Up to 20% off select tools
iFixit Adhesive Remover Preparation
Views: 29K
View statistics:
Past 24 Hours:
11
Past 7 Days:
73
Past 30 Days:
381
All Time:
29,226
Comments: 0
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide shows how to safely use iFixit’s adhesive remover.
    1. iFixit Adhesive Remover Preparation, iFixit Adhesive Remover Preparation: step 1, image 1 of 2 iFixit Adhesive Remover Preparation, iFixit Adhesive Remover Preparation: step 1, image 2 of 2
      • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
      • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
      • Do not wear contact lenses without eye protection.
      • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
      Ask FixBot
    2. iFixit Adhesive Remover Preparation: step 2, image 1 of 3 iFixit Adhesive Remover Preparation: step 2, image 2 of 3 iFixit Adhesive Remover Preparation: step 2, image 3 of 3
      • Pull off the black rubber stopper from your bottle of adhesive remover.
      • Twist to loosen or remove the bottle cap before you cut the applicator tip.
      • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
      • Use scissors to cut off the sealed tip of the applicator.
      • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
      • Twist and close the bottle cap securely before you proceed further.
      Ask FixBot
Finish Line
15 other people completed this guide.
Author
with
Arthur Shi
354,458 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 73
Past 30 Days: 381
All Time: 29,226
