Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Samsung Gear 360 is a unique camera capable of recording (3840 x 1290) video at 30 frames per second in 360 degrees or using the 15 Megapixel wide-angle lens for a 180-degree shot. The Samsung Gear 360 is lightweight (0.3 lbs) and is water resistant for up to 30 minutes. The Samsung Gear 360 is also capable of Wi-Fi, USB , and Bluetooth connectivity. For pairing with other Samsung devices, it is also equipped with NFC connectivity. The memory of the Samsung Gear 360 is controlled by a micro SD card that can be up to 200 GB. Key features include the ability to be used for Facebook 360, YouTube 360, Google Street view, and Samsung VR(Virtual Reality).
Identification
The Samsung Gear 360 can be identified by the IMEI and serial number on the label located on the bottom of the device, on the original packaging, or your receipt. It has a white spherical shape with the brand Samsung printed in gray on the side. It attaches to a small black tripod. For additional help with identifying your camera, visit the Samsung Support page.
Additional information
Samsung Gear 360 Support Page
Wikipedia: Samsung Gear 360
Samsung Gear 360 Lens Cover Replacement
Samsung Gear 360 on Samsung Site
Samsung Gear 360 Review on the Verge
Samsung SM-C200 Mode d'emploi
Samsung Gear 360 (SM-C200) ユーザーマニュアル
Samsung SM-R210 Manual do utilizador
Samsung Gear 360 SM-C200 User Manual
Samsung SM-C200 사용 설명서
Samsung Gear 360 SM-C200 Manual do utilizador
Samsung Gear 360 SM-R210 — Mode d'emploi
Samsung Gear 360 SM-R210 User Manual
Samsung Gear 360 SM-R210 사용 설명서
Samsung SM-R210 User Manual
Samsung SM-R210 Manualul utilizatorului
Samsung SM-R210 Benutzerhandbuch
Gear 360 (SM-R210) ユーザーマニュアル
Samsung ET-YC200 Gear 360 Value Kit Quick Start Guide (EN, RU)
Author
with
Connor
454 Reputation
3 Guides authored
USF Tampa, Team S3-G5, Sullivan Spring 2017 Member of USF Tampa, Team S3-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G5
4 Members
84 Guides authored
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 56
All Time: 7,823
