Vacuum Cleaner Brush Roll Replacement
    1. Vacuum Cleaner Brush Roll Replacement, Brush Roll: step 1, image 1 of 1
      • Be sure to unplug the device from the wall outlet before disassembling.
      • Remove the bottom head of the vacuum cleaner by pressing the push button.
      Ask FixBot
    2. Vacuum Cleaner Brush Roll Replacement: step 2, image 1 of 2 Vacuum Cleaner Brush Roll Replacement: step 2, image 2 of 2
      • Carefully unscrew the 6 screws with a Phillips screwdriver. Set aside.
      Ask FixBot
    3. Vacuum Cleaner Brush Roll Replacement: step 3, image 1 of 1
      • Separate the top portion of the head from the bottom.
      • Make sure not to pull off or damage the connected wires.
      Ask FixBot
    4. Vacuum Cleaner Brush Roll Replacement: step 4, image 1 of 1
      • Slip off the belt.
      Ask FixBot
    5. Vacuum Cleaner Brush Roll Replacement: step 5, image 1 of 2 Vacuum Cleaner Brush Roll Replacement: step 5, image 2 of 2
      • Pull the brush roll from its slots.
      Ask FixBot
    6. Vacuum Cleaner Brush Roll Replacement: step 6, image 1 of 2 Vacuum Cleaner Brush Roll Replacement: step 6, image 2 of 2
      • Use scissors to cut strings and other debris from the brush roll. Avoid cutting the bristles.
      Ask FixBot
    7. Vacuum Cleaner Brush Roll Replacement: step 7, image 1 of 1
      • Return the clean brush roll and re-situate the belt to secure it in place.
      Ask FixBot
To reassemble your device, follow the disassembly instructions in reverse order.
Kaitlyn Sheets
129 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 34
Past 30 Days: 118
All Time: 4,860
