Microsoft Surface Laptop 3 15" Battery Replacement
  1. Microsoft Surface Laptop 3 15" Battery Replacement, Prepare your device: step 1, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Prepare your device: step 1, image 2 of 2
    • Turn on your laptop and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power down your laptop and unplug any cables.
    • Close the laptop.
    Ask FixBot
  2. Microsoft Surface Laptop 3 15" Battery Replacement, Flip the laptop over: step 2, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Flip the laptop over: step 2, image 2 of 2
    • Flip the laptop over and place it on your work surface, feet facing up.
    Ask FixBot
  3. Microsoft Surface Laptop 3 15" Battery Replacement, Removal tip: step 3, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Removal tip: step 3, image 2 of 2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
    Ask FixBot
  4. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the rear feet: step 4, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the rear feet: step 4, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the rear feet: step 4, image 3 of 3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
    Ask FixBot
  5. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the front feet: step 5, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the front feet: step 5, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the front feet: step 5, image 3 of 3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
    Ask FixBot
  6. Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: step 6, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: step 6, image 2 of 2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
    Ask FixBot
  7. Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: step 7, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: step 7, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: step 7, image 3 of 3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
    Ask FixBot
  8. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the upper case screws: step 8, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
    • During reassembly, don't over-tighten these screws—they strip easily.
    Ask FixBot
  9. Microsoft Surface Laptop 3 15" Battery Replacement, Open the display: step 9, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Open the display: step 9, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Open the display: step 9, image 3 of 3
    • Flip the device over.
    • Open the display as far as it will go.
    Ask FixBot
  10. Microsoft Surface Laptop 3 15" Battery Replacement, Lift up the upper case: step 10, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Lift up the upper case: step 10, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Lift up the upper case: step 10, image 3 of 3
    • The upper case is secured in place by magnets.
    • Grip the top edge of upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case just yet, as it's still connected to the rest of the laptop.
    • Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the display could cause damage to the display as it closes.
    Ask FixBot
  11. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the ribbon cable: step 11, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the ribbon cable: step 11, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the ribbon cable: step 11, image 3 of 3
    • The keyboard and touchpad ribbon cable is secured in place by a magnet connector.
    • On some models, this connector is surrounded by black tape.
    • Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
    • Remove the ribbon cable from the motherboard.
    Ask FixBot
  12. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the upper case: step 12, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the upper case: step 12, image 2 of 2
    • Remove the upper case.
    • Set the upper case onto a clean surface, keyboard-side down.
    • Ensure the ribbon cable lays flat, and isn't twisted or stressed.
    Ask FixBot
  13. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the SSD screw: step 13, image 1 of 1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be performed before all major repairs.
    Ask FixBot
  14. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the SSD: step 14, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the SSD: step 14, image 2 of 2
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
    Ask FixBot
  15. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the tape: step 15, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the tape: step 15, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the tape: step 15, image 3 of 3
    Buy
    • Use a pair of tweezers to remove the two pieces of black tape covering the bottom left and bottom right corners of the motherboard.
    • During reassembly, if the tape is sticky enough to be reused, reapply it.
    Ask FixBot
  16. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink shield: step 16, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink shield: step 16, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink shield: step 16, image 3 of 3
    • Use an opening tool to pry up the front edge of the metal shield covering the heatsink.
    • Try not to deform the shield too much—you'll need to reinstall it during reassembly.
    Ask FixBot
  17. Microsoft Surface Laptop 3 15" Battery Replacement: step 17, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement: step 17, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement: step 17, image 3 of 3
    • Work your way around the perimeter of the shield, prying up intermittently, until you can remove it completely.
    Ask FixBot
  18. Microsoft Surface Laptop 3 15" Battery Replacement: step 18, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement: step 18, image 2 of 2
    • Remove the heatsink shield.
    Ask FixBot
  19. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the cooling fan: step 19, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the cooling fan: step 19, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the cooling fan: step 19, image 3 of 3
    • Use the pointed end of a spudger to flip up the locking flap on the fan cable's ZIF connector.
    • Use a pair of tweezers to pull the fan cable straight out of the connector.
    Ask FixBot
  20. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink screws: step 20, image 1 of 1
    • Use a T3 Torx driver to remove the ten screws securing the heatsink:
    • Two 2.5 mm screws
    • Three 2.0 mm screws
    • One 3.0 mm screw
    • Two 4.1 mm screws
    • Two 3.4 mm screws
    Ask FixBot
  21. Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: step 21, image 1 of 1
    • Align the heatsink with the centering peg on the motherboard.
    • Tighten the four CPU tension screws in an "X" pattern.
    Ask FixBot
  22. Microsoft Surface Laptop 3 15" Battery Replacement, Clear the alignment peg: step 22, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Clear the alignment peg: step 22, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Clear the alignment peg: step 22, image 3 of 3
    • Use the tip of your finger to lift the far right edge of the heatsink up and off of the small alignment peg near the right side of the fan on the lower case.
    • Once the heatsink has cleared the peg, lightly pull the right edge towards the front of the device.
