Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If you have a SVE171C11L and are attempting to identify an issue, please refer to the following troubleshooting guide for help with common issues here
Background
Released in 2014, The Sony Vaio SVE171C11L is a 17.3" laptop. It is a part of the Vaio series from Sony, originally introduced in 1996. VAIO stands for Visual Audio Intelligent Organizer. SVE171C11L has other model number and is also known as SVE17125CDB
SVE17127CXB, etc.
There are no recalls for this laptop at the moment.
Identification
The SONY VAIO is a 17 inch size laptop with VIAO sign on the back of the screen. The laptop has round edges on the top. The model number can be used to identified the device. It weights approximately 7 lbs.
Technical Specifications
Released in 2014, the VAIO E Series 17 notebook with Windows 10 (64-bit) operating system.
Weight: 7.0 lb
AC adapter version weight: 7.3 lb
Processor and Storage:
Quad-core Ivy Bridge 2.2GHz Intel Core i7-3632QM processor. Its quad cores can run at 2.2GHz boosted up to 3.2GHz.
8GB of 1600MHz DDR3 RAM
1TB 5400rpm hard drive.
Screen and Keyboard:
17.3'' LCD non-touch-LCD screen with 16:9 aspect ratio and a Full HD 1920 x 1080 native resolution.
The keyboard with LED backlight technology for in low-lit environments use.
Wi-Fi and Bluetooth connection:
With a 2-in-1 digital media card reader,
built-in 10/100/1000Mbps Gigabit Ethernet RJ-45 jack
wireless with 802.11b/g/n Wi-Fi. You can use Bluetooth 4.0 to wirelessly connect to all your external devices.
equipped with the USB 3.0 port
Built-in Blu-ray Optical Drive:
The Blu-ray Disc player with DVD CD read/write functionalities.
Audio/Speakers:
There are also stereo speakers with xLOUD and Clear Phase technology.
Integrated stereo speakers utilize the Clear Phase and xLoudClear Phase technologies, .
Additional Information
Sony Vaio SVE171C11L Laptop
VAIO SVE171C11L Memory Upgrade - Sony SVE171C11L VAIO Laptop Memory (memorystock.com)
Sony SVE171 product info
Sony Vaio E series review
Author
with
Edward Briseno
896 Reputation
6 Guides authored
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Member of CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
3 Members
72 Guides authored
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 45
All Time: 2,162
