Samsung Gear 360 Front Camera Replacement
    1. Samsung Gear 360 Front Camera Replacement, Case: step 1, image 1 of 3 Samsung Gear 360 Front Camera Replacement, Case: step 1, image 2 of 3 Samsung Gear 360 Front Camera Replacement, Case: step 1, image 3 of 3
      • Twist silver ring on the lens counter-clockwise with force to remove it.
      Ask FixBot
    2. Samsung Gear 360 Front Camera Replacement: step 2, image 1 of 2 Samsung Gear 360 Front Camera Replacement: step 2, image 2 of 2
      • Insert a small flathead screwdriver into marked slot on camera lens and pry off camera lens cover.
      Ask FixBot
    3. Samsung Gear 360 Front Camera Replacement: step 3, image 1 of 2 Samsung Gear 360 Front Camera Replacement: step 3, image 2 of 2
      • Using a PH00 screwdriver head, remove all Phillips #00 0.75 mm screws on the front of the camera.
      • Repeat for the back side of the camera.
      Ask FixBot
    4. Samsung Gear 360 Front Camera Replacement: step 4, image 1 of 3 Samsung Gear 360 Front Camera Replacement: step 4, image 2 of 3 Samsung Gear 360 Front Camera Replacement: step 4, image 3 of 3
      • Peel off the black rubber located on the bottom of the device using your hand or a small flathead screwdriver.
      Ask FixBot
    5. Samsung Gear 360 Front Camera Replacement: step 5, image 1 of 2 Samsung Gear 360 Front Camera Replacement: step 5, image 2 of 2
      • Once the black rubber has been removed, unscrew all Phillips #00 0.75 mm screws on the bottom of the device using a PH00 screwdriver head.
      Ask FixBot
    6. Samsung Gear 360 Front Camera Replacement: step 6, image 1 of 2 Samsung Gear 360 Front Camera Replacement: step 6, image 2 of 2
      • Using a plastic opening tool, pry the tripod mount off the device.
      Ask FixBot
    7. Samsung Gear 360 Front Camera Replacement: step 7, image 1 of 2 Samsung Gear 360 Front Camera Replacement: step 7, image 2 of 2
      • Using both hands, carefully remove the right cover off the camera body.
      Ask FixBot
    8. Samsung Gear 360 Front Camera Replacement: step 8, image 1 of 3 Samsung Gear 360 Front Camera Replacement: step 8, image 2 of 3 Samsung Gear 360 Front Camera Replacement: step 8, image 3 of 3
      • To remove the left cover of the camera body, lift the left cover using a small flathead screwdriver and pull it off.
      Ask FixBot
    9. Samsung Gear 360 Front Camera Replacement: step 9, image 1 of 2 Samsung Gear 360 Front Camera Replacement: step 9, image 2 of 2
      • Once the camera body has been removed, lift and pull off the metal support ring using a small flathead screwdriver.
      • Repeat for both sides of the camera.
      Ask FixBot
    10. Samsung Gear 360 Front Camera Replacement: step 10, image 1 of 2 Samsung Gear 360 Front Camera Replacement: step 10, image 2 of 2
      • Remove all Phillips #00 0.75 mm screws from the body of the camera using a PH00 screwdriver head.
      Ask FixBot
    11. Samsung Gear 360 Front Camera Replacement: step 11, image 1 of 3 Samsung Gear 360 Front Camera Replacement: step 11, image 2 of 3 Samsung Gear 360 Front Camera Replacement: step 11, image 3 of 3
      • Carefully lift the three sensors off using a plastic opening tool and pull them aside.
      Ask FixBot
    12. Samsung Gear 360 Front Camera Replacement: step 12, image 1 of 2 Samsung Gear 360 Front Camera Replacement: step 12, image 2 of 2
      • Carefully use a plastic opening tool to separate the gray case from the black case on the device.
      Ask FixBot
    13. Samsung Gear 360 Front Camera Replacement: step 13, image 1 of 3 Samsung Gear 360 Front Camera Replacement: step 13, image 2 of 3 Samsung Gear 360 Front Camera Replacement: step 13, image 3 of 3
      • Insert a plastic removal tool underneath the four sensors on the motherboard to fully separate the camera case.
      Ask FixBot
    1. Samsung Gear 360 Front Camera Replacement, Speaker: step 14, image 1 of 3 Samsung Gear 360 Front Camera Replacement, Speaker: step 14, image 2 of 3 Samsung Gear 360 Front Camera Replacement, Speaker: step 14, image 3 of 3
      • Within gold metal half of the case, unscrew the Phillips #00 0.75 mm screw located on the metal plate using a PH00 screwdriver.
      • Using a plastic opening tool, remove the metal cover.
      Ask FixBot
    2. Samsung Gear 360 Front Camera Replacement: step 15, image 1 of 3 Samsung Gear 360 Front Camera Replacement: step 15, image 2 of 3 Samsung Gear 360 Front Camera Replacement: step 15, image 3 of 3
      • Using a PH000 screwdriver head, unscrew all Phillips #00 0.75 mm screws.
      • To remove the speaker from the device, use a plastic opening tool on the edge and gently lift it up.
      Ask FixBot
    1. Samsung Gear 360 Front Camera Replacement, Front Camera: step 16, image 1 of 3 Samsung Gear 360 Front Camera Replacement, Front Camera: step 16, image 2 of 3 Samsung Gear 360 Front Camera Replacement, Front Camera: step 16, image 3 of 3
      • Using a PH000 screwdriver head, unscrew both screws on the remaining case.
      • Use a plastic opening tool to lift the front camera module from the case.
      Ask FixBot
Connor
454 Reputation
3 Guides authored
USF Tampa, Team S3-G5, Sullivan Spring 2017 Member of USF Tampa, Team S3-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G5
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 1,352
