Up to 20% off select tools
iPhone 15 Pro Max Back Glass Replacement
Views: 126K
View statistics:
Past 24 Hours:
107
Past 7 Days:
899
Past 30 Days:
4,127
All Time:
125,806
Comments: 38
32 comments on steps, 6 guide comments.
Go to guide comments
Completed: 55
55 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove or replace a cracked or broken back glass on your iPhone 15 Pro Max.
You'll need replacement back glass adhesive to complete this repair.
    1. iPhone 15 Pro Max Back Glass Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 15 Pro Max Back Glass Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. iPhone 15 Pro Max Back Glass Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Pro Max Back Glass Replacement, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    1. iPhone 15 Pro Max Back Glass Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Mark your opening picks: step 3, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 15 Pro Max Back Glass Replacement, Remove the pentalobe screws: step 4, image 1 of 1
      • Use a P2 pentalobe driver to remove the two 7.2 mm-long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 15 Pro Max Back Glass Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    2. iPhone 15 Pro Max Back Glass Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. iPhone 15 Pro Max Back Glass Replacement, Back glass information: step 7, image 1 of 1
      • As you slice the adhesive securing the back glass in the next steps, be careful of the wireless charging cable near the volume buttons.
      Ask FixBot
    4. iPhone 15 Pro Max Back Glass Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
      • Don't insert your opening pick deeper than 5 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. iPhone 15 Pro Max Back Glass Replacement, Heat the left edge: step 9, image 1 of 1
      • Heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    6. iPhone 15 Pro Max Back Glass Replacement, Separate the left edge adhesive: step 10, image 1 of 2 iPhone 15 Pro Max Back Glass Replacement, Separate the left edge adhesive: step 10, image 2 of 2
      • Don't insert your pick deeper than 5 mm along the left edge.
      • Insert a second opening pick to the left of the first one.
      • Slide this pick to the top left corner of the back glass to separate the left edge adhesive.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone 15 Pro Max Back Glass Replacement, Heat the top edge: step 11, image 1 of 1
      • Heat the top edge of the back glass until it's hot to the touch.
      Ask FixBot
    8. iPhone 15 Pro Max Back Glass Replacement, Separate the top edge adhesive: step 12, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Separate the top edge adhesive: step 12, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Separate the top edge adhesive: step 12, image 3 of 3
      • Don't insert your pick deeper than 5 mm along the top edge.
      • Insert a third opening pick in the top left corner of the back glass.
      • Slide your pick to the top right corner to separate the top edge adhesive.
      • If the top edge of the back glass doesn't separate, the top clips may be stuck. Use the flat end of a spudger to press the clips inward until they release.
      Ask FixBot
    9. iPhone 15 Pro Max Back Glass Replacement, Separate the top right corner adhesive: step 13, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Separate the top right corner adhesive: step 13, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Separate the top right corner adhesive: step 13, image 3 of 3
      • Don't slide your pick past the volume up button to avoid slicing the wireless charging cable.
      • Rotate your pick around the top right corner of the back glass.
      • Slide your pick to the volume up button.
      • Leave this pick in place to prevent the adhesive from resealing.
      Ask FixBot
    10. iPhone 15 Pro Max Back Glass Replacement, Heat the right edge: step 14, image 1 of 1
      • Heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    11. iPhone 15 Pro Max Back Glass Replacement, Separate the right edge adhesive: step 15, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Separate the right edge adhesive: step 15, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Separate the right edge adhesive: step 15, image 3 of 3
      • Don't slide your pick past the volume down button to avoid slicing the wireless charging cable.
      • Insert a fourth opening pick at the bottom edge of the back glass.
      • Rotate your pick around the bottom right corner of the back glass.
      • Slide your pick to the volume down button.
      Ask FixBot
    12. iPhone 15 Pro Max Back Glass Replacement, Swing open the back glass: step 16, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Swing open the back glass: step 16, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Swing open the back glass: step 16, image 3 of 3
      • Gently swing open the back glass over the right edge of the phone.
      • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      • Rest the back glass against a box or similar object so it doesn't strain the cable.
      Ask FixBot
    13. iPhone 15 Pro Max Back Glass Replacement, Remove the wireless charging connector cover: step 17, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Remove the wireless charging connector cover: step 17, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Remove the wireless charging connector cover: step 17, image 3 of 3
      Tool used on this step:
      Buy
      • Use a tri-point Y000 driver to remove the 1.0 mm‑long screw securing the wireless charging connector cover.
      • Use tweezers to slide the cover out of its slot on the logic board and remove it.
