Beater Bar/Agitator and Belt
15 Answers 14 Score |
Dyson V15 Detect stops after a few seconds with no indicators |
26 Answers 12 Score |
The power keeps cutting out after a few seconds |
8 Answers 10 Score |
Why is my Dyson going on an off when I'm holding the on button? |
14 Answers 11 Score |
Red lever will not pull up so I can empty/replace canister |
Parts
- Dyson V7 Battery
- Dyson V6 Battery
- iRobot Roomba i7, i7+, e5, e6 Battery
- Dyson V7, V8, V8 Slim, SV25, SV37 Post-HEPA Filter New Version
- Dyson V8 Floor Combo Brush
- iRobot Roomba J7, I7, I7+, I3, I4, I8, E5, E6, J7+, Combo 10 Max Rubber Brush
- iRobot Roomba Battery for Select 500, 600, and 700 Series
- iRobot Roomba 800 and 900 Series Brush and HEPA Filter Maintenance Set - IR800SET244
Tools
- Desoldering Pump
- Phillips #00 Screwdriver
- iFixit Precision Bit Driver, Aluminum
- Lead-Free Solder
- iFixit Mandible Needle Nose Pliers
- Minnow Driver Kit
- Digital Multimeter
- FixHub Portable Soldering Station
- TR10 Torx Security Screwdriver
- Narwhal 6-in-1 Driver
- Precision Utility Knife
- Magnetic Mat Replacement Pen
- iFixit Mandible Wire Strippers
- Utility Scissors
- Wire Stripper 16-26 AWG C.H.P. CSP-30-7
- Mahi Driver Kit - 48 Bit Driver Kit
- Soldering Iron 60w Hakko 503F
- T15 Torx Screwdriver
- Nitrile Gloves 100 Box
- Solder ROHS Lead Free Rosin Core
Models
EB1000, EB1100, EB750E, EB750EX, PENTA, ST100P
Background
A vacuum cleaner is a device that uses an air pump to create a partial vacuum to suck up dust and dirt, usually from floors and sometimes from other surfaces as well. The dirt is then collected for later disposal. Vacuum cleaners can either be corded or cordless. Cordless vacuums require charging in a charging dock.
Vacuums either use vacuum bags or reusable canisters for dirt collection and disposal. Vacuum canisters are more environmentally friendly, eliminating the need for a disposable bag. Vacuum canisters are often easily detachable and include some sort of trigger that allows users to propel the contents of the canister into a trash can.
Handheld vacuum cleaners are designed to fit in tight spaces or quickly clean up crumbs and other messes. Alternatively, upright and stick vacuums are designed for uses of a longer duration that clean an entire room or house. Robotic vacuums, such as Roombas, are designed to autonomously clean areas without user interaction. They achieve this by sensing their environment and avoiding obstacles as they travel around a room, vacuuming as they move.
Identification
Vacuum cleaners have a variety of appearances and means of operation depending on their type and manufacturer. They are all generally electrically operated. Several of the types listed below can be found in one unit (like backpack canister, or upright with detachable canister) to provide a description of the vacuum that will be helpful when troubleshooting. The most important identifying information is the manufacturer's label, which will provide a model number to allow you to find reliable repair and function information.
Vacuum Types
- Upright
- Stick
- Canister
- Wet/Dry
- Drum
- Pneumatic
- Backpack
- Hand-held
- Robotic
- Cyclonic
- Central
