Acer AL2216W Capacitor Replacement
Views: 26K
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
163
All Time:
25,848
Comments: 34
5 comments on steps, 29 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 hours
Difficulty: Difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
If your AL2216W is having problems, it is likely due to bad capacitors. Here are some common symptoms of bad capacitors:
Note: While some issues may be corrected with a partial repair, this is NOT RECOMMENDED. One bad capacitor usually means the rest will fail!
  • Power issues (Present issue)
  • Excessive transformer/inverter hum (Present)
  • Backlight problems
  • Auto adjust problems (VGA) (Present)
  • Random power issues are only resolved through a full power cycle (unplugging the monitor)
  • Video issues (Ex: Unstable image, video instability)
Original capacitor values (For Delta 00A power supply)
NOTE: I based the capacitor list on my monitor's specific power supply (Delta 00A). UNLESS YOU HAVE THE SAME PART IN YOUR MONITOR, YOU MUST VERIFY THAT MY CAPACITOR LIST IS ACCURATE TO YOUR MONITOR. However, in many cases, the stock part used is likely either NLA or hard to find a direct match for, especially as these monitors age. As such, you will likely need to use different capacitors that either have a higher voltage or uF rating and swap all of the remaining original capacitors that with the old component ratings for the newer part as there is a chance they will take on more wear and fail much sooner.
IMPORTANT: When swapping capacitors, stay as close to the original as possible. It’s okay to install a 35V 1000μF part instead of a 25V 1000μF part (or a 25V 2000μF replacement), but grossly exceeding the value of the stock part does not offer any benefits.
Part availability caution: While I have done my best throughout this guide's life (and still do what I can) to keep up with part phaseouts (and replacing hard "obsolete in practice" value components) by mitigating the issue as needed with components of a similar voltage or uF rating, I cannot continuously monitor the market. You may need to make additional substitutions!
  • 25V 1000uF (x2)
  • 10V 1000uF (x1)
  • 25V 220uF (x2)
  • 16V 2200uF (x1, Only found on early power supplies, and is used to drive the inverter transformer. This was not used in later power supply revisions as it was removed at some point.
Parts
Tools
    1. Acer AL2216W Capacitor Replacement, Cost note: step 1, image 1 of 3 Acer AL2216W Capacitor Replacement, Cost note: step 1, image 2 of 3 Acer AL2216W Capacitor Replacement, Cost note: step 1, image 3 of 3
      Tool used on this step:
      iFixit Precision 4 mm Screwdriver Bit
      $2.99
      Buy
      • The clone kits do not have the same lifespan the iFixit products are known for, but for periodic use on a budget, these kits will hold up for a reasonable amount of time.
      • If you buy iFixit tools to complete this guide, you will pay more for the toolkit vs the monitor, and is unavoidable. However, this is very common and the cost can be worked around over several uses as the tool will be a one-time purchase, unlike parts. If you plan on using the tools long past the monitor, cheap out on parts, not tools.
      • Current EET owners: You will need a 5mm driver bit for Step 8, your kit DOES NOT INCLUDE THIS BIT. While I no longer recommend it for new purchases, I have found an economical workaround to get the missing bit.
      • Due to add-on cost issues with the EET requiring a 5mm nut driver ($7.13+) or 5mm driver ($14.05+), I have removed the EET from the tool list due to add-on cost creep. If you are starting fresh and purchasing a new toolkit (and do not have an existing toolkit), the Pro Tech Go, a refurbished Pro Tech Go (or the full-sized Pro Tech) is the current recommendation. If your tool budget is tight, Harbor Freight has a good toolkit with lots of bits I have personally tested. (HF Item#: 59258)
      • iFixit refurbished tools: These do not come in the Retail package (rather, a plastic bag) but will cut your tool cost down when they are available in stock. Use this search to see if what you want is in stock.
      • Backup source for 63/37 leaded solder: https://www.digikey.com/en/products/deta...
      Ask FixBot
    2. Acer AL2216W Capacitor Replacement, Discharge the old capacitors: step 2, image 1 of 1
      • CAUTION: If you are uncertain about handing high voltage parts, follow all provided warnings! A capacitor discharge tool is STRONGLY RECOMMENDED.
      • The filter capacitor will hold the most residual charge. Use caution around this capacitor!
      • Unplug the monitor for 24-48 hours. Wait 5-7 days before swapping the filter capacitor.
      Ask FixBot
    3. Acer AL2216W Capacitor Replacement, Remove the stand: step 3, image 1 of 2 Acer AL2216W Capacitor Replacement, Remove the stand: step 3, image 2 of 2
      • EET owners: Your kit has this bit. No purchase needed.
