Royal Heat RS-100 Fan Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
69
All Time:
1,336
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
Replace the fan if the fan is not working. The heater will still work if the fan in broken but it will not allow the device to circulate air.
Tools
    1. Royal Heat RS-100 Fan Replacement, Panel: step 1, image 1 of 1
      • Unplug the power cord.
      • Flip the device over so the bottom is facing up.
      • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
      Ask FixBot
    2. Royal Heat RS-100 Fan Replacement: step 2, image 1 of 3 Royal Heat RS-100 Fan Replacement: step 2, image 2 of 3 Royal Heat RS-100 Fan Replacement: step 2, image 3 of 3
      • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
      • Remove the front panel by pulling them apart. The front panel should come out easily.
      Ask FixBot
    3. Royal Heat RS-100 Fan Replacement: step 3, image 1 of 1
      • Remove the two dial caps from the two switches by lifting them up.
      Ask FixBot
    1. Royal Heat RS-100 Fan Replacement, Fan: step 4, image 1 of 1
      • Remove the three 10 mm screws that attach the fan to the heating coil assembly using the #2 Phillip Screwdriver.
      Ask FixBot
    2. Royal Heat RS-100 Fan Replacement: step 5, image 1 of 1
      • Remove the 10 mm screw that attaches the fan to the heating coil assembly using the #2 Phillip Screwdriver.
      Ask FixBot
    3. Royal Heat RS-100 Fan Replacement: step 6, image 1 of 1
      • Lift the heating coil assembly from the fan.
      Ask FixBot
    4. Royal Heat RS-100 Fan Replacement: step 7, image 1 of 1
      • Unplug the two blue wires that connect the fan to the Power/Fan Switch Circuit Board Assembly by pulling them away them from the fan.
      Ask FixBot
    5. Royal Heat RS-100 Fan Replacement: step 8, image 1 of 1
      • Flip the device over so the back panel is facing upwards.
      Ask FixBot
    6. Royal Heat RS-100 Fan Replacement: step 9, image 1 of 1
      • Gently pry the back screen off of the device using a flathead screwdriver and remove it.
      Ask FixBot
    7. Royal Heat RS-100 Fan Replacement: step 10, image 1 of 1
      • Remove the four 10mm screws that attach the fan to the heater case using the #2 Phillip Screwdriver.
      • Lift the back plate from the fan by pulling it away from the fan.
      • Take note the direction of the fan blades. Putting the the fan in the wrong way will result in the air flow to come out the back of the device instead of the front.
      Ask FixBot
Danyele Rampone
125 Reputation
1 Guide authored
Cal Poly, Team 11-35, Amido Fall 2013 Member of Cal Poly, Team 11-35, Amido Fall 2013
CPSU-AMIDO-F13S11G35
4 Members
84 Guides authored
1 Guide Comment
QUESTION OFF TOPIC>>> sorry but don't know who else to ask..
Anyone know if Royal Heat is still in business maybe under a different name? I cannot find anything on the market today that compares to this little heater/fan. Was given one by elderly relative who said he has used it for 20 years and STILL works wonderfully. Poor fellow confined to a nursing home now and said he doesn't need it.
Thank You
Michael Gray - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 69
All Time: 1,336
