Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If you are experiencing problems with your Shark Rotator Lift-Away Speed, refer to our troubleshooting page.
Background
The Shark Rotator Lift-Away Speed (Model Number NV601), released in 2016, is a compact, multi-tool motorized vacuum. Relative to other Shark vacuum products, the Shark Rotator Lift-Away Speed has a shorter air path in order to reduce clogging and enhance suction. The Shark Rotator Lift-Away Speed also includes convenient storage for included hose accessories.
Identification
This product is not to be confused with its many similarly named counterparts, including the Shark Rotator Slim-Light Lift-Away (NV341), the Shark Rotator Lift-Away Professional (NV501), the Shark Rotator Powered Lift-Away Speed (NV680), the Shark Rotator Powered Lift-Away Deluxe (NV751), and the Shark Rotator Powered Lift-Away XL Capacity (NV755).
Parts and Tools
These are some common tools used to work on this device. You may not need every tool for every procedure.
Plastic Spudger
Torx Security Screwdriver (Various sizes)
Additional Information
User's Manual
Product Page
Shark Rotator Powered Lift-Away Speed on Amazon
Shark Rotator NV601 Quick Start Guide
Author
with
Julia Sullivan
107 Reputation
1 Guide authored
Cal Poly, Team S15-G7, Livingston Fall 2017 Member of Cal Poly, Team S15-G7, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G7
4 Members
60 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 48
All Time: 8,440
