Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Ring Stick Up Cam Battery is a wire-free security device powered by a quick-release battery pack. It is weather resistant and can be used both indoors and outdoors within the following operation conditions: -5°F to 122°F (-20°C to 50°C). By connecting to the Ring App, individuals can receive motion-activated notifications and have access to HD-Video and Two-Way Talk. Its motion zones can be altered and its field of view is 130° diagonal, 110° horizontal, and 57° vertical. The Ring Stick Up Cam video footage is 1080p HD and includes live view with color night vision. Regarding installation, the Ring Stick Up Cam Battery comes with an adjustable mount that can stand on its own or be applied to a variety of surfaces.
Setting it apart from previous generations, the third-generation Ring Stick Up Cam Battery has improved video quality, a flexible design, and improved power options. The price point of this model ranges from $99.00-$474.98. The price is dependent on how many devices and additional accessories are purchased. The Ring Stick Up Cam Battery can be bought individually or in packs of 2-4. Accessories include an optional solar panel, pan-tilt, Echo show 5, etc. Upon purchasing, the general box includes the Stick Up Cam Battery device, Quick-Release Battery Pack, Micro USB Charging Cable, Screws and Wall Anchors, User Manual, and Security Sticker. Consumers also receive a one-year limited warranty for their device. In comparison to other devices sold by Ring, the Ring Stick Up Cam Battery is described as a "Best Seller" on their website.
Ring's popularity stems from its ease of use and installation. Ring products are geared toward families, individuals, and companies who desire protection for their homes, buildings, property, etc. However, there are some frequent complaints about Ring security devices. This includes bulkiness, connectivity issues (especially with Android Devices), limited visual range, and lack of glass-break detection.
Specifically, regarding the Ring Stick Up Cam Battery, negative review focus on the Android app, narrow field of view, and lack of person detection. However, positive features noted in reviews include the affordable price, good battery life, two-way audio, as well as Alexa and Google Assistant compatibility. Additionally, it is noted to do well in various weather conditions and is easy to install. Overall, the Ring Stick Up Cam Battery has a positive reputation as an easy-to-use and affordable security system that brings piece of mind to customers.
Identification
The Ring Stick Up Cam Battery can be identified by its cylindrical body. At the front are the camera, light indicator, and speaker. The base allows the camera to be tilted in place. On the back, when twisted to the unlocked position, the top can be pulled off the base. Opening the device like this reveals access to the battery, a QR code involved with setting up the device in coordination with the Ring app, and information such as the DSN, MAC address, and model number.
Technical Specifications
Stick Up Camera Battery
_______________________________________________________________________
Size 2.36 in. x 3.82 in. x 2.36 in
Camera Resolution 1080p
Field of View 115 degrees horizontal, 60 degrees vertical
Battery Charging 5-10 hours
Battery Life approx. 1,000 activations
Connection 2.4GHz Wireless b/g/n
Connection Speed 2 Mbps per device
Audio Source 15mm H x 40mm W x 18mm D Speaker and one Omni-directional microphone
System Requirements IOS 12 or Android 6.0 or later required
Source: https://support.ring.com/hc/en-us/articl...
Additional Information
Ring Support - What To Know
Security.org: Ring Stick Up Cam Battery Review
Ring Stick Up Cam Battery on Amazon
Author
with
Vanessa Hasbrouck
366 Reputation
2 Guides authored
Marist, Team 1-1, Chaterdon Spring 2023 Member of Marist, Team 1-1, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G1
3 Members
60 Guides authored
Past 24 Hours: 0
Past 7 Days: 28
Past 30 Days: 117
All Time: 2,208
