Introduction
Go to step 1 ↓Use this guide to replace the Taptic Engine in your iPhone 15.
If the vibrations coming from your phone feel rattly or are intermittent, you might need to replace the Taptic Engine.
You'll need replacement back glass adhesive to complete this repair.
Unplug any cables from your phone.
Hold the power and either volume buttons and slide to power off your phone.
If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
Use a P2 pentalobe driver to remove the two 7.7Â mm-long screws on either side of the charging port.
Measure 3Â mm from the tip and mark the opening pick with a permanent marker.
Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
Apply a suction handle to the bottom edge of the back glass.
Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
Insert the tip of an opening pick into the gap.
There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
Slide your pick back and forth along the bottom edge to separate the adhesive.
Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
Leave this pick inserted to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge.
Rotate the second pick around the bottom left corner.
Slide this pick up to the top left corner to separate the adhesive.
Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
Leave this pick in place to prevent the adhesive from resealing.
Heat the top right corner of the back glass until it's hot to the touch.
Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
Gently lift and swing open the back glass to the right of the phone.
Rest the back glass against a raised surface so it doesn't strain the cable.
Tool used on this step:FixMat$31.41
Use a tri-point Y000 driver to remove the two 1.3Â mm-long screws securing the lower connector cover.
Tool used on this step:Tweezers$4.99
Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
Remove the cover.
Hold the back glass upright with one hand and rotate it just enough to reveal the battery press connector just below the volume buttons.
Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
Use your tri-point Y000 driver to remove the 0.9Â mm-long screw securing the middle connector cover.
Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
Remove the cover.
Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
Use your Phillips #000 driver to remove the two 1.9 mm‑long screws securing the Taptic Engine press connector cover.
Remove the cover.
Use the point of your spudger to pry up and disconnect the Taptic Engine press connector.
Use your Phillips #000 driver to remove the 1.9 mm‑long screw securing the Taptic Engine.
Use tweezers or your fingers to remove the Taptic Engine.
Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
Use a Phillips #000 driver to install the 1.9 mm‑long screw securing the Taptic Engine.
Use the flat end of a spudger to connect the Taptic Engine press connector.
Place the cover over the Taptic Engine connector.
Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
Use the tweezers to pull the adhesive off of the phone.
Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
Lay the adhesive next to the phone and use features like cutouts for spring contacts and the rear camera to make sure the adhesive is oriented correctly.
Use the pull tab to begin peeling the back liner off the adhesive starting from the bottom, but don't remove the liner all the way.
Hold the liner out of the way and align the adhesive with the bottom edge of the iPhone.
Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
Make sure the liner is aligned properly by checking that all spring contacts and the rear camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
Prop up the back glass along the right edge of the iPhone, using a box or similar sturdy object to support the screen.
Use the flat end of a spudger or your finger to connect the wireless charging coil press connector, then the battery press connector.
Place the middle connector cover over the wireless charging coil press connector so it slightly overhangs the slot on the logic board for the bottom clip.
Use your finger to press the cover down on the logic board.
While pressing it down, slide the cover upward so both metal clips slot into their spots in the logic board.
Use tweezers to hook the top of the lower connector cover into its slot on the logic board.
Lay the lower connector cover over the press connectors.
Use a tri-point Y000 screwdriver to install the 0.9 mm‑long screw securing the middle connector cover.
Use a tri-point Y000 screwdriver to install the two 1.3 mm‑long screws securing the lower connector cover.
Use tweezers or your fingers to separate the pull tabs at the bottom of the frame, near the charging port.
Lay the back glass straight down onto the frame and press until the clips engage.
Press around the perimeter of the back glass to engage all the clips.
Use a P2 pentalobe driver to install the two 7.7 mm‑long screws on either side of the charging port.
To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
Firmly press around the perimeter of the back glass. If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
If you have the box your iPhone came in, take the lid and place it on a flat surface.
Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
4 other people completed this guide.
3 Guide Comments
Wo bekomme ich denn den Kleber inkl. Schablone her, den ich zuvor mit dem Alkohol entfernt habe?
