Sony Vaio SVE171C11L RAM Replacement
    1. Sony Vaio SVE171C11L RAM Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over so its underside is facing upwards and visible.
      Ask FixBot
    2. Sony Vaio SVE171C11L RAM Replacement: step 2, image 1 of 1
      • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
      • Use your left hand to push up the left tab to release the battery.
      Ask FixBot
    3. Sony Vaio SVE171C11L RAM Replacement: step 3, image 1 of 1
      • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
      Ask FixBot
    4. Sony Vaio SVE171C11L RAM Replacement: step 4, image 1 of 1
      • Pull the battery away.
      Ask FixBot
    1. Sony Vaio SVE171C11L RAM Replacement, RAM: step 5, image 1 of 1
      • Unscrew the single 3mm screw to remove the RAM panel.
      Ask FixBot
    2. Sony Vaio SVE171C11L RAM Replacement: step 6, image 1 of 1
      • Use both hands to unlock the clips that are securing the RAM.
      • The RAM will pop out from the slot when release the clip. After unlocking, slide out the RAM from their slots.
      • When inserting new RAM do not forget the put the clips back on.
      Ask FixBot
Edward Briseno
896 Reputation
6 Guides authored
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Member of CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 64
All Time: 637
