PAPAISON Adjustable Inline Skates Cuff Buckle Removal
  1. PAPAISON Adjustable Inline Skates Cuff Buckle Removal, Cuff Buckle: step 1, image 1 of 1
    • Place the skate on a flat surface.
    Ask FixBot
  2. PAPAISON Adjustable Inline Skates Cuff Buckle Removal: step 2, image 1 of 2 PAPAISON Adjustable Inline Skates Cuff Buckle Removal: step 2, image 2 of 2
    • Locate the rivets on each side of the cuff buckle.
    • There should be 3 rivets in total.
    Ask FixBot
  3. PAPAISON Adjustable Inline Skates Cuff Buckle Removal: step 3, image 1 of 3 PAPAISON Adjustable Inline Skates Cuff Buckle Removal: step 3, image 2 of 3 PAPAISON Adjustable Inline Skates Cuff Buckle Removal: step 3, image 3 of 3
    • Insert Pozidriv PZ2 screwdriver into the back of each rivet and twist until the rivet is shaved down enough to pop out. Repeat as needed.
    • Apply heavy pressure.
    • If there are issues removing rivets, use a power drill with an 11/32 inch bit.
    • If using a power drill for this process, avoid loose clothing, and tie back hair. Wear safety goggles for additional protection.
    Ask FixBot
  4. PAPAISON Adjustable Inline Skates Cuff Buckle Removal: step 4, image 1 of 1
    • Stripping the rivets will produce metal shavings and dust. Use caution and dispose of them in the trash.
    Ask FixBot
  5. PAPAISON Adjustable Inline Skates Cuff Buckle Removal: step 5, image 1 of 1
    • Remove the plastic part of the cuff buckle with the attached cuff and discard.
    Ask FixBot
  6. PAPAISON Adjustable Inline Skates Cuff Buckle Removal: step 6, image 1 of 2 PAPAISON Adjustable Inline Skates Cuff Buckle Removal: step 6, image 2 of 2
    • Your skate will look like this once they are removed. There are two ways to attach the new cuff buckle:
    • If your new cuff buckle comes with rivets, please use this guide.
    • If your new cuff buckle comes with screws, please use this guide.
    Ask FixBot
To attach your new cuff buckle, see the appropriate guide above. The attachment will depend on whether your buckle includes rivets or screws.
Johnnie B.
602 Reputation
5 Guides authored
Texas Tech, Team 41-3, Allen Fall 2025 Member of Texas Tech, Team 41-3, Allen Fall 2025
TTU-ALLEN-F25S41G3
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 123