      Ask FixBot
    14. iPhone 15 Pro Max Back Glass Replacement, Disconnect the wireless charging coil: step 18, image 1 of 2 iPhone 15 Pro Max Back Glass Replacement, Disconnect the wireless charging coil: step 18, image 2 of 2
      • Use the tip of an opening pick to pry up and disconnect the wireless charging coil press connector.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
      Ask FixBot
    15. iPhone 15 Pro Max Back Glass Replacement, Remove the back glass: step 19, image 1 of 2 iPhone 15 Pro Max Back Glass Replacement, Remove the back glass: step 19, image 2 of 2
      • Remove the back glass.
      Ask FixBot
    1. iPhone 15 Pro Max Back Glass Replacement, Disassembly complete: step 20, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps show how to reassemble the iPhone.
      • Depending on your iPhone model, some reassembly photos may have minor visual discrepancies. The procedure will be correct.
      Ask FixBot
    1. iPhone 15 Pro Max Back Glass Replacement, Remove the back glass adhesive: step 21, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Remove the back glass adhesive: step 21, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Remove the back glass adhesive: step 21, image 3 of 3
      • The back glass adhesive is very sticky may take a while to remove.
      • Use the point of a spudger to ball up a larger section of adhesive and remove it from the frame.
      • If the adhesive is stubborn, warm it up with a hair dryer or heat gun to soften it.
      • Repeat this process until all the larger strips of adhesive are removed.
      Ask FixBot
    2. iPhone 15 Pro Max Back Glass Replacement: step 22, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement: step 22, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement: step 22, image 3 of 3
      iFixit Adhesive Remover
      $19.99
      Buy
      • Apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol to a cotton swab or coffee filter.
      • Wipe the residual adhesive off the frame.
      Ask FixBot
    3. iPhone 15 Pro Max Back Glass Replacement: step 23, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement: step 23, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement: step 23, image 3 of 3
      $19.99
      Buy
      • Apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol to a clean lint‑free cloth or coffee filter and wipe all residual adhesive off the frame to prep the surface for the new adhesive.
      Ask FixBot
    4. iPhone 15 Pro Max Back Glass Replacement, Orient the replacement adhesive: step 24, image 1 of 1
      • Without peeling any liners, lay the adhesive sheet over the frame to determine its orientation.
      • Use features such as the camera cutout and notches along the edges to visualize how the adhesive will lay on the frame.
      Ask FixBot
    5. iPhone 15 Pro Max Back Glass Replacement, Apply the replacement adhesive: step 25, image 1 of 1
      • Grab the large tab in the bottom corner of the adhesive sheet and begin peeling off the liner that exposes the side that sticks to the frame. Don't remove it all the way.
      • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
      • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
      Ask FixBot
    6. iPhone 15 Pro Max Back Glass Replacement: step 26, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement: step 26, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement: step 26, image 3 of 3
      • Once the adhesive is set into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
      • When the adhesive is aligned, set it down along the bottom edge.
      Ask FixBot
    7. iPhone 15 Pro Max Back Glass Replacement: step 27, image 1 of 2 iPhone 15 Pro Max Back Glass Replacement: step 27, image 2 of 2
      • Use the flat end of a spudger to press the adhesive into place along the bottom edge.
      Ask FixBot
    8. iPhone 15 Pro Max Back Glass Replacement: step 28, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement: step 28, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement: step 28, image 3 of 3
      • Continue peeling the back liner off of the adhesive and setting the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If you don't have another one handy, it's okay to put your iPhone back together without adhesive, but keep in mind that it won't be water resistant until you install new adhesive.
      Ask FixBot
    9. iPhone 15 Pro Max Back Glass Replacement, Press the adhesive into place: step 29, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Press the adhesive into place: step 29, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Press the adhesive into place: step 29, image 3 of 3
      • Use the flat end of a spudger to press the adhesive into place all around the iPhone.
      Ask FixBot
    10. iPhone 15 Pro Max Back Glass Replacement, Remove the top liner: step 30, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Remove the top liner: step 30, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Remove the top liner: step 30, image 3 of 3
      • Lift the pull tab in the top‑right corner of the frame to peel off the top liner and remove it.
      • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners along the edges.
      Ask FixBot
    11. iPhone 15 Pro Max Back Glass Replacement, Adhesive information: step 31, image 1 of 1
      • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
      • Your pull tabs may be in different positions.
      • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. Be careful not to touch anything to the exposed adhesive.
      Ask FixBot
    12. iPhone 15 Pro Max Back Glass Replacement, Align the back glass: step 32, image 1 of 2 iPhone 15 Pro Max Back Glass Replacement, Align the back glass: step 32, image 2 of 2
      • Set the back glass on the right edge of the iPhone frame and use one hand to hold it in place.
      Ask FixBot
    13. iPhone 15 Pro Max Back Glass Replacement, Connect the back glass: step 33, image 1 of 2 iPhone 15 Pro Max Back Glass Replacement, Connect the back glass: step 33, image 2 of 2
      • Use the flat end of a spudger or your finger to connect the back glass press connector.