      • This monitor never came with a hinge cap. If yours has one, unclup the marks in black.
      • Remove the 4 screws from the monitor stand with a Philips #1 screwdriver. Remove the bottom screws first.
      Ask FixBot
    4. Acer AL2216W Capacitor Replacement, Remove the back of the monitor: step 4, image 1 of 2 Acer AL2216W Capacitor Replacement, Remove the back of the monitor: step 4, image 2 of 2
      • Sort this screw separately, as it is unique.
      • Remove 4 fine threaded screws from the back of the monitor with a Phillips #0 screwdriver. All of these screws are the same.
      Ask FixBot
    5. Acer AL2216W Capacitor Replacement, Unlatch the clips (Bottom): step 5, image 1 of 2 Acer AL2216W Capacitor Replacement, Unlatch the clips (Bottom): step 5, image 2 of 2
      Jimmy
      $7.95
      Buy
      • If the monitor has never been serviced, you may have to use a flathead screwdriver, Jimmy or a Heavy duty spudger. This will damage the plastic somewhat and is unavoidable. In some cases, you may be able to use a plastic pry tool instead of metal to avoid the damage, but not every time.
      • Open the monitor at the bottom of the monitor by releasing the four tabs with a flathead screwdriver or a Jimmy and plastic pry tool. If force is needed, the best way to do this is to put electrical tape on a flathead screwdriver and split the panels.
      Ask FixBot
    6. Acer AL2216W Capacitor Replacement, Unlatch the clips (Side): step 6, image 1 of 1
      • If you are having trouble doing this, use a pry tool. An unserviced monitor may not come up as easily.
      • With the monitor unclipped on the bottom, pull the sides of the monitor up. Do this slowly to avoid cracking the LCD.
      Ask FixBot
    7. Acer AL2216W Capacitor Replacement, Remove the IEC socket screws: step 7, image 1 of 1
      • After these screws are removed, the power supply will be exposed.
      • With the back of the monitor off, remove the 2 screws on the IEC power connector using a Phillips #0 screwdriver.
      Ask FixBot
    8. Acer AL2216W Capacitor Replacement, Remove the video connection screws: step 8, image 1 of 1
      Mako Driver Kit - Refurbished
      $31.95
      Buy
      • EET owners: Your bit does not have this kit. Step 1 covers the current recommendation (Pro Tech Go or HF toolkit). If you want a cheap way to augment an existing EET, the Hart 61 bit screwdriver kit (Standalone) (or the 31 bit version) is a well made low-cost driver kit that includes the required 5mm bit that I have personally tested. The Mako driver kit (Refurbished) or Moray driver kit also has the 5mm bit.
      • Needlenose plyers can be used in place of the nut driver. However, it will be hard to properly re-tighten the screws.
      • Remove the 4 screw pins for the video cables from the monitor. Use a 5mm Nut driver to remove the screw pins from the power supply shield.
      Ask FixBot
    9. Acer AL2216W Capacitor Replacement, Disconnect the backlight cables: step 9, image 1 of 2 Acer AL2216W Capacitor Replacement, Disconnect the backlight cables: step 9, image 2 of 2
      • Disconnect the CCFL cables from the power supply board.
      Ask FixBot
    10. Acer AL2216W Capacitor Replacement, Disconnect the button board: step 10, image 1 of 2 Acer AL2216W Capacitor Replacement, Disconnect the button board: step 10, image 2 of 2
      • Board removal is optional.
      • Disconnect the flat flex cable that goes to the control board.
      Ask FixBot
    11. Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 1): step 11, image 1 of 2 Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 1): step 11, image 2 of 2
      • Remove the 2 lower screws that hold the power supply shield to the monitor with a Phillips #0 screwdriver.
      Ask FixBot
    12. Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 2): step 12, image 1 of 3 Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 2): step 12, image 2 of 3 Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 2): step 12, image 3 of 3
      • The lower shield does not have to be removed. However, it will make disassembly easier.
      • On the right side of the monitor, remove the remaining Phillips #0 screws holding the board shield in place.
      • Lift the lower plate up while removing the power supply shield to remove it from the monitor. Once this is done, you will have access to the power supply.
      • Removing the lower shield (Optional): To remove the lower shield, release the black tabs holding it in place, and lift up. Do this for all the tabs holding it in place.
      Ask FixBot
    13. Acer AL2216W Capacitor Replacement, Remove the power supply: step 13, image 1 of 3 Acer AL2216W Capacitor Replacement, Remove the power supply: step 13, image 2 of 3 Acer AL2216W Capacitor Replacement, Remove the power supply: step 13, image 3 of 3
      • IF YOU ARE REPLACING THE FILTER CAPACITOR, IT MUST BE DISCHARGED BEFORE REMOVAL FOR SAFETY!
