Samsung Gear 360 Rear Camera Replacement
Views: 2K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
86
All Time:
1,962
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Difficult
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will show you how to remove the rear camera module from the Samsung Gear 360. Like the front camera, this module can be removed by completing a tear-down of the device, and unscrewing the module from there.
Tools
    1. Samsung Gear 360 Rear Camera Replacement, Case: step 1, image 1 of 3 Samsung Gear 360 Rear Camera Replacement, Case: step 1, image 2 of 3 Samsung Gear 360 Rear Camera Replacement, Case: step 1, image 3 of 3
      • Twist silver ring on the lens counter-clockwise with force to remove it.
      Ask FixBot
    2. Samsung Gear 360 Rear Camera Replacement: step 2, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 2, image 2 of 2
      • Insert a small flathead screwdriver into marked slot on camera lens and pry off camera lens cover.
      Ask FixBot
    3. Samsung Gear 360 Rear Camera Replacement: step 3, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 3, image 2 of 2
      • Using a PH00 screwdriver head, remove all Phillips #00 0.75 mm screws on the front of the camera.
      • Repeat for the back side of the camera.
      Ask FixBot
    4. Samsung Gear 360 Rear Camera Replacement: step 4, image 1 of 3 Samsung Gear 360 Rear Camera Replacement: step 4, image 2 of 3 Samsung Gear 360 Rear Camera Replacement: step 4, image 3 of 3
      • Peel off the black rubber located on the bottom of the device using your hand or a small flathead screwdriver.
      Ask FixBot
    5. Samsung Gear 360 Rear Camera Replacement: step 5, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 5, image 2 of 2
      • Once the black rubber has been removed, unscrew all Phillips #00 0.75 mm screws on the bottom of the device using a PH00 screwdriver head.
      Ask FixBot
    6. Samsung Gear 360 Rear Camera Replacement: step 6, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 6, image 2 of 2
      • Using a plastic opening tool, pry the tripod mount off the device.
      Ask FixBot
    7. Samsung Gear 360 Rear Camera Replacement: step 7, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 7, image 2 of 2
      • Using both hands, carefully remove the right cover off the camera body.
      Ask FixBot
    8. Samsung Gear 360 Rear Camera Replacement: step 8, image 1 of 3 Samsung Gear 360 Rear Camera Replacement: step 8, image 2 of 3 Samsung Gear 360 Rear Camera Replacement: step 8, image 3 of 3
      • To remove the left cover of the camera body, lift the left cover using a small flathead screwdriver and pull it off.
      Ask FixBot
    9. Samsung Gear 360 Rear Camera Replacement: step 9, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 9, image 2 of 2
      • Once the camera body has been removed, lift and pull off the metal support ring using a small flathead screwdriver.
      • Repeat for both sides of the camera.
      Ask FixBot
    10. Samsung Gear 360 Rear Camera Replacement: step 10, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 10, image 2 of 2
      • Remove all Phillips #00 0.75 mm screws from the body of the camera using a PH00 screwdriver head.
      Ask FixBot
    11. Samsung Gear 360 Rear Camera Replacement: step 11, image 1 of 3 Samsung Gear 360 Rear Camera Replacement: step 11, image 2 of 3 Samsung Gear 360 Rear Camera Replacement: step 11, image 3 of 3
      • Carefully lift the three sensors off using a plastic opening tool and pull them aside.
      Ask FixBot
    12. Samsung Gear 360 Rear Camera Replacement: step 12, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 12, image 2 of 2
      • Carefully use a plastic opening tool to separate the gray case from the black case on the device.
      Ask FixBot
    13. Samsung Gear 360 Rear Camera Replacement: step 13, image 1 of 3 Samsung Gear 360 Rear Camera Replacement: step 13, image 2 of 3 Samsung Gear 360 Rear Camera Replacement: step 13, image 3 of 3
      • Insert a plastic removal tool underneath the four sensors on the motherboard to fully separate the camera case.
      Ask FixBot
    1. Samsung Gear 360 Rear Camera Replacement, Rear Camera: step 14, image 1 of 2 Samsung Gear 360 Rear Camera Replacement, Rear Camera: step 14, image 2 of 2
      • Within the grey half of the case, unscrew both Phillips #00 0.75 mm screws located on the metal plate using PH00 screwdriver.
      Ask FixBot
    2. Samsung Gear 360 Rear Camera Replacement: step 15, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 15, image 2 of 2
      • Once the screws have been removed, remove the metal plate.
      Ask FixBot
    3. Samsung Gear 360 Rear Camera Replacement: step 16, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 16, image 2 of 2
      • Using a PH000 screwdriver head, remove the both Phillips #000 0.75 mm screws on the grey case.
      Ask FixBot
    4. Samsung Gear 360 Rear Camera Replacement: step 17, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 17, image 2 of 2
      • Using a plastic opening tool, remove the plastic cover underneath the rear camera
      Ask FixBot
    5. Samsung Gear 360 Rear Camera Replacement: step 18, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 18, image 2 of 2
      • Gently remove the rear camera module by using a plastic opening tool and lifting the module.
      Ask FixBot
2 other people completed this guide.
Connor
454 Reputation
3 Guides authored
USF Tampa, Team S3-G5, Sullivan Spring 2017 Member of USF Tampa, Team S3-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G5
4 Members
84 Guides authored
1 Guide Comment
number datasheet sensor camera?
Pelicula 360 - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 86
All Time: 1,962