    Ask FixBot
  23. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink: step 23, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink: step 23, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink: step 23, image 3 of 3
    • Remove the heatsink.
    • If the heatsink feels stuck to the CPU, gently wiggle it side-to-side to separate it from the thermal paste holding it down.
    • Don't pull on the heatsink too hard; the heat pipes are susceptible to creasing.
    Ask FixBot
  24. Microsoft Surface Laptop 3 15" Battery Replacement, Reapply thermal paste: step 24, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Reapply thermal paste: step 24, image 2 of 2
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and CPU and reapply thermal paste.
    Ask FixBot
  25. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard shields: step 25, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard shields: step 25, image 2 of 2
    • Some motherboard screws are located under two of the metal shields, both of which need to be removed.
    • Use an opening tool to pry up an edge of the metal shield covering the right side of the motherboard.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • Remove the shield.
    Ask FixBot
  26. Microsoft Surface Laptop 3 15" Battery Replacement: step 26, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement: step 26, image 2 of 2
    • Repeat the previous step to remove the second shield from the left side of the motherboard, closest to the CPU.
    Ask FixBot
  27. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the right speaker: step 27, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the right speaker: step 27, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the right speaker: step 27, image 3 of 3
    • Use the pointed end of a spudger to lift and disconnect the right speaker wire from its connector on the motherboard.
    Ask FixBot
  28. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the Surface Connect port: step 28, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the Surface Connect port: step 28, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the Surface Connect port: step 28, image 3 of 3
    • Use an opening tool to flip open the gold locking arm on the Surface Connect port's motherboard connector.
    Ask FixBot
  29. Microsoft Surface Laptop 3 15" Battery Replacement: step 29, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement: step 29, image 2 of 2
    • Grip the Surface Connect port cable and pull it away from its connector to remove it.
    Ask FixBot
  30. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the left speaker: step 30, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the left speaker: step 30, image 2 of 2
    • Use the pointed end of a spudger to lift and disconnect the left speaker wire from its connector on the motherboard.
    Ask FixBot
  31. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the display connector shields: step 31, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the display connector shields: step 31, image 2 of 2
    • Use an opening tool to pry up the black shield covering the right bank of display connectors.
    • Repeat at different points around the shield until it becomes loose.
    Ask FixBot
  32. Microsoft Surface Laptop 3 15" Battery Replacement: step 32, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement: step 32, image 2 of 2
    • Repeat the previous step to remove the remaining shield from the left bank of display connectors.
    Ask FixBot
  33. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the display cables: step 33, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the display cables: step 33, image 2 of 2
    • Use the flat end of a spudger to pry the first display cable up and out of its socket on the motherboard to disconnect it.
    Ask FixBot
  34. Microsoft Surface Laptop 3 15" Battery Replacement: step 34, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement: step 34, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement: step 34, image 3 of 3
    • Disconnect the three remaining display connectors.
    Ask FixBot
  35. Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: step 35, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: step 35, image 2 of 2
    • During reassembly, use the flat end of a spudger to gently push the display cables back into their cavity in the lower case.
    Ask FixBot
  36. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the antenna cable: step 36, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the antenna cable: step 36, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the antenna cable: step 36, image 3 of 3
    Buy
    • Use a pair of tweezers to grip the antenna cable close to its base.
    • Pull straight up to disconnect the cable.
    Ask FixBot
  37. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard bracket: step 37, image 1 of 1
    • Use a T3 Torx driver to remove the two 3 mm screws securing the motherboard bracket.
    Ask FixBot
  38. Microsoft Surface Laptop 3 15" Battery Replacement: step 38, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement: step 38, image 2 of 2
    • Use a pair of tweezers to remove the motherboard bracket.
    Ask FixBot
  39. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard screws: step 39, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard screws: step 39, image 2 of 2
    • Use a T3 Torx driver to remove the six 2 mm screws securing the motherboard.
    • Optionally, to simplify motherboard removal, use a T3 Torx driver to remove the three screws securing the port bracket, then remove the bracket.
    Ask FixBot
  40. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard: step 40, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard: step 40, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard: step 40, image 3 of 3
    • Use your fingers to lift and remove the motherboard.
    • If the motherboard feels stuck, slide the motherboard to the right so the I/O ports clear their cutouts on the chassis.
    • Ensure the two screwpost braces underneath the motherboard don't get lost during removal.
    Ask FixBot
  41. Microsoft Surface Laptop 3 15" Battery Replacement, Check cables during reassembly: step 41, image 1 of 1
    • When you reinstall the motherboard, verify that no cables get trapped under the board as you lower it into place. Check each of the five locations carefully:
    • Four display cables
    • Antenna cable
    • Left speaker cable
    • Surface Connect cable
    • Right speaker cable
    Ask FixBot
  42. Microsoft Surface Laptop 3 15" Battery Replacement, Loosen the battery contact cable adhesive: step 42, image 1 of 2 Microsoft Surface Laptop 3 15" Battery Replacement, Loosen the battery contact cable adhesive: step 42, image 2 of 2
    • Heat an iOpener and lay it on top of the battery contact cable for about a minute, in order to soften the adhesive securing it to the case.