      Ask FixBot
    14. iPhone 15 Pro Max Back Glass Replacement, Install the wireless charging connector cover: step 34, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Install the wireless charging connector cover: step 34, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Install the wireless charging connector cover: step 34, image 3 of 3
      • Use tweezers to slide the tab on the wireless charging connector cover into its slot on the board and set it into place.
      • Use a tri-point Y000 driver to install the 1.0 mm‑long screw securing the wireless charging connector cover.
      Ask FixBot
    15. iPhone 15 Pro Max Back Glass Replacement, Remove the final adhesive liners: step 35, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Remove the final adhesive liners: step 35, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Remove the final adhesive liners: step 35, image 3 of 3
      • Hold the back glass over the phone so you can access the narrow liner covering the adhesive on the right edge of the frame.
      • Use tweezers to remove the narrow liner on the right edge.
      Ask FixBot
    16. iPhone 15 Pro Max Back Glass Replacement: step 36, image 1 of 2 iPhone 15 Pro Max Back Glass Replacement: step 36, image 2 of 2
      • Remove the remaining narrow liners to fully expose the back glass adhesive.
      Ask FixBot
    17. iPhone 15 Pro Max Back Glass Replacement, Install the back glass: step 37, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Install the back glass: step 37, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Install the back glass: step 37, image 3 of 3
      • Align the back glass over the frame and press it into place.
      Ask FixBot
    18. iPhone 15 Pro Max Back Glass Replacement: step 38, image 1 of 2 iPhone 15 Pro Max Back Glass Replacement: step 38, image 2 of 2
      • Firmly press along the edges of the phone to compress the adhesive and engage the clips.
      Ask FixBot
    19. iPhone 15 Pro Max Back Glass Replacement, Install the pentalobe screws: step 39, image 1 of 1
      • Use a P2 pentalobe screwdriver to install the two 7 mm‑long screws on either side of the charging port.
      Ask FixBot
    20. iPhone 15 Pro Max Back Glass Replacement, Heat the back glass: step 40, image 1 of 2 iPhone 15 Pro Max Back Glass Replacement, Heat the back glass: step 40, image 2 of 2
      • To help the adhesive bond, apply heat to the edges of the back glass using a hair dryer or heat gun until it's hot to the touch.
      Ask FixBot
    1. iPhone 15 Pro Max Back Glass Replacement, Press the back glass: step 41, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement, Press the back glass: step 41, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement, Press the back glass: step 41, image 3 of 3
      • To evenly compress the iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
      • If you have the iPhone's original box, take the lid and place it on a flat surface.
      • If you don't have the original box, skip this step for an alternate method.
      • Place the iPhone screen-side-up in the lid of the box with the camera bump in its recess.
      • Find something close to the size of the iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
      • Leave the objects in place for at least thirty minutes, ideally overnight.
      Ask FixBot
    2. iPhone 15 Pro Max Back Glass Replacement: step 42, image 1 of 3 iPhone 15 Pro Max Back Glass Replacement: step 42, image 2 of 3 iPhone 15 Pro Max Back Glass Replacement: step 42, image 3 of 3
      • If you don't have the iPhone's original box, follow the these two steps for another method to evenly compress the screen.
      • Place the iPhone screen-side-down on a soft, flat surface.
      • Apply tape to the back glass to protect its finish.
      • Place three layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
      Ask FixBot
    3. iPhone 15 Pro Max Back Glass Replacement: step 43, image 1 of 1
      • Stack multiple books or other heavy objects on your iPhone.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      Ask FixBot
Congratulations on finishing the repair!
If you have trouble with wireless charging, try running Apple’s Repair Assistant.
Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
55 other people completed this guide.
Author
with
Clay Eickemeyer
109,670 Reputation
471 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
6 Guide Comments
Is there a recommended source for getting a new back glass? Either OEM or non-OEM.
Taylor - Reply Share
I’m looking for the same answer can’t find oem quality back glass of iphone
Shehroz Shehzad - Reply Share
Great instructions, but where do we get a new replacement back glass from? Please suggest.
rubenhak - Reply Share
Apple's OEM parts are available through SelfServiceRepair.com, including the back glass for this iPhone. None of the aftermarket stores I'd generally recommend carry this part, but it looks like there's quite a few options on marketplace sites. The best advice I can give there is to look at seller reviews, and when possible, feedback for that specific part. Best of luck!
Nick Schultz - Reply Share
怎么在不更换无线充线圈的情况下更换后壳
menglei Ren - Reply Share
Past 24 Hours: 107
Past 7 Days: 899
Past 30 Days: 4,127
All Time: 125,806
