Up to 20% off select tools
iPhone 14 Pro Max Screen Replacement
Views: 224K
View statistics:
Past 24 Hours:
194
Past 7 Days:
1,127
Past 30 Days:
5,321
All Time:
224,037
Comments: 62
43 comments on steps, 19 guide comments.
Go to guide comments
Completed: 60
60 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
  • iPhone 14 Pro Max Screen
    4.5
Parts
Tools
Introduction
Go to step 1 ↓
If your iPhone 14 Pro Max screen is cracked, not responding to touch, or not showing a picture when your phone is powered on, use this guide to restore your iPhone to working order with a new screen, a.k.a. display assembly.
This guide was created using the A2894 (international) model. If you're fixing a different iPhone 14 model, there may be some visual discrepancies, but the procedure should be the same.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Note: On iOS 17.6 and earlier, True Tone and auto brightness functionality is disabled after a screen replacement, even when using an original Apple screen. Face ID is also disabled, unless the iPhone is running iOS 15.2 or newer. On the latest iOS version, you can calibrate your new screen using Apple's Repair Assistant to restore True Tone functionality. This may happen automatically.
You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
    1. iPhone 14 Pro Max Screen Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 14 Pro Max Screen Replacement, Remove the pentalobe screws: step 1, image 2 of 2
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
      Ask FixBot
    1. iPhone 14 Pro Max Screen Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 14 Pro Max Screen Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 14 Pro Max Screen Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 14 Pro Max Screen Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 14 Pro Max Screen Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 14 Pro Max Screen Replacement, Tape over any cracks: step 3, image 3 of 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone 14 Pro Max Screen Replacement, Screen damage warning: step 4, image 1 of 3 iPhone 14 Pro Max Screen Replacement, Screen damage warning: step 4, image 2 of 3 iPhone 14 Pro Max Screen Replacement, Screen damage warning: step 4, image 3 of 3
      • To avoid damaging your screen in the next steps, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll damage the screen.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive. In this case, you’ll most likely need to replace your entire screen.
      Ask FixBot
    3. iPhone 14 Pro Max Screen Replacement, Anti-Clamp instructions: step 5, image 1 of 3 iPhone 14 Pro Max Screen Replacement, Anti-Clamp instructions: step 5, image 2 of 3 iPhone 14 Pro Max Screen Replacement, Anti-Clamp instructions: step 5, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    4. iPhone 14 Pro Max Screen Replacement: step 6, image 1 of 3 iPhone 14 Pro Max Screen Replacement: step 6, image 2 of 3 iPhone 14 Pro Max Screen Replacement: step 6, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. iPhone 14 Pro Max Screen Replacement: step 7, image 1 of 3 iPhone 14 Pro Max Screen Replacement: step 7, image 2 of 3 iPhone 14 Pro Max Screen Replacement: step 7, image 3 of 3
      • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
      • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next two steps.
      Ask FixBot
    6. iPhone 14 Pro Max Screen Replacement, Heat the bottom edge: step 8, image 1 of 1
      • If you're using a suction handle, follow the next two steps to loosen the screen.
      • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the screen is slightly too hot to touch.
      • Never leave your heat gun in one spot for an extended period of time.
      Ask FixBot
    7. iPhone 14 Pro Max Screen Replacement, Insert an opening pick: step 9, image 1 of 3 iPhone 14 Pro Max Screen Replacement, Insert an opening pick: step 9, image 2 of 3 iPhone 14 Pro Max Screen Replacement, Insert an opening pick: step 9, image 3 of 3
      • Apply a suction handle to the bottom edge of the screen, while avoiding the very edge of the glass.
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • Insert an opening pick into the gap under the screen's plastic bezel.
      • The adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
      Ask FixBot
    8. iPhone 14 Pro Max Screen Replacement, Heat the right edge: step 10, image 1 of 2 iPhone 14 Pro Max Screen Replacement, Heat the right edge: step 10, image 2 of 2
      • Heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
      Ask FixBot
    9. iPhone 14 Pro Max Screen Replacement, Separate the right adhesive: step 11, image 1 of 3 iPhone 14 Pro Max Screen Replacement, Separate the right adhesive: step 11, image 2 of 3 iPhone 14 Pro Max Screen Replacement, Separate the right adhesive: step 11, image 3 of 3
      • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
      • Continue sliding up the right edge of the iPhone until you reach the top right corner.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      • Leave the pick in the top right corner before continuing.
