Descale support valve
3 Answers 2 Score |
How to Realign Gears on my Saeco Vienna Plus? |
3 Answers 1 Score |
Starts to brew, dispenses abt 2oz liquid, stops, red lights comes on |
1 Answer 2 Score |
Why is freshly ground coffee going all over inside machine and out? |
1 Answer 0 Score |
accidentally pour water into the coffee grinder |
Tools
Saeco Vienna Sup 018 Maintenance
At the latest, maintenance is needed when the taste is not good any more. Though better do this earlier, these devices are not maintenance-free, although this opinion is widespread.
Essential points that determine the taste:
- Grist, amount
- temperature
- Type of coffee
- amount of water
- cleanliness
Some of these things can be adjusted, with others you have to work.
It goes without saying that the decalcification is carried out frequently and on time. It is also important to keep clean the Cappucinatore, as described in the manual, so it has.
Saeco recommends frequent cleaning of the brewing unit. The simplest is to remove and rinse under running water. Add a grease to the most important moving parts. A complete disassembly is not so difficult, the success is amazing! There are several descriptions here, but the brewing groups differ in details:
- Saeco brewing unit disassembly
- Disassembling and cleaning a Saeco Incanto SBS brewing unit
- Replacing the O-rings in a Saeco Incanto SBS brewing unit
The support valve is heavily used, these seals are exchanged from time to time and greased afterwards.
Shown here for the Royal model, works very similar. Below the valve is an opening through which excess water can drain. This must be kept free, e.g. with a pipe cleaner.
The mill should be cleaned from time to time. Grindstones wears off and only squeezes the coffee instead of cutting it clean. They are exchanged as described here
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
