Up to 20% off select tools
Constructing a Capacitor Discharge Tool
Views: 259K
View statistics:
Past 24 Hours:
61
Past 7 Days:
356
Past 30 Days:
1,669
All Time:
259,473
Comments: 19
3 comments on steps, 16 guide comments.
Go to guide comments
Completed: 161
161 people have marked this guide "completed." Will you be next?
Favorites: 156
156 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Capacitors are electronic components found in almost every device containing a circuit board. Large capacitors can store enough charge to cause injuries, so they must be discharged properly.
This guide will show you how to make a simple resistor-based capacitor discharge tool.
    1. Constructing a Capacitor Discharge Tool, Constructing a Capacitor Discharge Tool: step 1, image 1 of 1
      • To construct a capacitor discharge tool, first gather the necessary materials. These include:
      • Two lengths of wire. Minimum wire requirements is 12AWG, 600 volt rating for large electrolytic capacitors used in power supplies, electric motor start circuits and camera flash circuitry
      • A resistor rated to dissipate the amount of thermal energy created when discharging the capacitor. Minimum requirements for resistor is 2k OHM 5w for small capacitors, 20k OHM 5w for large electrolytic capacitors used in power supplies, electric motor start circuits and camera flash circuitry.
      • Shrink tubing
      Ask FixBot
    2. Constructing a Capacitor Discharge Tool: step 2, image 1 of 2 Constructing a Capacitor Discharge Tool: step 2, image 2 of 2
      • Begin the process by stripping one side end of each length of wire.
      • To ensure a solid solder joint, strip at least .25" of insulation off the wire.
      Ask FixBot
    3. Constructing a Capacitor Discharge Tool: step 3, image 1 of 2 Constructing a Capacitor Discharge Tool: step 3, image 2 of 2
      • Next, trim both of the leads leaving the resistor to match the length of insulation stripped off the wires in the previous step.
      Ask FixBot
    4. Constructing a Capacitor Discharge Tool: step 4, image 1 of 3 Constructing a Capacitor Discharge Tool: step 4, image 2 of 3 Constructing a Capacitor Discharge Tool: step 4, image 3 of 3
      Tool used on this step:
      FixHub Smart Soldering Iron
      $79.95
      Buy
      • Join the lead leaving the resistor to the stripped end of the wire by twisting the two together.
      • The wire we are using is quite thick, so we inserted the resistor lead down the center of the conductor portion of the wire and twisted the wire against it as tightly as possible.
      • Solder the wire to the resistor.
      • It is essential that enough solder flows through the wire to create a permanent bond between the two pieces.
      Ask FixBot
    5. Constructing a Capacitor Discharge Tool: step 5, image 1 of 2 Constructing a Capacitor Discharge Tool: step 5, image 2 of 2
      • Slide a section of shrink tubing up the wire, making sure to completely cover up the solder joint and any exposed wire.
      • Use a heat gun or lighter to shrink the tubing over the joint, making sure it is positioned to cover all exposed wire.
      Ask FixBot
    6. Constructing a Capacitor Discharge Tool: step 6, image 1 of 1
      • Repeat the above process for the other side of the resistor.
      • To complete the discharge tool, strip the ends of the wires.
      • To discharge from small points, it may be helpful to cut the exposed ends of wire into a point shape and solder them to maintain the shape. Alternatively, the probes commonly used on multimeters can be soldered to the wires to create a more precise discharge tool.
      • For large electrolytic capacitors used in power supplies, electric motor start circuits, and camera flash units, you may want to solder one end to a large alligator clip and the other to a well insulated screwdriver.
      Ask FixBot
Finish Line
161 other people completed this guide.
Author
with
16 Guide Comments
thank you !!! :)
Sufian Hamouda - Reply Share
This article is by far the best I've read. I have made these in the past and had to get past the amount of words used to describe what needed to be done with what. This article is straight to the point and the tips ( using alligator clip ) are excellent.
Paul Kriner - Reply Share
I get the basics and can build something more to fit my needs, with what you have instructed
puckhead22 - Reply Share
hi
i have one query, if it is possible to discharge the capacitor in 12V 1 A power supply..? if i cut of the power, the power supply discharge the power around 6 sec but i need to discharge it with in 1 sec ..? this is possible or Not...?
prakashkumar - Reply Share
Thank you! I have been looking for a good diy discharge probe....I also used overlapping large size heat shrink to strengthen the joint at the ceramic resistor to prevent failure at a bad time.
doorabull2 - Reply Share
Past 24 Hours: 61
Past 7 Days: 356
Past 30 Days: 1,669
All Time: 259,473
