Shark Rotator Lift-Away Speed Belt Replacement
    1. Shark Rotator Lift-Away Speed Belt Replacement, Brushroll: step 1, image 1 of 1
      • Make sure the vacuum is turned off and unplugged before proceeding.
      • Locate the release button at the top of the vacuum pod next to the handle.
      • Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
      • Removing the pod is optional, but it may be easier to locate blockages or access the motor and belt if you do so.
      Ask FixBot
    2. Shark Rotator Lift-Away Speed Belt Replacement: step 2, image 1 of 2 Shark Rotator Lift-Away Speed Belt Replacement: step 2, image 2 of 2
      • Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
      Ask FixBot
    3. Shark Rotator Lift-Away Speed Belt Replacement: step 3, image 1 of 2 Shark Rotator Lift-Away Speed Belt Replacement: step 3, image 2 of 2
      • Lift the brushroll out by using the pull-tab on the left side.
      • You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode. The brushroll indicator light should be a solid green color.
      Ask FixBot
    1. Shark Rotator Lift-Away Speed Belt Replacement, Brushroll Motor: step 4, image 1 of 1
      • Remove the five 5mm Torx #9 screws on the front side.
      Ask FixBot
    2. Shark Rotator Lift-Away Speed Belt Replacement: step 5, image 1 of 1
      • Remove the six 7.5mm Torx #20 screws on the bottom face of the nozzle.
      • A screwdriver extension may be necessary to reach the screw closest to the center of the nozzle.
      Ask FixBot
    3. Shark Rotator Lift-Away Speed Belt Replacement: step 6, image 1 of 1
      • Remove the top panel by lifting the top piece off of the bottom.
      • There will be loud clicking noises.
      Ask FixBot
    4. Shark Rotator Lift-Away Speed Belt Replacement: step 7, image 1 of 1
      • If you are trying to remove the belt, you may skip to the next step.
      • Remove the 7.5mm Torx #20 screw in front of the motor.
      • The motor is the gray block on the right side of the floor nozzle (when the nozzle faces towards you).
      Ask FixBot
    5. Shark Rotator Lift-Away Speed Belt Replacement: step 8, image 1 of 2 Shark Rotator Lift-Away Speed Belt Replacement: step 8, image 2 of 2
      • Remove the panel to reveal the motor screw.
      • Remove the 7.5mm Torx #20 motor screw.
      • Remove the motor.
      Ask FixBot
    1. Shark Rotator Lift-Away Speed Belt Replacement, Brushroll Belt: step 9, image 1 of 1
      • Remove the black belt located on the right face of the vacuum nozzle.
      Ask FixBot
5 other people completed this guide.
Samantha Woo
357 Reputation
2 Guides authored
Cal Poly, Team S15-G7, Livingston Fall 2017 Member of Cal Poly, Team S15-G7, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G7
4 Members
60 Guides authored
1 Guide Comment
where can I purchase the wheel shown in the photo above??
Kay Sherbeck - Reply Share
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 128
All Time: 12,833
