PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets
    1. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets, Cuff Buckle: step 1, image 1 of 1
      • Place the skate on a flat surface.
      Ask FixBot
    2. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 2, image 1 of 2 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 2, image 2 of 2
      • Locate the rivets on each side of the cuff buckle.
      • There should be 3 rivets in total.
      Ask FixBot
    3. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 3, image 1 of 3 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 3, image 2 of 3 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 3, image 3 of 3
      • Insert Pozidriv PZ2 screwdriver into the back of each rivet and twist until the rivet is shaved down enough to pop out. Repeat as needed.
      • Apply heavy pressure.
      • If there are issues removing rivets, use a power drill with an 11/32 inch bit.
      • If using a power drill for this process, avoid loose clothing, and tie back hair. Wear safety goggles for additional protection.
      Ask FixBot
    4. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 4, image 1 of 1
      • Stripping the rivets will produce metal shavings and dust. Use caution and dispose of them in the trash.
      Ask FixBot
    5. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 5, image 1 of 1
      • Remove the plastic part of the cuff buckle with the attached cuff and discard.
      Ask FixBot
    6. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 6, image 1 of 2 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 6, image 2 of 2
      • Your skate will look like this once they are removed. There are two ways to attach the new cuff buckle:
      • If your new cuff buckle comes with rivets, please use this guide.
      • If your new cuff buckle comes with screws, please use this guide.
      Ask FixBot
    1. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets, Cuff Buckle With Rivets: step 7, image 1 of 1
      Ask FixBot
    2. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 8, image 1 of 1
      • Align the cuff buckle with the strap on the outside holes.
      Ask FixBot
    3. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 9, image 1 of 1
      • Insert the rivet into the first hole from the outside completely until flush with the skate.
      Ask FixBot
    4. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 10, image 1 of 3 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 10, image 2 of 3 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 10, image 3 of 3
      • Insert the long, straight rivet into the rivet gun until it's completely covered.
      • Squeeze the rivet gun repeatedly, until it detaches from the rivet.
      • You will hear a pop.
      • Discard the detached metal rod.
      Ask FixBot
    5. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 11, image 1 of 2 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: step 11, image 2 of 2
      • Repeat for each remaining rivet placement.
      • Following completion of remaining rivets, your new cuff buckle will be fully attached.
      Ask FixBot
Johnnie B.
602 Reputation
5 Guides authored
Texas Tech, Team 41-3, Allen Fall 2025 Member of Texas Tech, Team 41-3, Allen Fall 2025
TTU-ALLEN-F25S41G3
3 Members
30 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 29
All Time: 188