      Ask FixBot
    10. iPhone 14 Pro Max Screen Replacement, Heat the top edge: step 12, image 1 of 1
      • Heat the top edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    11. iPhone 14 Pro Max Screen Replacement, Slice the top edge adhesive: step 13, image 1 of 3 iPhone 14 Pro Max Screen Replacement, Slice the top edge adhesive: step 13, image 2 of 3 iPhone 14 Pro Max Screen Replacement, Slice the top edge adhesive: step 13, image 3 of 3
      • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and half way across the top edge stopping right before the earpiece speaker cut-out.
      • Don't insert your pick more than 3 mm, as you may damage the top sensors.
      Ask FixBot
    12. iPhone 14 Pro Max Screen Replacement, Heat the left edge: step 14, image 1 of 2 iPhone 14 Pro Max Screen Replacement, Heat the left edge: step 14, image 2 of 2
      • Heat the left edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    13. iPhone 14 Pro Max Screen Replacement, Slice the left edge adhesive: step 15, image 1 of 3 iPhone 14 Pro Max Screen Replacement, Slice the left edge adhesive: step 15, image 2 of 3 iPhone 14 Pro Max Screen Replacement, Slice the left edge adhesive: step 15, image 3 of 3
      • There are delicate cables along the left edge of your iPhone. Don't insert your pick deeper than 2 mm here, as you may damage the cables.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the adhesive.
      • If you're having trouble separating the adhesive, reheat the left edge.
      Ask FixBot
    14. iPhone 14 Pro Max Screen Replacement, Open the iPhone: step 16, image 1 of 3 iPhone 14 Pro Max Screen Replacement, Open the iPhone: step 16, image 2 of 3 iPhone 14 Pro Max Screen Replacement, Open the iPhone: step 16, image 3 of 3
      • Rotate your iPhone so the right edge faces you.
      • Open your iPhone by swinging the screen up from the right side, like the front cover of a book.
      • Lean the screen against something to keep it propped up while you're working on the phone.
      • If you don't have anything at hand to lean the screen against, your suction handle can do the trick.
      • During reassembly, lay the screen in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the screen down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the screen and make sure they aren't bent.
      Ask FixBot
    15. iPhone 14 Pro Max Screen Replacement, Unfasten the battery connector cover screws: step 17, image 1 of 2 iPhone 14 Pro Max Screen Replacement, Unfasten the battery connector cover screws: step 17, image 2 of 2
      Magnetic Project Mat
      $16.96
      Buy
      • Use a Y000 screwdriver to remove the eight screws securing the battery connector cover:
      • Five 1.3 mm-long screws
      • Two 1.6 mm-long screw
      • One 1.9 mm-long screw
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the screen in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    16. iPhone 14 Pro Max Screen Replacement, Remove the battery connector cover: step 18, image 1 of 3 iPhone 14 Pro Max Screen Replacement, Remove the battery connector cover: step 18, image 2 of 3 iPhone 14 Pro Max Screen Replacement, Remove the battery connector cover: step 18, image 3 of 3
      Buy
      • Grasp the connector cover with a pair of tweezers and slide it downwards to clear the flex cables.
      • Remove the connector cover.
      Ask FixBot
    17. iPhone 14 Pro Max Screen Replacement, Disconnect the battery: step 19, image 1 of 2 iPhone 14 Pro Max Screen Replacement, Disconnect the battery: step 19, image 2 of 2
      • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Ask FixBot
    18. iPhone 14 Pro Max Screen Replacement, Disconnect the display cables: step 20, image 1 of 2 iPhone 14 Pro Max Screen Replacement, Disconnect the display cables: step 20, image 2 of 2
      • Use the pointed end of a spudger to disconnect the first display cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    19. iPhone 14 Pro Max Screen Replacement: step 21, image 1 of 2 iPhone 14 Pro Max Screen Replacement: step 21, image 2 of 2
      • Use the pointed end of a spudger to disconnect the second display cable by prying the connector straight up from its socket.
