Advanced No-Sew Zipper Repair Techniques
      • Before starting any techniques in this guide, identify the correct zipper type, size, and qualities. Reference the Zipper Identification guide for help.
      Ask FixBot
    1. Advanced No-Sew Zipper Repair Techniques, INFO: Zipper top stops: step 2, image 1 of 3 Advanced No-Sew Zipper Repair Techniques, INFO: Zipper top stops: step 2, image 2 of 3 Advanced No-Sew Zipper Repair Techniques, INFO: Zipper top stops: step 2, image 3 of 3
      • Top stops prevent the slider from coming off the zipper track. There are three types of top stops:
      • Coil top stops are metal pieces shaped like a claw with three prongs (2 on one side and 1 on the other). They're applied by puncturing through the zipper tape and wrapping the prongs into the coil.
      • A single hand stitch can also be used as a stop for a coil zipper.
      • Plastic tooth (Vislon®) top stops are colored metal pieces shaped like a hot dog bun. They clamp onto a toothless area of the zipper tape.
      • These top stops don't prevent plastic tooth sliders size 5 and larger from sliding off the tape. Use metal top stops instead.
      • Metal top stops are metal piece shaped like a small "c." They clamp onto a toothless area of a metal or plastic tooth zipper tape.
      • Despite the name, top stops can be placed on other locations of the zipper track, not just the top.
      Ask FixBot
    2. Advanced No-Sew Zipper Repair Techniques, SKILL: Top stop removal: step 3, image 1 of 3 Advanced No-Sew Zipper Repair Techniques, SKILL: Top stop removal: step 3, image 2 of 3 Advanced No-Sew Zipper Repair Techniques, SKILL: Top stop removal: step 3, image 3 of 3
      • Application - Factory-applied top stops can be removed to release sliders from the zipper tape.
      • Skill - Use flush cutters to nip off the edge of the plastic, then peel the rest of the plastic away.
      • Wear safety glasses.
      • Try to avoid cutting or damaging the zipper tape.
      • Singe frayed or damaged zipper tape with a lighter.
      Ask FixBot
    3. Advanced No-Sew Zipper Repair Techniques, SKILL: Cutting zipper teeth: step 4, image 1 of 3 Advanced No-Sew Zipper Repair Techniques, SKILL: Cutting zipper teeth: step 4, image 2 of 3 Advanced No-Sew Zipper Repair Techniques, SKILL: Cutting zipper teeth: step 4, image 3 of 3
      • Application - Cutting zipper teeth is a valuable skill that can help with all sorts of zipper repairs.
      • Wear safety goggles.
      • Plastic Tooth - Use flush cutters to snip along the edge of the teeth, then peel the rest of the tooth away from the tape.
      • Coil - Use flush cutters to snip along the edge of the teeth, then pull out the back side of each coil with needle nose pliers.
      Ask FixBot
    4. Advanced No-Sew Zipper Repair Techniques, SKILL: Breaking a slider: step 5, image 1 of 3 Advanced No-Sew Zipper Repair Techniques, SKILL: Breaking a slider: step 5, image 2 of 3 Advanced No-Sew Zipper Repair Techniques, SKILL: Breaking a slider: step 5, image 3 of 3
      • Application - A slider that's fully stuck and can't move up or down due to corrosion, caught fabric, or damage should be forcibly broken and removed to prevent further damage to the zipper tape and any snagged fabric.
      • This technique uses two pairs of needle-nose vice grips to break the top and bottom of the slider away from the "diamond" that holds them together, so the slider releases from the zipper teeth.
      Ask FixBot
    5. Advanced No-Sew Zipper Repair Techniques, SKILL: Breaking a slider: step 6, image 1 of 3 Advanced No-Sew Zipper Repair Techniques, SKILL: Breaking a slider: step 6, image 2 of 3 Advanced No-Sew Zipper Repair Techniques, SKILL: Breaking a slider: step 6, image 3 of 3
      • Skill - Clamp the top of the slider with one pair of needle nose vice grips and the bottom of the slider with the other pair of vice grips, making sure no fabric is caught.
