Ring Stick Up Cam Battery Microphone Replacement
  1. Ring Stick Up Cam Battery Microphone Replacement, Battery: step 1, image 1 of 1
    • Turn the camera so the lens is facing away from you, and the back is facing towards you.
    • Place one hand securely on the base and the other on the stand.
    • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
    Ask FixBot
  2. Ring Stick Up Cam Battery Microphone Replacement: step 2, image 1 of 1
    • Gently pull down to separate the stand from the camera body.
    Ask FixBot
  3. Ring Stick Up Cam Battery Microphone Replacement: step 3, image 1 of 2 Ring Stick Up Cam Battery Microphone Replacement: step 3, image 2 of 2
    • Hold the camera so the opening containing the battery is toward the ceiling.
    • Squeeze the silver lever labeled "push" and extract the battery from its slot.
    Ask FixBot
  4. Ring Stick Up Cam Battery Microphone Replacement, Motherboard: step 4, image 1 of 1
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
    Ask FixBot
  5. Ring Stick Up Cam Battery Microphone Replacement: step 5, image 1 of 1
    • Remove the 6 mm white screw from the rear panel with the a T3 Torx screwdriver.
    Ask FixBot
  6. Ring Stick Up Cam Battery Microphone Replacement: step 6, image 1 of 1
    • Rotate the device so the base is facing upward.
    • Remove the two 6 mm screws from the base (on either side of the QR code) using a Phillips #00 screwdriver.
    • Remove the two 4 mm screws that connect the silver latch on the outside rim using a Phillips #00 screwdriver.
    Ask FixBot
  7. Ring Stick Up Cam Battery Microphone Replacement: step 7, image 1 of 1
    • Remove the silver latch from the base.
    • Remove the front cover.
    • Remove the eight 6 mm screws from the inside panel with a Philips #00 screwdriver.
    • Remove the two 4 mm screws from the inside panel with a Phillips #00 screwdriver.
    Ask FixBot
  8. Ring Stick Up Cam Battery Microphone Replacement: step 8, image 1 of 1
    • Pry the inside panel open using your hands or a spudger if necessary.
    Ask FixBot
  9. Ring Stick Up Cam Battery Microphone Replacement: step 9, image 1 of 1
    • Remove the seven 4 mm screws connecting the motherboard to the camera body with a Phillips #00 screwdriver.
    Ask FixBot
  10. Ring Stick Up Cam Battery Microphone Replacement: step 10, image 1 of 2 Ring Stick Up Cam Battery Microphone Replacement: step 10, image 2 of 2
    • Lift the motherboard from the camera body with the halberd spudger.
    Ask FixBot
  11. Ring Stick Up Cam Battery Microphone Replacement: step 11, image 1 of 2 Ring Stick Up Cam Battery Microphone Replacement: step 11, image 2 of 2
    • Rotate the device to its side.
    • With your fingers, carefully remove the white part of the cord clip from the beige base.
    • Repeat this for the remaining three cords connecting the motherboard to the camera body.
    Ask FixBot
  12. Ring Stick Up Cam Battery Microphone Replacement: step 12, image 1 of 1
    • Fold the motherboard downward from the camera body, revealing a white connecting strip.
    • Using the flat end of a spudger, flick the black hinge upward.
    • Pull the white strip out of the slot.
    Ask FixBot
  13. Ring Stick Up Cam Battery Microphone Replacement: step 13, image 1 of 2 Ring Stick Up Cam Battery Microphone Replacement: step 13, image 2 of 2
    • Carefully insert the spudger underneath gold adhesive at the lower left-hand corner of the motherboard.
    • Gently remove the adhesive cover from the motherboard.
    Ask FixBot
  14. Ring Stick Up Cam Battery Microphone Replacement, Camera: step 14, image 1 of 1
    • Orient your device so that the interior of the camera body is facing the ceiling.
    Ask FixBot
  15. Ring Stick Up Cam Battery Microphone Replacement: step 15, image 1 of 1
    • Remove the two 6 mm screws that connect the camera to the camera body using a Phillips #00 screwdriver.
    Ask FixBot
  16. Ring Stick Up Cam Battery Microphone Replacement: step 16, image 1 of 1
    • Grab and twist the camera counterclockwise with your thumb and index finger.
    Ask FixBot
  17. Ring Stick Up Cam Battery Microphone Replacement: step 17, image 1 of 2 Ring Stick Up Cam Battery Microphone Replacement: step 17, image 2 of 2
    • Using your fingers, lift out the camera component including the camera lens and the attached wire.
    Ask FixBot
  18. Ring Stick Up Cam Battery Microphone Replacement, Microphone: step 18, image 1 of 1
    • Remove the two 4 mm screws connecting the metal protective piece to the camera body using a Phillips #00 screwdriver.
    Ask FixBot
  19. Ring Stick Up Cam Battery Microphone Replacement: step 19, image 1 of 1
    • Using your fingers, carefully pinch the white connector attached to the black cable, and gently pull it out of its slot on the daughterboard.
    Ask FixBot
  20. Ring Stick Up Cam Battery Microphone Replacement: step 20, image 1 of 1
    • Rotate the camera body to a comfortable position.
    • Use the spudger to pry the metal component from the camera body.
    • The daughterboard and microphone should now be exposed.
    Ask FixBot
  21. Ring Stick Up Cam Battery Microphone Replacement: step 21, image 1 of 1
    • Gently remove the daughterboard from the base with your hands or the spudger if necessary.
    Ask FixBot
  22. Ring Stick Up Cam Battery Microphone Replacement: step 22, image 1 of 2 Ring Stick Up Cam Battery Microphone Replacement: step 22, image 2 of 2
    Halberd Spudger
    $2.99
    Buy
    • Use the hook end of the halberd spudger to carefully lift the microphone from the base.
    Ask FixBot
Caroline Smith
267 Reputation
2 Guides authored
Marist, Team 1-1, Chaterdon Spring 2023 Member of Marist, Team 1-1, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G1
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 64
All Time: 1,008