      Ask FixBot
    20. iPhone 14 Pro Max Screen Replacement, Remove the screen: step 22, image 1 of 2 iPhone 14 Pro Max Screen Replacement, Remove the screen: step 22, image 2 of 2
      • Remove the screen.
      • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • During reassembly, pause here if you wish to replace the screen adhesives.
      Ask FixBot
    1. iPhone 14 Pro Max Screen Replacement, Unfasten the front sensor bracket: step 23, image 1 of 1
      • The remaining steps demonstrate how to transfer the front sensor assembly to a new screen. If your replacement screen comes with the assembly pre-installed, skip these steps.
      • Use a PH000 screwdriver to remove the two 1.4 mm-long screws securing the sensor assembly bracket.
      Ask FixBot
    2. iPhone 14 Pro Max Screen Replacement, Remove the front sensor bracket: step 24, image 1 of 2 iPhone 14 Pro Max Screen Replacement, Remove the front sensor bracket: step 24, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the front sensor assembly bracket.
      Ask FixBot
    3. iPhone 14 Pro Max Screen Replacement, Heat the front sensor assembly: step 25, image 1 of 1
      • Heat an iOpener and apply it to the top edge of the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
      Ask FixBot
    4. iPhone 14 Pro Max Screen Replacement, Disconnect the proximity sensor: step 26, image 1 of 2 iPhone 14 Pro Max Screen Replacement, Disconnect the proximity sensor: step 26, image 2 of 2
      • Insert an opening pick between the proximity sensor and its recess on the screen.
      • Pry up with the pick to separate the proximity sensor from the screen.
      Ask FixBot
    5. iPhone 14 Pro Max Screen Replacement, Disconnect the ambient light sensor: step 27, image 1 of 2 iPhone 14 Pro Max Screen Replacement, Disconnect the ambient light sensor: step 27, image 2 of 2
      • Insert an opening pick between the ambient light sensor and its recess on the screen.
      • Pry up with the pick to separate the ambient light sensor from the screen.
      Ask FixBot
    6. iPhone 14 Pro Max Screen Replacement, Remove the front sensor assembly: step 28, image 1 of 3 iPhone 14 Pro Max Screen Replacement, Remove the front sensor assembly: step 28, image 2 of 3 iPhone 14 Pro Max Screen Replacement, Remove the front sensor assembly: step 28, image 3 of 3
      • At this point, the adhesive may have cooled down. If so, apply a heated iOpener to the assembly for one minute before continuing.
      • Insert an opening pick under the left side of the front sensor assembly.
      • Slide the pick under the assembly to separate it from the frame.
      Ask FixBot
    7. iPhone 14 Pro Max Screen Replacement: step 29, image 1 of 2 iPhone 14 Pro Max Screen Replacement: step 29, image 2 of 2
      Tesa 61395 Tape
      $8.95
      Buy
      • Remove the front sensor assembly.
      • When transferring the assembly to a new screen, follow these instructions:
      • Connect the sensors to their slots in the frame to help align the main section of the assembly.
      • Use Tesa tape to re-adhere any sections of the assembly that are no longer sticky.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the frame and place the screen back in its original position.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
60 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
19 Guide Comments
What should I do if in the center and where is the eye of the central chamber, under pressure, my fingers click?
Very annoying, on 2 iPhone such clicks, that is, then disappear... thanks
pro style - Reply Share
Thanks for this detailed guide on how to disassemble my phone screen. I was just checking some Celebrity Heights and all of a sudden my screen went black. I tried hard reset and all different things but it was the screen. I bought on eBay a new screen and used your guide to replace it and luckily everything went smoothly. Thanks again.
Briansmith1 - Reply Share
Why would I pay 399 for a stupid kit and do it myself and apple is $20 cheaper and they ll replace it with limited warranty. Wtf yall smoking.
Jimmy g - Reply Share
Then go through Apple
Alec - Reply Share
Just replaced the iPhone 14 Pro MAX, How do I get rid of the screen error message that the screen is not an authentic device?
Blake2005 - Reply Share
Past 24 Hours: 194
Past 7 Days: 1,127
Past 30 Days: 5,321
All Time: 224,037
