Royal Heat RS-100 Fuse Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
84
All Time:
1,117
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
Check the fuse when the current flow through the power cord, but not through the heater coil.
Tools
    1. Royal Heat RS-100 Fuse Replacement, Panel: step 1, image 1 of 1
      • Unplug the power cord.
      • Flip the device over so the bottom is facing up.
      • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
      Ask FixBot
    2. Royal Heat RS-100 Fuse Replacement: step 2, image 1 of 3 Royal Heat RS-100 Fuse Replacement: step 2, image 2 of 3 Royal Heat RS-100 Fuse Replacement: step 2, image 3 of 3
      • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
      • Remove the front panel by pulling them apart. The front panel should come out easily.
      Ask FixBot
    3. Royal Heat RS-100 Fuse Replacement: step 3, image 1 of 1
      • Remove the two dial caps from the two switches by lifting them up.
      Ask FixBot
    1. Royal Heat RS-100 Fuse Replacement, Fuse: step 4, image 1 of 2 Royal Heat RS-100 Fuse Replacement, Fuse: step 4, image 2 of 2
      • Do not pry from the middle of the fuse because some fuses are made of glass.
      • Pry one end of the fuse from the bracket until it is separated from the holder.
      • Remove the fuse by lifting it up.
      Ask FixBot
Long Tran
205 Reputation
2 Guides authored
Cal Poly, Team 11-35, Amido Fall 2013 Member of Cal Poly, Team 11-35, Amido Fall 2013
CPSU-AMIDO-F13S11G35
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 84
All Time: 1,117
