Back Glass
3 Answers 0 Score |
Front cam not working after screen repair |
6 Answers 0 Score |
iPhone 15 pro Max randomly reboots |
2 Answers 0 Score |
Back Glass Replacement - Wireless Charging Coil Transfer? |
2 Answers 0 Score |
Is it possible to retrieve my photos if my phone won’t power up |
Documents
Parts
Tools
- Spudger
- iFixit Opening Picks (Set of 6)
- Tweezers
- Suction Handle
- Microfiber Cleaning Cloths
- Plastic Cards
- Heat Gun
- Cotton Swabs
- Phillips #000 Screwdriver
- Lint-Free Clean Room Wipes
- P2 Pentalobe Screwdriver iPhone
- Tri-point Y000 Screwdriver
- Standoff Screwdriver for iPhones
- IA-3952 - Max Professional Consumable Isopropyl Alcohol
Models
A2849 US, A3105 Canada/Mexico/Japan/Saudi Arabia, A3106 Global, A3108 China
Background
The iPhone 15 Pro Max was announced on September 12th, 2023, and released the week after on September 22nd. It has the same 6.7" Always-On ProMotion OLED as its 2022 predecessor, the iPhone 14 Pro Max, but has a new A17 Pro SoC—the first time Apple's used the "Pro" naming for iPhone chips. New for 2023, both the iPhone 15 Pro and 15 Pro Max come in titanium instead of stainless steel (specifically a Grade 5 alloy), sport USB-C ports as opposed to Lightning, and feature a new programmable Action Button in place of the ring/silent switch that Apple's used since the first iPhone.
The 15 Pro Max also features a camera system with a 48 MP Main camera, an Ultra Wide camera, and a new "tetraprism" 5x Telephoto camera. The iPhone Pro-line’s Dynamic Island, which has now been adopted by the vanilla iPhone 15 and 15 Plus, hides the top sensors and FaceTime camera in the display with a reactive black pill-shaped area.
The iPhone 15 Pro Max is priced at $1199 for a 256 GB model, available in one of four finishes: Black Titanium, White Titanium, Blue Titanium, or Natural Titanium.
Identification
You can identify the iPhone 15 Pro Max by the one of the following model numbers printed on the inside back of the USB-C (charge) port. Flip the iPhone over (with the screen facing away from you) to see it.
- A2849
- A3105
- A3106
- A3108
You can also find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
Additionally, Apple offers a quick online tool to help identify your devices: Identify your iPhone model.
The iPhone 15 Pro Max features a 6.7-inch (diagonal) flat glass screen, thin black bezels, a pill-shaped, black "dynamic island" at the top of the screen, matte back glass, and titanium side rails.
Volume controls and the new "Action Button" can be found on the left edge while the power button is situated on the right. A square camera "bump" containing three cameras protrudes from the back case. This model has no home button.
The iPhone 15 Pro Max can be differentiated from the iPhone 15 Pro by its larger 6.7-inch screen (relative to the 6.1-inch screen on the standard Pro model).
The iPhone 15 Pro Max can be differentiated from the previous generation iPhone 14 Pro Max by its titanium design, USB-C port, and side Action Button.
Technical Specifications
Dimensions: 159.9 × 76.7 × 8.25 mm (6.29 × 3.02 × 0.32 in)
Weight: 221 g (7.81 oz)
Water Resistance: IP68
Colors: Black Titanium, White Titanium, Blue Titanium, or Natural Titanium
Operating System: iOS 17
Processor: A17 Pro chip
- 6‑core CPU with 2 performance and 4 efficiency cores
- 6‑core GPU
- 16‑core Neural Engine
RAM: 8 GB
Storage: 256, 512 GB, or 1 TB
Battery: 4422 mAh, up to 29 hours of video playback
Ports: 1x USB-C connector
- Charging
- Reverse charging of accessories
- DisplayPort
- USB 3 data transfer (up to 10 Gb/s)
Display:
- 6.7-inch “Super Retina XDR” OLED
- Ceramic Shield glass technology
- Multi‑touch
- Haptic Touch
- 2796 × 1290 pixel resolution (460 ppi)
- 2,000,000:1 contrast ratio (typical)
- True Tone
- P3 wide color gamut
- 1000 nits max brightness, 1600 nits peak (HDR), 2000 nits peak (outdoor)
- Fingerprint-resistant oleophobic coating
- Dynamic Island
Pro camera system:
- Main module
- 48 MP
- 24 mm, ƒ/1.78 aperture
- Sensor-shift optical image stabilization (OIS)
- Autofocus with 100% Focus Pixels
- Ultra-wide module (120° field of view)
- 12 MP
- 13 mm, ƒ/2.2 aperture
- Telephoto (5x)
- 12 MP
- 120 mm, ƒ/2.8 aperture
- 3D sensor-shift optical image stabilization (OIS)
- tetraprism design
TrueDepth selfie camera with Face ID:
- 12 MP
- ƒ/1.9 aperture
- ProRes video up to 4K at 60 fps
- Retina Flash
Sensors:
- Face ID
- LiDAR scanner
- Barometer
- High dynamic range gyro
- High-g accelerometer (Crash Detection)
- Proximity sensor
- Dual ambient light sensors
Wireless Connectivity:
- 802.11ax Wi‑Fi 6E with 2x2 MIMO
- 5G, sub-6 GHz and mmWave (all models)
- Gigabit LTE with 4x4 MIMO and LAA (all models)
- Bluetooth 5.3
- Second-generation Ultra Wideband chip
- Thread networking technology
- NFC with reader mode
- Express Cards with power reserve
