Up to 20% off select tools
Saeco brewing unit disassembly
Views: 36K
View statistics:
Past 24 Hours:
38
Past 7 Days:
310
Past 30 Days:
1,038
All Time:
35,912
Comments: 14
9 comments on steps, 5 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
A clean brew group makes much better coffee. Seals that are particularly subject to wear must be replaced from time to time.
These instructions can also help with fully automatic coffee machines from Philips and Gaggia - they all come from the same manufacturer and are very similar in design.
    1. Saeco brewing unit disassembly, Cream valve and spout: step 1, image 1 of 3 Saeco brewing unit disassembly, Cream valve and spout: step 1, image 2 of 3 Saeco brewing unit disassembly, Cream valve and spout: step 1, image 3 of 3
      • These parts differ in details depending on the model
      • Two screws hold the part, loosen. A seal becomes free, pick up well, better still replace later.
      • Inside is a feather and a small glass ball. Store carefully.
      Ask FixBot
    2. Saeco brewing unit disassembly, The brewing sieve: step 2, image 1 of 2 Saeco brewing unit disassembly, The brewing sieve: step 2, image 2 of 2
      • With a 6mm Allen key (or the key that comes with the machine), the brewing sieve can be unscrewed. It strongly determines the aroma, if it is dirty the coffee tastes bad.
      Ask FixBot
    3. Saeco brewing unit disassembly, The upper piston: step 3, image 1 of 3 Saeco brewing unit disassembly, The upper piston: step 3, image 2 of 3 Saeco brewing unit disassembly, The upper piston: step 3, image 3 of 3
      • He is held in place by four latches. These impress, e.g. with a screwdriver, then the piston can be pushed down.
      • The new sealing ring is already waiting, but first it has to be cleaned properly.
      Ask FixBot
    4. Saeco brewing unit disassembly, Intake: step 4, image 1 of 3 Saeco brewing unit disassembly, Intake: step 4, image 2 of 3 Saeco brewing unit disassembly, Intake: step 4, image 3 of 3
      • Through the hole on the opposite side of the fixing screw can be solved. The inlet is plugged in and held by a latch, which you have to push away.
      Ask FixBot
    5. Saeco brewing unit disassembly, dismantle: step 5, image 1 of 3 Saeco brewing unit disassembly, dismantle: step 5, image 2 of 3 Saeco brewing unit disassembly, dismantle: step 5, image 3 of 3
      • Three screws hold the brew groups together, loosen.
      • The whole mechanics can now be broken down into three big parts. The coffee funnel can stay.
      Ask FixBot
    6. Saeco brewing unit disassembly, Umlenkhebel: step 6, image 1 of 2 Saeco brewing unit disassembly, Umlenkhebel: step 6, image 2 of 2
      • That's the trickiest part: you have to lever this lever out of its camp. To do this you drive with a screwdriver between the lever and the carrier and press it really very strong outwards. Now he grabs out - hopefully!
      Ask FixBot
    7. Saeco brewing unit disassembly, Lower piston: step 7, image 1 of 1
      • Since the lever is gone you can easily pull out the piston. It has no seal.
      • The lower piston itself has no gasket. But the shaft of the piston slides in an o-ring. which is situated under the brewing chamber. It can be changed, but it´s not easy to do this.
      Ask FixBot
    8. Saeco brewing unit disassembly, Clean: step 8, image 1 of 1
      • That's why we did it. All parts are thoroughly cleaned. For this purpose, a solution of machine detergent is good. (Use rubber gloves!) Clean all channels with pipe cleaners. The brewing sieve is like new again! Allow to dry well.
      • Then apply new gaskets, in particular to the crema valve and piston and lubricate with food-grade grease.
      • Fat also belongs to the bearings of the rocker arm and into the slides, the piston skirt, as well as into the water inlet
      Ask FixBot
Repeat the steps in order to reassemble your device.
4 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
349,691 Reputation
325 Guides authored
5 Guide Comments
How does the metal bar you see in figure 7 get put back in place when you reassemble the unit?
milesj - Reply Share
Not easy to describe. First try to use the brewing unit without the metal, maybe that's already enough. Or try borrowing another unit to compare.
VauWeh - Reply Share
i dismantled only the square part to clean the metal filter. A 1mm seal fell out of no where and wasnt sure where to put it back. I placed it back into that L shape piece on top of it and now there is some coffe leaking into the square piece. Please help. I have the diagram to show the exact piece i mentioned but how do i show it here?
Jelim - Reply Share
I suppose it is the seal visible in Saeco brewing unit disassembly, step 1, picture 3. Be sure to put in the little ball, the spring and the seal, before you tighten the screws on the L-shaped hose. There is another gasket on the axis in step 2, picture 1, perhaps you removed it?
Once I saw someone put the L-shaped hose in the wrong way. The exit must point into the machine.
Past 24 Hours: 38
Past 7 Days: 310
Past 30 Days: 1,038
All Time: 35,912