      • Use both a twisting motion and a rocking motion to loosen the diamond until it breaks.
      • Because the surface area of the slider is so small, the vice grips often dislodge. Reattach them and try again if needed.
      • Steam any fabric that was caught to help prevent future snagging.
      • Discard the broken slider responsibly.
      • Attach a new slider:
      • Coil Zipper Slider Replacement
      • Plastic Tooth Zipper Slider Replacement
      Ask FixBot
      • Reference this video to see the technique off of a garment.
      Ask FixBot
      • Issue - When zippers have been worn down, the sides of the zipper can become unaligned and offset. If the zipper is coil, the two sides can sometimes be realigned.
      • Technique - Bring the slider as close as possible to the unaligned area. Then move the slider away, gently pulling on the side of the zipper that's bubbled, trying to skip teeth. Bring the slider back down and repeat until the skipped area is fixed.
      • This technique is a permanent repair. However, if there's any hesitation that this technique will cause damage, remove and replace the slider.
      Ask FixBot
    6. Advanced No-Sew Zipper Repair Techniques, SKILL: Fastening zippers by hand: step 9, image 1 of 3 Advanced No-Sew Zipper Repair Techniques, SKILL: Fastening zippers by hand: step 9, image 2 of 3 Advanced No-Sew Zipper Repair Techniques, SKILL: Fastening zippers by hand: step 9, image 3 of 3
      • Application - Many repair techniques require split zippers to be refastened before the fix is applied. To achieve this, the zipping function of slider can be mimicked by hand.
      • Skill - Begin where the zipper teeth first start to split and use your fingers to manipulate the teeth back together (reference the video in Step 10).
      • Use a safety pin through the tape to capture progress and to keep the zipper from re-separating (reference image #2).
      • A FixnZip is a handy tool that can also be used to fasten a section of zipper back together (reference image #3).
      Ask FixBot
      • Reference this video to see the technique in action.
      Ask FixBot
    7. Advanced No-Sew Zipper Repair Techniques, SKILL: Retracking a slider at a damaged area: step 11, image 1 of 3 Advanced No-Sew Zipper Repair Techniques, SKILL: Retracking a slider at a damaged area: step 11, image 2 of 3 Advanced No-Sew Zipper Repair Techniques, SKILL: Retracking a slider at a damaged area: step 11, image 3 of 3
      • Application - Damage to zipper teeth or zipper tape can cause the slider to come off one or both sides of the zipper. Use the damaged area to retrack the slider back onto the zipper tape when doing a temporary fix.
      • Skill - Remove the teeth at the damaged area and lightly singe the tape if it has frayed. This will leave an open area where the slider can be maneuvered back on to the zipper tape.
      • Patagonia Repair Tech Tip: Maneuver the slider as if parallel parking a car. Start at an angle, back it onto the zipper tape, and then straighten out.
      Ask FixBot
    8. Advanced No-Sew Zipper Repair Techniques, TECHNIQUE: Replacing a pocket slider - Sacrificial teeth: step 12, image 1 of 3 Advanced No-Sew Zipper Repair Techniques, TECHNIQUE: Replacing a pocket slider - Sacrificial teeth: step 12, image 2 of 3 Advanced No-Sew Zipper Repair Techniques, TECHNIQUE: Replacing a pocket slider - Sacrificial teeth: step 12, image 3 of 3
      • Issue - A pocket zipper is missing a slider, or has a stuck slider, and there's no tooth or tape damage.
      • Technique - Remove a small number of teeth from the base of the zipper to create space to retrack a new slider.
      • If the slider remains, break it off.
      • Remove teeth from both sides at the base of the zipper. Take only as many teeth are necessary to retrack the new slider. Singe any fraying.
      • Put on a new slider where the teeth were removed, catching both sides of the zipper, and slide it up.
      • Use a top stop or a hand stitch to lock off the bottom of the zipper.
      • This technique is the quick fix alternative to a Sewn Zipper Slider Replacement, where the stitching is opened at the base of the pocket to retrack a new slider.
