Up to 20% off select tools
How to Use the FixHub Web Console
Views: 5.6K
View statistics:
Past 24 Hours:
14
Past 7 Days:
63
Past 30 Days:
336
All Time:
5,614
Comments: 3
3 comments on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Follow this guide to adjust the settings on your FixHub Smart Soldering Iron using a computer. All changes made will be saved to the iron's onboard storage.
    1. How to Use the FixHub Web Console, Plug in your iron: step 1, image 1 of 1
      • To use the FixHub Web Console, you need a browser with Web Serial enabled. We recommend Brave, Chrome, Edge, or Opera as they include this functionality enabled by default.
      • Firefox supports Web Serial since version 141, but requires installation of an add-on before the functionality can be used.
      • Safari don't support Web Serial at this time.
      • Plug the cable included with your iron or any USB cable that supports data transfer into your computer.
      • Navigate to iFixit.com/FixHub/console
      Ask FixBot
    2. How to Use the FixHub Web Console, Connect your iron: step 2, image 1 of 3 How to Use the FixHub Web Console, Connect your iron: step 2, image 2 of 3 How to Use the FixHub Web Console, Connect your iron: step 2, image 3 of 3
      • Click Connect my device.
      • Select your Smart Soldering Iron from the pop-up window asking you to connect a serial port.
      • Click Connect.
      Ask FixBot
    3. How to Use the FixHub Web Console, FixHub Web Console layout: step 3, image 1 of 1
      • Once the FixHub Web Console opens, you'll see temperature settings, current status, and other information:
      • Current temperature shows the tip temperature in real time.
      • Set temperature allows you to change the iron's temperature with a slider.
      • Status reflects the current status of the iron.
      • Settings allows you to change iron settings such as idle temperature and sleep timer.
      • Serial number shows the serial number of the connected iron.
      • Version shows the firmware version of the connected iron.
      Ask FixBot
    4. How to Use the FixHub Web Console, Firmware update: step 4, image 1 of 3 How to Use the FixHub Web Console, Firmware update: step 4, image 2 of 3 How to Use the FixHub Web Console, Firmware update: step 4, image 3 of 3
      • Before using the FixHub Web Console, ensure your firmware is up to date.
      • Select the Version box.
      • Click Update now and wait for the firmware update to complete. Don't disconnect your iron or close the window during the firmware update.
      • Once the soldering iron updates successfully, be sure to update the Portable Power Station firmware to the same version.
      • If something goes wrong, you can downgrade your firmware by repeating these steps and clicking Downgrade to an older firmware.
      Ask FixBot
    5. How to Use the FixHub Web Console, Adjust the set temperature: step 5, image 1 of 3 How to Use the FixHub Web Console, Adjust the set temperature: step 5, image 2 of 3 How to Use the FixHub Web Console, Adjust the set temperature: step 5, image 3 of 3
      • Drag the Set temperature slider to your desired temperature from 200 to 420 °C (395 to 790 °F).
      Ask FixBot
    6. How to Use the FixHub Web Console, Change the temperature scale: step 6, image 1 of 2 How to Use the FixHub Web Console, Change the temperature scale: step 6, image 2 of 2
      • You can reset all settings back to default at any time.
      • Click the Settings box.
      • At the top of the Settings window, select your desired unit for temperature under the Unit tab.
      Ask FixBot
    7. How to Use the FixHub Web Console, Adjust the idle temperature: step 7, image 1 of 3 How to Use the FixHub Web Console, Adjust the idle temperature: step 7, image 2 of 3 How to Use the FixHub Web Console, Adjust the idle temperature: step 7, image 3 of 3
      • A lower idle temperature will extend tip life, while a higher one will resume working temperature more quickly.
      • Drag the Idle temperature slider to your desired temperature from 50 to 200 °C (125 to 390 °F).
      Ask FixBot
    8. How to Use the FixHub Web Console, Adjust the idle timer: step 8, image 1 of 3 How to Use the FixHub Web Console, Adjust the idle timer: step 8, image 2 of 3 How to Use the FixHub Web Console, Adjust the idle timer: step 8, image 3 of 3
      • The idle timer can be disabled, but it's highly recommended to leave it enabled to prevent the iron cap from overheating and to extend tip life.
      • The idle timer setting adjusts how long the iron must be stationary before entering Idle Mode.
      • Drag the Idle timer slider to your desired time from 1s to 60s.
      Ask FixBot
    9. How to Use the FixHub Web Console, Adjust the sleep timer: step 9, image 1 of 2 How to Use the FixHub Web Console, Adjust the sleep timer: step 9, image 2 of 2
      • The sleep timer can be disabled, but doing so will cause the iron cap to overheat and the tip to degrade rapidly.
      • Drag the Sleep timer slider to your desired time from 1s to 60s.
      Ask FixBot
    10. How to Use the FixHub Web Console, Offset temperature based on external calibration: step 10, image 1 of 3 How to Use the FixHub Web Console, Offset temperature based on external calibration: step 10, image 2 of 3 How to Use the FixHub Web Console, Offset temperature based on external calibration: step 10, image 3 of 3
      • This setting lets you offset the temperature settings of your iron tips based on an external temperature sensor.
      • Drag the Temperature correction slider to the desired amount from -20 to +20 °C (-36 to 36 °F).
      Ask FixBot
    11. How to Use the FixHub Web Console, Calibrate the accelerometer: step 11, image 1 of 2 How to Use the FixHub Web Console, Calibrate the accelerometer: step 11, image 2 of 2
      • This setting lets you calibrate the accelerometer in the iron by setting it completely still.
      • Click Go to calibration to open the Accelerometer Calibration page.
      • Set the iron down on a stationary object with the power switch facing up. Click Calibrate to set the current magnitude (shown in the line graph on the page) as the iron's resting state.
      Ask FixBot
That's it! You're ready to configure your Smart Soldering Iron to your individual preferences.
Still struggling? Try some basic troubleshooting, or ask our Answers community for help.
7 other people completed this guide.
Author
with
Nick Schultz
71,397 Reputation
363 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 63
Past 30 Days: 336
All Time: 5,614
