Up to 20% off select tools
Documents
Models
A2846 US, A3089 Canada/Mexico/Japan/Saudi Arabia, A3090 Global, A3092 China
Background
Apple's "vanilla" iPhone 15 was announced on September 12th, 2023, and released the week after on September 22nd. It features a 6.1" OLED, inherits the Dynamic Island and the A16 Bionic SoC from 2022's iPhone 14 Pro and 14 Pro Max, and features an improved dual-camera system with a 48 MP Main camera and a 12 MP Ultra Wide camera.
Notably, the iPhone 15, 15 Plus, 15 Pro, and 15 Pro Max are the first iPhones to ship with USB-C—marking only the second time Apple has switched ports on its iPhones, the first being the iPhone 5's switch to Lightning from the 30-pin connector in 2012. However, the non-Pro 15 and 15 Plus models only support USB 2 speeds—the same as outgoing Lightning.
The iPhone 15 is priced at $799 for a 128 GB model, available in one of five colors: Black, Blue, Green, Yellow, or Pink.
Identification
You can identify the iPhone 15 by the one of the following model numbers printed on the inside back of the USB-C (charge) port. Flip the iPhone over (with the screen facing away from you) to see it.
  • A2846
  • A3089
  • A3090
  • A3092
You can also find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
Additionally, Apple offers a quick online tool to help identify your devices: Identify your iPhone model.
The iPhone 15 features a 6.1-inch (diagonal) flat glass screen, thin black bezels, a pill-shaped, black "dynamic island" at the top of the screen, matte back glass, and colored aluminum side rails.
Volume controls and the ring/silent switch can be found on the left edge while the power button is situated on the right. A square camera "bump" containing two cameras protrudes from the back case. This model has no home button.
The iPhone 15 can be differentiated from the iPhone 15 Pro by its colorful aluminum design and dual-camera array (relative to the more muted metal finishes and triple-camera array of the Pro, respectively).
The iPhone 15 can be differentiated from the previous generation iPhone 14 by its USB-C charging port and Dynamic Island.
Technical Specifications
Dimensions: 147.6 × 71.6 × 7.80 mm (5.81 × 2.82 × 0.31 in)
Weight: 171 g (6.02 oz)
Water Resistance: IP68
Colors: Black, Blue, Green, Yellow, or Pink
Operating System: iOS 17
Processor: A16 Bionic chip
  • 6‑core CPU with 2 performance and 4 efficiency cores
  • 5‑core GPU
  • 16‑core Neural Engine
RAM: 6 GB
Storage: 128, 256, or 512 GB
Battery: 3349 mAh, up to 20 hours of video playback
Ports: 1x USB-C connector
  • Charging
  • Reverse charging of accessories
  • DisplayPort
  • USB 2 data transfer (up to 480 Mb/s)
Display:
  • 6.1-inch “Super Retina XDR” OLED
  • Ceramic Shield glass technology
  • Multi‑touch
  • Haptic Touch
  • 2556 × 1179 pixel resolution (460 ppi)
  • 2,000,000:1 contrast ratio (typical)
  • True Tone
  • P3 wide color gamut
  • 1000 nits max brightness, 1600 nits peak (HDR), 2000 nits peak (outdoor)
  • Fingerprint-resistant oleophobic coating
  • Dynamic Island
Camera system:
  • Main module
    • 48 MP
    • 26 mm, ƒ/1.6 aperture
    • Sensor-shift optical image stabilization (OIS)
    • Autofocus with 100% Focus Pixels
  • Ultra-wide module (120° field of view)
    • 12 MP
    • 13 mm, ƒ/2.4 aperture
TrueDepth selfie camera with Face ID:
  • 12 MP
  • ƒ/1.9 aperture
  • 4K video up to 60 fps
  • Retina Flash
Sensors:
  • Face ID
  • Barometer
  • High dynamic range gyro
  • High-g accelerometer (Crash Detection)
  • Proximity sensor
  • Dual ambient light sensors
Wireless Connectivity:
  • 802.11ax Wi‑Fi 6 with 2x2 MIMO
  • 5G, sub-6 GHz and mmWave (all models)
  • Gigabit LTE with 4x4 MIMO and LAA (all models)
  • Bluetooth 5.3
  • Second-generation Ultra Wideband chip
  • NFC with reader mode
  • Express Cards with power reserve
Additional Information
Author
with
Jacob Mehnert
50,876 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
71 Members
1,152 Guides authored
Past 24 Hours: 327
Past 7 Days: 1,838
Past 30 Days: 8,532
All Time: 230,834