      Ask FixBot
    9. Advanced No-Sew Zipper Repair Techniques, TECHNIQUE: Isolating zipper teeth damage - Packs: step 13, image 1 of 3 Advanced No-Sew Zipper Repair Techniques, TECHNIQUE: Isolating zipper teeth damage - Packs: step 13, image 2 of 3 Advanced No-Sew Zipper Repair Techniques, TECHNIQUE: Isolating zipper teeth damage - Packs: step 13, image 3 of 3
      • Issue - There's damage to the zipper on a backpack.
      • Technique - Isolate each slider to one side of the damage so the damage location will become the place where the sliders meet.
      • It's likely that the sliders have come unconnected from the damaged side.
      • Use the skill in Steps 9 and 10 to refasten the zipper teeth on both sides of the damage.
      • Use the skill in Step 11 to retrack both sliders onto the zipper at the damaged area.
      • Place a coil top stop at the damaged area with the sides of the zipper either together or apart depending on preference.
      • This technique is the quick fix alternative to a Backpack Zipper Replacement.
      Ask FixBot
    10. Advanced No-Sew Zipper Repair Techniques, TECHNIQUE: Isolating zipper teeth damage - Separating zippers: step 14, image 1 of 2 Advanced No-Sew Zipper Repair Techniques, TECHNIQUE: Isolating zipper teeth damage - Separating zippers: step 14, image 2 of 2
      • Issue - There's tooth or tape damage on a separating zipper.
      • Technique #1 - Isolate damage on the bottom half of the zipper.
      • Move the slider to sit above the damage. Apply a coil top stop above and below the damaged area, connecting both sides of the zipper. The jacket is now a half-zip pullover!
      • This technique can also work when the zipper box or pin are damaged.
      • Technique #2 - Isolate damage on the top half of the zipper.
      • Move the slider to sit below the damage. Apply two coil top stops to the zipper at the damaged area, one on each side of the zipper tape. The jacket will still zip, just not all the way up.
      • This technique is the quick fix alternative to a Zipper Line Replacement.
      Ask FixBot
    11. Advanced No-Sew Zipper Repair Techniques, TECHNIQUE: Isolating zipper teeth damage - Pocket zippers: step 15, image 1 of 3 Advanced No-Sew Zipper Repair Techniques, TECHNIQUE: Isolating zipper teeth damage - Pocket zippers: step 15, image 2 of 3 Advanced No-Sew Zipper Repair Techniques, TECHNIQUE: Isolating zipper teeth damage - Pocket zippers: step 15, image 3 of 3
      • Issue - There's tooth or tape damage on a pocket zipper.
      • Technique #1 - Repair damage below the halfway point.
      • Move the slider above the damage and use a coil top stop to connect both sides of the zipper at the damage. Make sure the user can still fit their hand in opening.
      • Technique #2 - Repair damage above the halfway point.
      • Move the slider below the damage and add coil top stops to both sides of the zipper tape at the damage area. Warn the user that the pocket can't close fully now before pursuing this technique.
      • The pocket could also be temporarily fully closed with top stops if the damage is too extensive (reference image #3).
      • This technique is the quick fix alternative to a Pocket Zipper Replacement.
      Ask FixBot
    12. Advanced No-Sew Zipper Repair Techniques, INFO: Zipper corrosion: step 16, image 1 of 2 Advanced No-Sew Zipper Repair Techniques, INFO: Zipper corrosion: step 16, image 2 of 2
      • Any metal part of a zipper will corrode with enough exposure to salt water and air.
      • Frequently wash any items that come in contact with salt water.
      • Some slightly seized zippers can be freed by rubbing off the corrosion with Coca-Cola and/or rubbing alcohol.
      • If the zipper teeth and tape are in good condition, remove and replace the slider.
      • If the zipper teeth and tape are damaged, pursue a full zipper line replacement.
      Ask FixBot
Finish Line
Zach Mueller
1,810 Reputation
9 Guides authored
Patagonia Member of Patagonia
Community
9 Members
383 Guides authored
0 Guide Comments
Past 24 Hours: 45
Past 7 Days: 343
Past 30 Days: 1,476
All Time: 24,385
