Shark Rotator Lift-Away Speed Brushroll Replacement
  1. Shark Rotator Lift-Away Speed Brushroll Replacement, Brushroll: step 1, image 1 of 1
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Locate the release button at the top of the vacuum pod next to the handle.
    • Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
    • Removing the pod is optional, but it may be easier to locate blockages or access the motor and belt if you do so.
    Ask FixBot
  2. Shark Rotator Lift-Away Speed Brushroll Replacement: step 2, image 1 of 2 Shark Rotator Lift-Away Speed Brushroll Replacement: step 2, image 2 of 2
    • Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
    Ask FixBot
  3. Shark Rotator Lift-Away Speed Brushroll Replacement: step 3, image 1 of 2 Shark Rotator Lift-Away Speed Brushroll Replacement: step 3, image 2 of 2
    • Lift the brushroll out by using the pull-tab on the left side.
    • You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode. The brushroll indicator light should be a solid green color.
    Ask FixBot
Weston Mongomery
201 Reputation
2 Guides authored
Cal Poly, Team S15-G7, Livingston Fall 2017 Member of Cal Poly, Team S15-G7, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G7
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 56
All Time: 2,121
