Up to 20% off select tools
How to Use the FixHub Web Console
Views: 8.6K
View statistics:
Past 24 Hours:
23
Past 7 Days:
117
Past 30 Days:
433
All Time:
8,618
Comments: 8
8 guide comments.
Go to guide comments
Completed: 22
22 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Follow this guide to adjust the settings and update the firmware on your FixHub Portable Power Station using a computer.
    1. How to Use the FixHub Web Console, Connect your power station: step 1, image 1 of 2 How to Use the FixHub Web Console, Connect your power station: step 1, image 2 of 2
      • To use the FixHub Web Console, you need a browser with Web Serial enabled. We recommend Brave, Chrome, Edge, or Opera as they include this functionality enabled by default.
      • Firefox supports Web Serial since version 141, but requires installation of an add-on before the functionality can be used.
      • Safari doesn't support Web Serial at this time.
      • Plug the Portable Power Station into your computer, making sure the cable is connected to the power station's rear port (the side opposite the screen).
      • Ensure your cable is capable of data transfer. Otherwise, you won't be able to use the web console.
      • Navigate to iFixit.com/FixHub/console
      Ask FixBot
    2. How to Use the FixHub Web Console: step 2, image 1 of 3 How to Use the FixHub Web Console: step 2, image 2 of 3 How to Use the FixHub Web Console: step 2, image 3 of 3
      • Click Connect my device.
      • Select your Portable Power Station from the pop-up window asking you to connect a serial port.
      • If your power station is completely drained, it may not show up. Skip to this step to boot into the bootloader.
      • Click Connect.
      Ask FixBot
    3. How to Use the FixHub Web Console, FixHub Web Console layout: step 3, image 1 of 2 How to Use the FixHub Web Console, FixHub Web Console layout: step 3, image 2 of 2
      • Once the FixHub Web Console opens, you'll see information and settings for your power station:
      • USB 1 shows info about the device connected to the power station's front left USB-C port.
      • USB 2 shows info about the device connected to the power station's front right USB-C port.
      • Battery shows the battery percentage in real time.
      • Serial number shows the serial number of the power station.
      • Version shows the firmware version and updates for the power station.
      Ask FixBot
    4. How to Use the FixHub Web Console, Firmware update: step 4, image 1 of 3 How to Use the FixHub Web Console, Firmware update: step 4, image 2 of 3 How to Use the FixHub Web Console, Firmware update: step 4, image 3 of 3
      • Before using the FixHub Web Console, ensure your firmware is up to date.
      • Select the Version box.
      • Click Update now and wait for the firmware update to complete. Don't disconnect your power station or close the window during the firmware update.
      • Once your power station updates successfully, be sure to update your soldering iron firmware to the same version.
      • If something goes wrong, you can downgrade your firmware by repeating these steps and clicking Pick a specific firmware version.
      Ask FixBot
    5. How to Use the FixHub Web Console, Firmware update using the bootloader: step 5, image 1 of 3 How to Use the FixHub Web Console, Firmware update using the bootloader: step 5, image 2 of 3 How to Use the FixHub Web Console, Firmware update using the bootloader: step 5, image 3 of 3
      • Follow this step to update a drained power station's firmware using the bootloader.
      • Unplug the power station from the computer.
      • Press and hold the adjustment knob.
      • Plug the power station back into to the computer, then release the adjustment knob.
      • The web console will show that the device has failed to start up.
      • Use the web console to manually update the firmware.
      Ask FixBot
That's it!
Still need help? Ask our Answers community, or try some basic troubleshooting.
22 other people completed this guide.
Author
with
Nick Schultz
71,397 Reputation
363 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
8 Guide Comments
Can you update the app or website to display the latest firmware release information for this device? When I plug in my hub, it only shows the current firmware version on the device but doesn't indicate if it's the latest. Unlike other options, I can't click on the box for more details. Additionally, I couldn't find any information on your website about the current firmware version or its release notes.
john - Reply Share
The web console page is: https://www.ifixit.com/fixhub/console
This is where you can browse through the current and prior firmware versions. However, I don't believe the packaged firmware (at least with CI/CD) is currently open-source at the time of writing. Yet you can see what is currently available here on GitHub: https://github.com/ifixit/fixhub (The commands here work if you're able to access the FixHub with either minicomp on Linux or PuTTY on Windows; you can determine which TTY device the FixHub is assigned to with the help of the FixHub web console, which reliably picks out the correct low-level serial device name for the FixHub.)
Tai Lam - Reply Share
Settings tab is missing in the FixHub page for the Ifix-it portable power station. I am unable to reset battery health Calibration data for the PPS so i can perform initial battery calibration. is this a glitch? any suggestions?
Hector A - Reply Share
Same the settings tab is missing for me with no option to reset battery health calibration data after updating the firmware on the power station.
Slittcer - Reply Share
il manque le boutons settings, il y a un autre moyen de recalibrer la batterie ?
Alexandre - Reply Share
Past 24 Hours: 23
Past 7 Days: 117
Past 30 Days: 433
All Time: 8,618