      • The black screw is a ground screw and must be placed in the same location when reassembling the monitor. The remaining 3 screws can be installed in any order when reinstalling the power supply.
      • Any bulged capacitors are likely to have a residual charge, and the power supply should be handed with this assumption in mind if you see any visibly bulged capacitors.
      • With the power supply shield removed from the monitor, identify the power supply. Take note of the printed values, including the inverter cap (if present).
      • Remove the 4 Phillips #1 screws from the power supply. Once this is done, lift up the power supply at a slight angle to clear the chassis. Do not lift too much or the connector may be damaged!
      • This capacitor is only found on older power supplies. Replacement is optional, but recommended.
      Ask FixBot
    14. Acer AL2216W Capacitor Replacement, (Optional) Capacitor polarity marking: step 14, image 1 of 1
      • If the PCB is marked to avoid mis-installation, the flux will wash these marks off.
      • If you are unsure of the position of the capacitors, mark the polarity with a permanent marker. If the capacitors are incorrectly installed, they will explode when power is applied.
      Ask FixBot
    15. Acer AL2216W Capacitor Replacement, Add flux to the capacitor leads: step 15, image 1 of 1
      • If you do not have flux on hand, solder can be used. Some flux is difficult to clean if overused.
      • To prepare the board for capacitor replacement, add flux or solder.
      Ask FixBot
    16. Acer AL2216W Capacitor Replacement, Remove the old capacitors: step 16, image 1 of 3 Acer AL2216W Capacitor Replacement, Remove the old capacitors: step 16, image 2 of 3 Acer AL2216W Capacitor Replacement, Remove the old capacitors: step 16, image 3 of 3
      • Use of a Helping Hands is recommended to avoid soldering iron contact. If you do not have one, hold the board at an angle.
      • While a partial replacement may work, the remaining capacitors will fail. It is best to do them all while servicing the failed ones. Refer to this guide for a soldering "how to".
      • Move to a workspace with ventilation or use a fume extractor. Once in an appropriate workspace, desolder the old capacitors. Heat up each leg and remove it.
      • After removing the capacitors, clean up the old solder with a desoldering braid. Lift it with the iron when removing it.
      Ask FixBot
    17. Acer AL2216W Capacitor Replacement, Installing brand new capacitors: step 17, image 1 of 1
      • Check the capacitor polarity before soldering the new capacitors in. Incorrectly installed capacitors will explode with power applied!
      • Install the new capacitors. Check the polarity and bend the leads so they do not come loose during installation.
      Ask FixBot
    18. Acer AL2216W Capacitor Replacement, Solder the new capacitors in: step 18, image 1 of 3 Acer AL2216W Capacitor Replacement, Solder the new capacitors in: step 18, image 2 of 3 Acer AL2216W Capacitor Replacement, Solder the new capacitors in: step 18, image 3 of 3
      • Once the polarity is verified, solder the capacitors in. After installation, cut off any excess lead.
      Ask FixBot
    19. Acer AL2216W Capacitor Replacement, Clean the flux off of the board: step 19, image 1 of 1
      • After verifying there are no cold solder joints, clean the board with 91%+ Isopropyl alcohol, or denatured alcohol.
      Ask FixBot
    20. Acer AL2216W Capacitor Replacement, Test the monitor: step 20, image 1 of 1
      • Put the monitor back together and test the repair.
      Ask FixBot
12 other people completed this guide.
Nick
106,443 Reputation
72 Guides authored
29 Guide Comments
I did not replace the large capacitor on the Acer monitor yet. All other caps have been replaced. I may have to replace the FSPO55- ZP102A as it has a hot spot beside it. I don't know if the part number is right? Do know where I can buy it. Tom B
Thomas Brady - Reply Share
These older CCFL panels usually burn on the PCB by the inverter coil and main transformer (the Delta branded part, in this case). The LED monitors limit the failure points to the transformer.
It sounds like your PCB got burned from the heat by the transformer or the inverter coil. This is very common and the boards are designed to take it. However, if you are concerned you should buy a new power supply board altogether if that makes you more comfortable.
Nick - Reply Share
In step 12, replacing the capacitors with ones with a different capacitance rating instead of using a capacitor rated for higher voltage makes no sense to me electrically. The capacitance rating is the important part, if you use a capacator rated for say 35 volts when the original is rated for 10 makes no difference whatsoever. the rating just means MAX voltage.
Brennan Gomolka - Reply Share
Thanks @nick! Just waiting for the parts to come in!
Aiden - Reply Share
@nick which one is the filter capacitor?
Aiden - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 163
All Time: 25,848
