extra or unneeded programs. You can do this by clicking the red button or “x” in the upper corner of the program window.
Full SSD
A full SSD is a common reason computers will run slowly. To clear up some extra space, simply search “uninstall” in your start bar, and click on the application suggested for this search. In this application, there should be a list of programs. Choose some of these that you do not need or use often, then click on the chosen application and click "Uninstall". This will open a program to assist you in uninstalling the chosen apps.
Windows Needs Updating
Outdated software can cause your computer to run slowly. Try updating Windows and this may help. To do this, select Start (in the bottom left corner of your screen), then Settings, and Windows Update. Click this and run the update. It will take a moment, but this will install and restart your computer with the latest version of Windows.
RAM Upgrade Needed
A bad RAM can be the reason a computer is running poorly. A replacement may be required. See the Ram Replacement Guide for a tutorial on how to replace your own RAM.
Laptop is Not Charging
The laptop charges slowly, or does not charge while plugged in.
Loose Connection
Try checking all electrical connections, the charging jack, the power adapter, and the wall plug.
Cord is Faulty
Make sure that you are using the correct kind of power cord and adapter for your computer. Also, try plugging the cord into different outlets and devices. If it doesn't work with any of these, then the issue is with the cord and not the computer.
Battery is Faulty
Your computer’s battery will sometimes fail, preventing your computer from holding power like it used to or charging sufficiently. Your battery may need to be replaced. See Battery Replacement replacement guide for a tutorial on how to do this.
Power Adapter is Faulty
The power adapter may go bad over time, and could be causing your computer to charge slowly. This may need to be replaced.
Charging Port is Faulty
Charging ports are another item that is prone to wear and may go bad over time. If your computer is not charging when plugged in, or charges intermittently, then a charging port replacement may solve this issue.
Overheating
The computer is hot to the touch, or is making loud whirling noises.
Laptop Exposure to Heat
Make sure to keep your laptop out of the sun. Leaving or using your computer out in the sun will raise its internal temperature.
Lack of Airflow
A common cause of overheating is a lack of airflow through your device. This is often caused by having your computer on a soft surface, such as a pillow or blanket. Try placing your device on a hard, flat surface such as a book or table instead.
Changes in Power Settings
Changing a few items in Windows Settings may be all that's needed to fix this issue. Try lowering the screen brightness. You can also set the Power Plan settings to "Balanced", and the System Cooling Policy for Plugged in to "Active". All of these items can be found by searching in Settings.
Clogged Fan
A clogged can is another common issue that causes overheating. This often happens when hair, dust, and other debris accumulate inside the cooling fan. Unscrewing and removing the laptop's bottom panel will allow you to access the cooling fan and clean it out. Simply screw the bottom panel back into place once the fan is clean.
Battery is Faulty
A bad battery can cause your computer to overheat. Old or degraded batteries will often put off too much heat while charging or during use, causing your device to overheat. Check if your battery is producing excess heat, and replace it if necessary. See Battery Replacement repair guide for a tutorial on how to do this.
Laptop Won’t Turn On
The laptop doesn’t turn on when the power button is pressed.
Screen is Turned Off or Low
It may be that low brightness is causing the screen to seem unresponsive. Try pressing the FN + F6 buttons to turn up your screen’s brightness.
Laptop Needs to be Restarted
Try pressing and holding down the Power button down for at least 30 seconds, then restart your computer.
Laptop Overheated
If a computer overheats, it may shut down and not boot properly afterward. Start by making sure that the cooling vents on your laptop are clean and not being blocked. Then, see the “Overheating” section of this guide.
Check to see if your computer is charging. A red light near the power connector will show that your computer battery is dead and needs to be charged. Try plugging your laptop in, and see if the charging light turns on.
External Devices are Interfering
Be sure to disconnect your laptop from any docking stations, disk drives, USB devices, or other external devices. Even if this doesn’t solve the problem, it will make for a smoother troubleshooting process.
No Sound is Playing
No sound comes from the speakers when it is played on the laptop—e.g. music or videos.
Changes in Sound Settings
Often, when there is no sound coming from the speakers on the laptop, the issue may simply be solved by changing the sound settings. You can do this to by clicking on the sound icon next to the clock, to make sure the sound is not muted, and then adjusting the volume level.
Connected Headphones or Bluetooth Devices
Make sure there are no headphones or external speakers plugged into your laptop. Next, search “Bluetooth” in Settings, and make sure that there are no Bluetooth speakers or headphones connected.
Low Battery
Sometimes, your computer can stop producing sound as a means of conserving battery life. Connect it to a power source and see if the problem resolves.
Faulty Speakers
Make sure that your speakers haven't been damaged. They may need to be replaced, in which case, you can follow the Speaker Replacement Guide for this device.
Damaged or Outdated Audio Driver
If an audio driver is damaged or outdated, it can cause disruptions to the operation of sound across the laptop. You may need to download a new one. To do this, click “Service and Support” on the Acer website. Click "Driver "Download" in the left corner of the screen. Next, select your computer’s exact make and model and download the audio driver. All that you have to do now is double-click the downloaded file to open it and follow its prompts.
Mykah Green
57 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 42
All Time: 1,119
