Fan
1 Answer 0 Score |
Why does the heat work but not the fan? |
1 Answer 0 Score |
What Is This Part? |
Tools
Background
The Royal Heat RS-100 was manufactured in Taiwan in 1989. It works by flowing electric current through a resistive coil and converting it into heat energy. The heating elements inside the heater are called the coils which contain many layers of metal (a conductor) wound around a core.
The Royal Heat RS-100 functions as a fan heater. It transfers heat from the device to the surrounding area by using an electric fan.
Identification
To differentiate the Royal Heat RS-100 from other space heaters, look for the following features. On the front, the RS-100 has four rectangular resistors with a metal net cover, a dial-switch with three positions (Heat-Off-Fan), and a dial to adjust the power. On the back, a removable filter hides the fan inside. On the bottom of the heater, you will find the identification plate and it contains the model number (RS-100), power input and output, and the serial number.
Specifications
Model: RS-100
Release Date: 07/1989
Power Source Required: Standard 120v 2-prong outlet
Color: Black
Power consumption: adjustable up to 1500W
Voltage rating: 120 V (60Hz)
Output: Up to 5200 BTU
Dimensions: 6.5 L x 5 W x 7.5'' H
Unit weight: 8 lbs
Additional Information
Honeywell Heater Troubleshooting
Heater's Common Problems (section 7.52)
