Acer Aspire 5 A515-46-R3UB RAM Replacement
    1. Acer Aspire 5 A515-46-R3UB RAM Replacement, Battery: step 1, image 1 of 2 Acer Aspire 5 A515-46-R3UB RAM Replacement, Battery: step 1, image 2 of 2
      • Use a JIS #1 screwdriver to remove eleven 6.7 mm screws from the bottom cover.
      Ask FixBot
    2. Acer Aspire 5 A515-46-R3UB RAM Replacement: step 2, image 1 of 2 Acer Aspire 5 A515-46-R3UB RAM Replacement: step 2, image 2 of 2
      • Use an opening tool and picks to pry the bottom cover from the laptop.
      • Work your way around the perimeter of the bottom cover, releasing any clips before you remove the bottom case.
      • Remove the bottom case.
      Ask FixBot
    3. Acer Aspire 5 A515-46-R3UB RAM Replacement: step 3, image 1 of 2 Acer Aspire 5 A515-46-R3UB RAM Replacement: step 3, image 2 of 2
      • Remove the two pieces of tape from the battery and the battery connector.
      • Save the tape for reassembly.
      Ask FixBot
    4. Acer Aspire 5 A515-46-R3UB RAM Replacement: step 4, image 1 of 2 Acer Aspire 5 A515-46-R3UB RAM Replacement: step 4, image 2 of 2
      • Use the plastic opening tool to carefully push on each side of the connector and remove it from the socket.
      Ask FixBot
    5. Acer Aspire 5 A515-46-R3UB RAM Replacement: step 5, image 1 of 2 Acer Aspire 5 A515-46-R3UB RAM Replacement: step 5, image 2 of 2
      • Lift up the battery and remove it from the bottom case of the laptop.
      Ask FixBot
    1. Acer Aspire 5 A515-46-R3UB RAM Replacement, RAM: step 6, image 1 of 2 Acer Aspire 5 A515-46-R3UB RAM Replacement, RAM: step 6, image 2 of 2
      • After opening the computer case, remove the RAM device from its slot as indicated in the photos.
      • Insert upgraded RAM into this slot.
      • Repeat the steps in reverse order to reassemble the computer.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 102
All Time: 1,120
