Up to 20% off select tools
Coil Zipper Slider Replacement
Views: 124K
View statistics:
Past 24 Hours:
76
Past 7 Days:
496
Past 30 Days:
1,801
All Time:
123,521
Comments: 11
11 guide comments.
Go to guide comments
Completed: 25
25 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Tools
Introduction
Go to step 1 ↓
A zipper slider is responsible for joining the two sides of the zipper and ensuring the teeth secure properly. When a slider is damaged or missing, the zipper will not stay closed and the slider needs to be replaced.
This guide will demonstrate how to replace the slider on a coil zipper.
IMPORTANT! Before proceeding:
  1. Ensure that the zipper separates at the top and bottom (e.g. a center front jacket zipper) and the top and bottom are not sewn together (e.g. a pocket zipper)
  2. Identify the type of zipper to obtain the correct replacement part
  3. Ensure that the issue can be fixed with a slider replacement and doesn't require a full zipper line replacement
Read through the entire guide before starting the repair, and gather the necessary tools and materials. While Patagonia-specific materials are ideal, they are not required. Patagonia replacement parts can be obtained by calling or messaging Patagonia Customer Service.
Alternatively, Patagonia products can be taken to a local retail store for a repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
WARNING! Small Parts. Patagonia does not recommend conducting these repairs on garments intended for children age 3 or under. Instead, we recommend return of the product for professional repair services.
The 3 Stages of Patagonia Zipper Repair
  1. Identify the zipper type
  2. Diagnose the issue
  3. Repair the zipper
Return to the Patagonia Care & Repair homepage.
    1. Coil Zipper Slider Replacement, Gather materials: step 1, image 1 of 3 Coil Zipper Slider Replacement, Gather materials: step 1, image 2 of 3 Coil Zipper Slider Replacement, Gather materials: step 1, image 3 of 3
      • Gather tools and the two pieces required for a coil slider replacement:
      • A replacement slider that is the right size and style
      • Reference the Zipper Identification guide to confirm the appropriate replacement piece.
      • A coil top stop in the correct size
      • Coil top stops look like a small metal claw with a flat back and three prongs (one on one side and two on the other).
      Ask FixBot
    2. Coil Zipper Slider Replacement, Locate the top stop: step 2, image 1 of 3 Coil Zipper Slider Replacement, Locate the top stop: step 2, image 2 of 3 Coil Zipper Slider Replacement, Locate the top stop: step 2, image 3 of 3
      • Unzip the zipper.
      • Locate the top stop at the top of the zipper on the side with the slider.
      • The top stop is a piece of plastic or metal that keeps the slider from coming off the top of the zipper.
      • Peel back any fabric that is covering the top stop.
      Ask FixBot
      • Wear safety glasses to protect from projectile pieces.
      • Use end nippers or flush cutters to remove the top stop.
      • To avoid cutting the zipper tape, position the nippers to cut off only the very edge of the stop, then peel away the rest of the stop from the zipper tape.
      Ask FixBot
      • Use a lighter to singe frayed or damaged zipper tape.
      Ask FixBot
      • Slide the damaged zipper slider up and off the zipper tape.
      • Discard the zipper slider responsibly.
      Ask FixBot
      • Making sure the new slider is oriented correctly, slide it onto the zipper tape.
      • Patagonia Repair Tech Tip: Maneuver the slider as if parallel parking a car. Start at an angle, back it onto the zipper tape, and then straighten out. This step can take practice, patience, and a little muscle!
      • Once the slider is on the zipper, test zipping up the jacket to make sure it's the right slider type and that the issue is fixed.
      Ask FixBot
      • Place the top stop on the flat, tape side of the zipper, aligning the double-prong side of the stop to face the jacket and the single-prong side to face the zipper teeth.
      • Slide the single-prong beneath the first or second tooth at the top of the zipper tape.
      • Push the double-prongs through the zipper tape so they emerge on the opposite side, on the inside of the coil.
      Ask FixBot
      • Use pliers to bend the prongs of the stop inward, clamping them around the zipper coil. The prongs will grab into the coil, securing it in place.
      • Check that the new stop effectively prevents the new slider from coming off the zipper.
      Ask FixBot
Finish Line
25 other people completed this guide.
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
11 Guide Comments
Where do I get the zipper stop????
Jason Heimink - Reply Share
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
bbehrhorst - Reply Share
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
kasten39828 - Reply Share
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Jenny - Reply Share
Great now how ! thank’s :)
Robert Fyfe - Reply Share
Past 24 Hours: 76
Past 7 Days: 496
Past 30 Days: 1,801
All Time: 123,521