    • If you don't have an iOpener, use a hair dryer to warm up the cable instead.
    Ask FixBot
  43. Microsoft Surface Laptop 3 15" Battery Replacement, Separate the battery contact cable: step 43, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Separate the battery contact cable: step 43, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Separate the battery contact cable: step 43, image 3 of 3
    • Slide an opening pick underneath the battery contact cable to separate it from the case.
    • If the adhesive is stubborn, don't force the pick. Lightly reheat the cable and try again.
    • During reassembly, note that the contact cable is centered in place with both a screwpost and an alignment peg.
    Ask FixBot
  44. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the battery screws: step 44, image 1 of 1
    • Use a T3 Torx driver to remove the six 2.7 mm screws securing the battery to the case.
    Ask FixBot
  45. Microsoft Surface Laptop 3 15" Battery Replacement, Loosen the battery adhesive: step 45, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Loosen the battery adhesive: step 45, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Loosen the battery adhesive: step 45, image 3 of 3
    • Apply adhesive remover or high-concentration (90% or higher) isopropyl alcohol to the top edges of all three battery cell groups.
    • If you are using adhesive remover, follow these preparation steps first.
    • Wait 2–3 minutes for the adhesive remover to penetrate and soften the adhesive before you proceed to the next step.
    Ask FixBot
  46. Microsoft Surface Laptop 3 15" Battery Replacement: step 46, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement: step 46, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement: step 46, image 3 of 3
    Plastic Cards
    $2.99
    Buy
    • Take care not to puncture or bend the battery with your tools—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Slide a plastic card underneath the far left battery cell group to slice through the adhesive holding it to the case.
    • If you encounter significant resistance at any point during this procedure, pause and apply more adhesive remover. Wait for it to soak into the adhesive, and try again.
    • Wiggle the card from side to side as you insert it under the battery cells to fully separate all adhesive holding them in place.
    • Leave the plastic card temporarily underneath the cell to prevent it from re-adhering while you continue.
    Ask FixBot
  47. Microsoft Surface Laptop 3 15" Battery Replacement: step 47, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement: step 47, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement: step 47, image 3 of 3
    • Slide a second plastic card underneath the middle battery cell group to slice through the adhesive holding it to the case.
    Ask FixBot
  48. Microsoft Surface Laptop 3 15" Battery Replacement: step 48, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement: step 48, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement: step 48, image 3 of 3
    • Slide the card out from under the middle cell group.
    • Leave the card that's underneath the left group in place for now.
    • Slide the plastic card underneath the far right battery cell group to slice through the adhesive holding it to the case.
    • Leave the plastic card temporarily underneath the right cell group to prevent it from re-adhering while you continue.
    Ask FixBot
  49. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the battery: step 49, image 1 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the battery: step 49, image 2 of 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the battery: step 49, image 3 of 3
    Tesa 61395 Tape
    $25.95
    Buy
    • Use both plastic cards to lift the entire battery assembly up and away from the case.
    • If the battery still feels adhered to the case, reapply adhesive remover and use the plastic cards in problem areas to make sure all three cell groups are fully separated from the case.
    • Remove the battery.
    • During reassembly, double-check the fit and alignment of your new battery before sticking it down.
    • If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
    • Carefully position the battery and set it into place. Press and hold each cell group firmly for 5–10 seconds to secure it to the lower case.
    Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
5 other people completed this guide.
Carsten Frauenheim
167,227 Reputation
439 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,624 Guides authored
7 Guide Comments
Wow, that was hard. but I did it and it worked. however. a couple of things. two of the mounting holes in the ifixit battery do not line up with the holes in the case - not a big deal, as the adhesive does most of the holding. And, two elongated dump-bell-shaped washers/bushings fell out somewhere when taking the motherboard out. I just found them lying in the case. I have no idea where they go (i can send an image of them).. like i said, it appears to work without them -- for now.
R
buckrepairer - Reply Share
I'll check on those battery mounting holes! Those two washers are mentioned in step 40. They live under the motherboard.
Carsten Frauenheim - Reply Share
Got through that. The author did a great job with the instructions, thank you!
The laptop powers up and operates just fine but is not charging. We have ordered another Surface 127W power supply but does anyone know of any issues with the Microsoft power supply not being happy with the replacement battery?
Patrick Arnold - Reply Share
Vous avez obtenu une réponse par ailleurs ?
Regis Junkem - Reply Share
Wow, what a job... Should probably have a caption saying "do not try this at home"! Amazing that Microsoft made it so extraordinarily complicated just to change the battery - obviously a design choice to get people to buy new machines rather than replacing batteries! This sort of design should be prohibited by law. Be warned, removing the various shields is awful, and prising the battery cells out with isopropanol is messy. However, with the fantastic instructions here, and care and perseverance it is certainly possible. Only additional note I would add is to take precautions for static. Finally completed at 3 in the morning and the laptop is back to together, runs and charges. Thanks for the guidance iFixit :)
Samuel S - Reply Share
Past 24 Hours: 7
Past 7 Days: 74
Past 30 Days: 325
All Time: 37,113
