Battery
2 Answers 3 Score |
iPhone 14 Pro Max restarts randomly after screen repair |
1 Answer 1 Score |
SMC PANIC failure, TB0T TB0V |
4 Answers 13 Score |
How to remove iCloud Activation Lock? |
2 Answers 3 Score |
iPhone restarting every 3 minutes? |
Documents
Parts
- iPhone 14 Pro Max Battery
- iPhone 14 Pro Max Screen
- iPhone 14 Pro/14 Pro Max Rear Camera Lens Covers
- iPhone 14 Pro Max Display Assembly Adhesive
- iPhone 14 Pro Max Lightning Connector Assembly
- iPhone 14 Pro Max Battery Adhesive Strips
- Lightning to USB Charging Cable
- Grip Glass Ultra iPhone 14 Pro Max Screen Protector
Tools
- Clampy - Anti-Clamp
- Spudger
- iOpener
- iFixit Opening Picks (Set of 6)
- Tweezers
- Suction Handle
- Microfiber Cleaning Cloths
- Phillips #00 Screwdriver
- iFixit Adhesive Remover
- Heat Gun
- Phillips #000 Screwdriver
- iFixit Safety Glasses
- P2 Pentalobe Screwdriver iPhone
- Tri-point Y000 Screwdriver
- Standoff Screwdriver for iPhones
- SIM Card Eject Tool
- iHold EVO
- IA-3952 - Max Professional Consumable Isopropyl Alcohol
Models
A2651 US, A2893 Canada/Mexico/Japan/Saudi Arabia, A2894 Global, A2895 Russia, A2896 China
Wallpapers
Get your free iPhone 14 Pro Max wallpapers! Choose from iFixit or Creative Electron (X-ray) versions. Looking for more? Check out our other wallpaper posts!
Background
The iPhone 14 Pro Max was announced on September 7th, 2022, and released the week after—on September 16th. It has a 6.7" Always-On ProMotion OLED and the new A16 Bionic chip. The Pro Max also features a Pro Camera System with a 48 MP Main camera, an Ultra Wide, and Telephoto camera as well as a larger aperture across. The iPhone Pro-line’s Dynamic Island hides the top sensors and facetime camera on the display with a reactive black pill-shaped area.
Identification
You can identify the iPhone 14 Pro Max by the one of the following model numbers printed on the inside back of the Lightning (charge) port. Flip the iPhone over (with the screen facing away from you) to see it.
- A2651
- A2893
- A2894
- A2895
- A2896
You can also find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
The iPhone 14 Pro Max features a 6.7 in (diagonal) flat glass screen, thin black bezels, and a new "dynamic island" at the top of the screen to accommodate sensors and the front facing camera. The back cover is glass and the edge frame is made from flat stainless steel.
Volume controls and the SIM tray can be found on the left edge while the power button is situated on the right. A rectangular camera "bump" containing three cameras in a triagonal layout protrudes slightly from the back case. This model has no home button.
The iPhone 14 Pro Max can be differentiated from the iPhone 14 Pro by the 6.7 in screen (relative to the 6.1 in screen on the standard Pro model).
Technical Specifications
Dimensions: 160.7 × 77.6 × 7.85 mm (6.33 × 3.05 × 0.31 in)
Weight: 240 g (8.47 oz)
Water Resistance: IP68
Colors: Space Black, Silver, Gold, or Deep Purple
Operating System: iOS 16
Processor: A16 Bionic chip
- 6‑core CPU with 2 performance and 4 efficiency cores
- 5‑core GPU
- 16‑core Neural Engine
RAM: 6 GB
Storage: 128, 256, 512 GB, or 1 TB
Battery: 4323 mAh, 16.68 Wh
Display:
- 6.7-inch “Super Retina XDR” OLED
- Ceramic Shield glass technology
- Multi‑touch
- Haptic Touch
- 2796 × 1290 pixel resolution (460 ppi)
- 2,000,000:1 contrast ratio (typical)
- True Tone
- P3 wide color gamut
- 1000 nits max brightness, 1600 nits peak (HDR), 2000 nits peak (outdoor)
- Fingerprint-resistant oleophobic coating
Pro camera system:
- Main module
- 48 MP
- ƒ/1.78 aperture
- Sensor-shift optical image stabilization (OIS)
- Autofocus with 100% Focus Pixels
- Seven-element lens
- Ultra-wide module (120° field of view, 2x optical zoom)
- 12 MP
- ƒ/2.2 aperture
- Six-element lens
- Telephoto (3x)
- 12 MP
- ƒ/2.8 aperture
- Six-element lens
TrueDepth selfie camera with Face ID:
- 12 MP
- ƒ/1.9 aperture
- ProRes video up to 4K at 30 fps
- Six‑element lens
- Retina Flash
Sensors:
- Face ID
- Barometer
- High dynamic range gyro
- High-g accelerometer (Crash Detection)
- Proximity sensor
- LiDAR
- Dual ambient light sensor
Wireless Connectivity:
- 802.11ax Wi‑Fi 6 with 2x2 MIMO
- 5G (sub-6 GHz in all models, mmWave only US-model)
- Gigabit LTE with 4x4 MIMO (LAA only US-model)
- Bluetooth 5.3
- Apple-designed U1 Ultra Wideband chip for spatial awareness
- NFC with reader mode
- Express Cards with power reserve
Additional Information
- Official Apple page: iPhone 14 Pro Max
